If just Kodi is frozen (rather than the whole device) you won't have a crashlog until Kodi actually crashes. Enable debugging and see what's in your debug log. Most likely something is causing a deadlock. Identifying the build when the problem started may help narrow it down.
ok, I did a -kill SIGSEGV and got the following crashlog:
http://sprunge.us/FIQN
Is that helping in any way?
Stupid me: How do I enable debugging?
(2016-09-18, 21:24)jobisoft Wrote: [ -> ]ok, I did a -kill SIGSEGV and got the following crashlog: http://sprunge.us/FIQN
Settings/system/logging with standard to expert settings level.
(2016-09-18, 21:24)jobisoft Wrote: [ -> ]Stupid me: How do I enable debugging?
Settings > System > Logging > Enable debug
There's a PVR related change PR10472 that calls HasAddons() which seems to be part of your backtrace. Try to identify the last working build.
(2016-09-18, 19:30)Milhouse Wrote: [ -> ] (2016-09-18, 18:33)*Spider* Wrote: [ -> ]Did you just change the Kernel file in #917? I just re-downloaded that build and now it boots without the big rainbow square and the supported white pi wifi stick.
No, nothing has changed.
(2016-09-18, 18:33)*Spider* Wrote: [ -> ]Could you add the RTL8192EU drivers to these builds? It still locks up with #917 and the debug screen info.
RTL8192EU is already included (always has been). I'm not sure why this driver would now cause problems since #0902, although there are some kernel and firmware changes in #0902 which is why I asked you to test the kernel from #0902 with #0901 firmware.
After a substantial amount of testing, I have concluded that this RTL8192EU works perfectly with OPENELEC 603 on a Pi 0 and not on a later version.
How can I help you to get this working with your September nightly builds? It only sees one wifi network (mine) instead of the neighborhoods around me and it constantly fails to connect to my router.
On OpenELEC it sees all of my neighbors routers.
What files do you want from OpenELEC 603 To help you resolve this problem?
Looks like last working build is 915, but I will have to test more, because with enabled debug logging, it is not 100% reproducible. I even got #916 working a few times with enabled debug logging.
Edit: The normal log is just more detailed, there is no extra debug.log?
Than this is the crashlog with enabled debug logging:
http://sprunge.us/cfbZ
Edit2: I just want to add, that I have a second Pi2 in my bedroom, which behaves the same. Furthermore my setup was working for a couple of days with #916, until my Win10-PC (which runs the DVBViewer-Recording-Service and has 3 DVB-S tuners connected) updated itself this morning. I do not understand this at all.
What else can I do to help you guys fix this?
(2016-09-18, 22:44)*Spider* Wrote: [ -> ]After a substantial amount of testing, I have concluded that this RTL8192EU works perfectly with OPENELEC 603 on a Pi 0 and not on a later version.
It would help if you were consistent about the problem and when it started - you said you've had kernel panics since #0902, but apparently you no longer have these panics? If the dongle now works with #0917 but you see more networks with OpenELEC 6.0.3 (and have a more stable connection) then you have an opportunity to identify when this change occurred as my builds go back a long, long time.
Here's the version history for the RTL8192EU driver:
https://github.com/LibreELEC/LibreELEC.t...package.mk
You could also test with LibreELEC 7.0.2 and, if you experience the same problems, then I'd advise you to report it on the LibreELEC forum as it's not an issue caused by any new code being tested in these builds (this thread is not here to fix each and every bug in LibreELEC).
(2016-09-18, 22:45)jobisoft Wrote: [ -> ]What else can I do to help you guys fix this?
I've posted a comment on PR10472.
I may need a more detailed backtrace in which case I'll upload a debug-enabled build overnight that you can test with (just upgrade to it as normal then generate your crashlog etc.). Will post details once it's uploaded.
New LibreELEC.tv Krypton build #0918:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.4 #1 Sun Sep 18 21:05:46 BST 2016 armv6l GNU/Linux
# vcgencmd version
Sep 14 2016 20:00:33
Copyright (c) 2012 Broadcom
version efa16f891edfcb0ba1aae15be195ad9d8b38d6be (tainted) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160918210447-#0918-g88a20f0 [Build #0918]
# vcdbg log msg 2>&1 | grep DTOK
# Kernel device tree status: DISABLED
Based on tip of
LibreELEC.tv master (88a20f0b,
changelog) and tip of
XBMC master (3f23348b,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (29d87e7c, ahead +2)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (2c8ffc7b), inputstream.rtmp (91bb3741), inputstream.smoothstream (081c6c43), peripheral.joystick (263aa849), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (42c91b1c), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7, +4), pvr.vbox (2750c92a), pvr.vdr.vnsi (da5fdd5a), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
- Include [env] PR:738: scripts/mkimage: Add run mode, remember default selection, resize gpt partitions
- Include [env] PR:739: linux-firmware build system rework
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: peripheral.joystick: Disable udev and see if stability improves (peripheral.joystick)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10445: require click action to activate slider controls
Build Highlights:
- MMAL fixes, remove dead code
- Enable NEON in kernel (RPi2/3 only)
Build Details:
- LibreELEC.tv:
- kodi: update to 17.0-beta2-6e9d6fb (PR:746, 8 commits, 19 files changed)
- XBMC:
- [osx] - fix sse flags when using autoconf/xcode (PR:10473, 2 commits, 2 files changed)
- Fix "Custom" view mode not showing in view mode list (PR:10481, 1 commit, 1 file changed)
- add Pull request template (PR:10379, 1 commit, 1 file changed)
- [estuary] avoid hyphens in front of temperatures (PR:10487, 1 commit, 2 files changed)
- [PVR] Fix PVR not working after using kodi login screen (trac#16813) (PR:10480, 3 commits, 16 files changed)
- [settings] make skin settings button more obvious (PR:10252, 1 commit, 2 files changed)
- [docs] add Pull request template (df6e9d76)
- pvr.stalker:
- Fix crash (PR:75, 4 commits, 48 files changed)
- newclock5:
- New commits in this build:
- MMAL: Move pool into base class (b74de6ce)
- MMAL: Make setting the decoder more consistent between MMALCodec and MMALFFMpeg (d9731f2a)
- MMAL: Set processInfo in pool (01f1de9b)
- ApplicationPlayer: Remove dead code (2c4a646c)
- Updated commits in this build:
- Added: [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
The changes to MMAL have created playback issues with 3D T/B (or O/U) encoded files (started with #0916, 16-Sep-2016)
The screen will flicker momentarily, rendering the top as a complete frame for one eye and the bottom as a complete frame for the other eye.
OMX still has problem with playback with 3D MVC files - scanning through the file (arrow key left or right) has the player jump to the correct time but playback is frozen and cannot be restarted.
Both MMAL and OMX still have the subtitle problem as commented previously and
here (the link).
Using #0917 then #0918 (with debug switched on) playing a video and bringing up both audio and subtitle off-set options in top centre of Estuary GUI, I found was unable to adjust (left-right) with either CEC remote or the keyboard. (Stuck, unable to adjust)
Steps to create problem, with video playing, via playback GUI
First adjusted audio off-set, movement left and right OK
Then switched to subtitle off-set, movement left and right NOT OK
Swiched back to audio off-set, movement left and right NOT OK
kodi debug.log
Note: almost never need to adjust audio/subtitle off-set, so not tried option in a long time, (Apologies if its an error in my set-up?)
(2016-09-18, 23:23)Milhouse Wrote: [ -> ] (2016-09-18, 22:45)jobisoft Wrote: [ -> ]What else can I do to help you guys fix this?
I've uploaded a debug enabled build #0918x:
RPi2 (318MB)
Just upgrade as normal, then produce the crashlog. You can revert back to #0918 afterwards if you like.
