It seems to simply reboot with version 0725 every time. I have been placing it in the update folder as I have always done on my windows network.Thank you for your reply.
(2016-08-14, 03:16)Milhouse Wrote: [ -> ] (2016-08-14, 02:30)nb2a Wrote: [ -> ]It seems that my system shows version 0725. No matter what I try it does not seem to upgrade after placing a newer file in the update folder.
Not sure why you quoted your other post (which I assume is now resolved?) as it doesn't seem relevant to your upgrade issue.
So what happens when you reboot - does the system detect the new tar file? If not, are you copying the tar file into the .update directory (note the leading . when accessing the folder in ssh)? How are you copying it - could it be that it doesn't have the .tar extension?
After you copy the new tar file but before you reboot, run the following and paste the results:
ls -la /storage/.update 2>&1 | pastebinit
Assuming you've copied the file correctly, reboot and describe exactly what happens when the Pi restarts (a video would be nice!)
(2016-08-14, 02:30)nb2a Wrote: [ -> ]Is there a Settings addon available? It was so much better when the addon that did the upgrades worked but it seems that one is not being updated anymore.
Thanks again
Yes it's now built-in - access it via the LibreELEC Settings add-on. See the first post, note #7 for configuration details. If it's not working post a debug log.
(2016-08-14, 06:22)nb2a Wrote: [ -> ]It seems to simply reboot with version 0725 every time. I have been placing it in the update folder as I have always done on my windows network.Thank you for your reply.
Then you're copying it into the wrong folder, or copying the wrong file - hundreds of other users are upgrading without any problem.
Since you haven't provided the information I asked for I can't help any further.
I'm having some buffering/stuttering problems on some files. Don't know if the Pi3 is not powerful enough, or if there is something wrong with my setup.
If anyone can see something in my log and give me a hint on what could be wrong I would appreciate it.
http://sprunge.us/JdhS
Adjust refresh rate and Sync display is enabled. Only have enabled MMAL. OMX disabled. LibreElec #810.
This is the mediainfo for a file with problem.
General
Unique ID : 234811680756598974706753784405900282139 (0xB0A715B09C218551B49127B04372491B)
Complete name : Z:\series\Continuum\Season 2\Continuum - S02E06 - Second Truths Bluray-720p.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.18 GiB
Duration : 44mn 8s
Overall bit rate : 7 076 Kbps
Encoded date : UTC 2014-03-14 06:17:10
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 44mn 8s
Bit rate : 5 566 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.252
Stream size : 1.67 GiB (77%)
Writing library : x264 core 140 r2377 1ca7bb9
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5566 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 44mn 8s
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 93.750 fps (512 spf)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 476 MiB (21%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:21.243 : en:00:03:21.243
00:21:24.533 : en:00:21:24.533
00:36:53.795 : en:00:36:53.795
(2016-08-14, 18:04)raptorjr Wrote: [ -> ]I'm having some buffering/stuttering problems on some files. Don't know if the Pi3 is not powerful enough, or if there is something wrong with my setup.
The format of the file is fine and you data is arriving over network okay (buffers fill up and remain full).
There are a few PVR/EPG messages while playing like:
17:45:45 684.769470 T:1472197536 DEBUG: EPG - UpdateFromScraper - updating EPG for channel 'VH-1' from client '440135507'
Is it any better with live tv disabled?
If not a sample would be useful (e.g. use makemkv or similar to produce a two minute sample) and upload somewhere (e.g. dropbox/google drive) and I'll test it here.
(2016-08-14, 18:34)popcornmix Wrote: [ -> ] (2016-08-14, 18:04)raptorjr Wrote: [ -> ]I'm having some buffering/stuttering problems on some files. Don't know if the Pi3 is not powerful enough, or if there is something wrong with my setup.
Thank you. I will try and disable LiveTV and see if that helps.
Haven't tried to figure out if the buffering/stuttering is happening at the same time every time, but will find out and make a sample if it is.
New LibreELEC.tv Krypton build #0814:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0 #1 Sun Aug 14 21:05:58 BST 2016 armv6l GNU/Linux
# vcgencmd version
Aug 10 2016 20:40:48
Copyright (c) 2012 Broadcom
version c62d8dc8087e79a3e3e16846fc37ac9efa878731 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160814210359-#0814-g17fb8db [Build #0814]
# vcdbg log msg 2>&1 | grep DTOK
002384.001: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
LibreELEC.tv master (17fb8dbb,
changelog) and tip of
XBMC master (961d0121,
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (2cf8fd5b, ahead +3)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (7898a672, +13), inputstream.rtmp (7bf2298e), inputstream.smoothstream (b63ecbb4, +3), peripheral.joystick (75966fa3, +5), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4), pvr.dvbviewer (7a7ead36), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f), pvr.iptvsimple (21e91a5f), pvr.mediaportal.tvserver (72452b9d), pvr.mythtv (d10d210b), pvr.nextpvr (32b3c2ff), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (5f440e00, +4), pvr.vbox (f38f82f0), pvr.vdr.vnsi (98673d3a, +1), pvr.vuplus (4f2ad621), pvr.wmc (979c37db)
- Exclude [env] kodi-999.99-PR10164-add-aetempo-filter.patch: Merged upstream
- Exclude [env] kodi-999.99-PR10206-recursive-remove.patch: Merged upstream
- Exclude [env] kodi-999.99-PR10211-videoplayer-fix-handling-of-progressive-content-in-rendermanager.patch: Merged upstream
- Exclude [env] kodi-999.99-VideoPlayer_Fix_build_after_dropping_deinterlacing_mode.patch: Merged upstream
- Exclude [env] libcec-PR208.patch: Merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: curl: bump 7.50.1 (sync with kodi 17b1)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: expat: Bump to 2.2.0
- Include [env] patch: ffmpeg: Bump to 3.1.2-Krypton-Beta1 (6da2f5f)
- Include [env] patch: kodi: sync appliance.xml after xbmc/PR10201
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Include [env] PR:573: kodi/Intel: Various improvements from fritsch
- Include [env] PR:621: init: mount per-client boot/disk if available & configured
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
Build Highlights:
- Minors
Build Details:
- XBMC:
- [PVR] Fix home screen channel widget context menu. (PR:10286, 1 commit, 1 file changed)
- paplayer: another fix for pause and speed (PR:10291, 1 commit, 1 file changed)
- VideoPlayer: fix false positive drop detection for ffmpeg decoder (PR:10284, 1 commit, 2 files changed)
- respect start_pts for omx_pts (32-bit) handling in aml (PR:10260, 2 commits, 3 files changed)
- settings: Add settings option to control atempo resampling (PR:10234, 1 commit, 10 files changed)
- [osx/XBMCHelper] - some fixes (PR:10285, 8 commits, 6 files changed)
- [iOS/XMemUtils] - fix pagesize retrieval once and for all for all ios… (PR:10294, 1 commit, 1 file changed)
- Disable Travis autotools testing and addons. (PR:10292, 2 commits, 1 file changed)
- add backward compatibility for AppearanceSettings (PR:10265, 1 commit, 1 file changed)
- newclock5:
- Commits no longer in build:
- settings: Add settings option to control atempo resampling (37397b0e)
- paplayer: another fix for pause and speed (7ff57aba)
- VideoPlayer: fix false positive drop detection for ffmpeg decoder (e2de38e2)
- Added: [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
(2016-08-12, 13:34)popcornmix Wrote: [ -> ]I think you have an nfs issue rather than a jpeg issue:
If I use an OS mounted volume with
Options=nfsvers=3,rw,intr,noatime,rsize=32768,wsize=32768,nolock,async,proto=udp
Then I don't get the errors. Just using a normal NFS connection in Kodi and I get the errors and missing images. This is connecting to a Mac running El Capitan. I'll do some more testing. I've gone back through the builds and noticed the errors also on v16 but not as bad.
Hallo good folks! I really wanted to thank you for all your efforts and say keep going like this you're the BOMB
Well, with every new post comes a question. Here is mine:
I use (for my video collection) a central mysql database on my Synology. My advancedsettings MYSQL Section looks like this:
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>IP Address</host>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
the funny thing is that it doesnt work. The Database cant be read with the Build #0813. Nothing appears and happens.
I used the Build #0701 and it worked perfectly.
What could possibly fix the problem?
p.s.: i'am sorry for my bad english
AND THANK YOU ONCE AGAIN
(2016-08-15, 10:42)zoranserbe Wrote: [ -> ]the funny thing is that it doesnt work. The Database cant be read with the Build #0813. Nothing appears and happens.
p.s.: i'am sorry for my bad english AND THANK YOU ONCE AGAIN
Nobody cares about your LAN IP address - obfuscating it just makes it that bit more difficult to help you.
MySQL works in #0813, I'm using it here.
There is a Video database migration in #0720, perhaps the migration failed when you upgraded from #0701 to #0813.
Do the following:
1. Enable debug logging in Kodi #0813
2. Drop the MyVideos107 database from your MySQL server
3. Restart Kodi #0813 and allow it to finish the database migration (it will migrate your MyVideos106 database)
Once the Kodi GUI appears if you still have database issues log in to Kodi using ssh and run:
cat /storage/.kodi/temp/kodi.log | pastebinit
then post the url.
(2016-08-15, 18:51)thent Wrote: [ -> ]since long time ago - unfortunately I cannot tell since which build exactly, but at least the beginning of this year - I've been experiencing kodi crashes (+ subsequent rebooting) when opening audio streams. I'm using the radiotunes addon together with Yatse from several Android devices to run the streams. Usually, when kodi was idle for hours, it crashes immediately after opening a second stream righter after the first one.
Yes. I flagged it on the Kodi Slack, and the problem has been identified
Quote:ouch, that's a std:hared_ptr<CFileItem> afaik so just about any nasty thing can have happened to it
like passing it by reference which doesn't up the usage count and then another thread changes the currently playing file deleting the one we passed by reference
I'm hoping someone who knows this code better will come up with a fix.
New LibreELEC.tv Krypton build #0815:
RPi /
RPi2
# uname -a
Linux rpi512 4.7.0 #1 Mon Aug 15 21:05:15 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160815210333-#0815-g44a05fd [Build #0815]
002385.300: Kernel trailer DTOK property says yes
Based on tip of
LibreELEC.tv master (44a05fda,
XBMC master (3a01911c,
Build Highlights:
- Estuary skin sync. Fix seek label.
Build Details:
- LibreELEC.tv:
- Add satip devices option (PR:622, 1 commit, 3 files changed)
- WeTek: RELEASE_DIR removing fix (PR:625, 1 commit, 1 file changed)
- XBMC:
- [darwin]: - fixed cpu usage reporting for all darwin platforms by hoo… (PR:10295, 1 commit, 3 files changed)
- [estuary] skin sync (PR:10253, 3 commits, 7 files changed)
- [addons] Add Window.Property(Addon.ID) to addon settings dialog (PR:10037, 1 commit, 1 file changed)
- Controller dialog: Feature groups (PR:10293, 3 commits, 18 files changed)
- [skin] show playspeed (PR:10266, 2 commits, 4 files changed)
- [skin.estouchy] updates (PR:10298, 1 commit, 4 files changed)
- kernel 4.7.y:
- New commits in this build:
- Add cm3 dts file (31b6fbc3)
- config: Enable SENSORS_LM75 (054f1600)
- config: Enable SERIAL_SC16IS7XX (193f590d)
- snd-bcm2835: Don't allow responses from VC to be interrupted by user signals (338dfd6c)
(2016-08-15, 11:09)Milhouse Wrote: [ -> ] (2016-08-15, 10:42)zoranserbe Wrote: [ -> ]the funny thing is that it doesnt work. The Database cant be read with the Build #0813. Nothing appears and happens.
Do the following:
then post the url.
I've followed the steps above and now it works perfectly! it really was the migration which didnt work
Thank you once again!!!
(2016-08-15, 20:30)popcornmix Wrote: [ -> ] (2016-08-15, 18:51)thent Wrote: [ -> ]since long time ago - unfortunately I cannot tell since which build exactly, but at least the beginning of this year - I've been experiencing kodi crashes (+ subsequent rebooting) when opening audio streams. I'm using the radiotunes addon together with Yatse from several Android devices to run the streams. Usually, when kodi was idle for hours, it crashes immediately after opening a second stream righter after the first one.
These are good news, thank you very much!
I am using the 08 August nightly. Everything works nicely so far.
However I am missing the Options for the CEC Adapter? I searched in all menus but could not find anything? Is it not included or am I missing something?
