nomnom27
I'm still working on the studio icon displaying for boxsets. Right now it will only display when "MOVIE SET CASES" is enabled.
UPDATE #57
Main menu player controls
The player controls were not displaying if the horizontal main menu was enabled. Thanks to melons2 for reporting the bug.
04-12-18 Update
latts9923 How can i copy my build and move it on kodi from spmc without losing my settings
lathie
If you have the script.skin.helper.skinbackup addon installed you can export your MQ 7 skin settings from the "RESTORE SETTINGS" option and import the zip file it creates.
By default it creates the zip in Kodi\userdata\addon_data\script.skin.helper.skinbackup.
Hey latts I did the 3/29 update however I still experience the title showing up in text a long with the logo instead of just the logo. I noticed that when I toggle "logo as title (on top if available" to turn on it also toggles "show original title" to turn on. Am I doing something wrong?
Caped Crusader
I bet they're both set to "true" in your settings.xml file. Open the file Kodi\userdata\addon_data\skin.aeonmq7.krypton.mod\settings.xml and search for "originaltitle". If that is set to true, change it to false.
(2018-04-14, 21:07)latts9923 Wrote: [ -> ]@Caped Crusader
Thanks latts I'll try that out later.
(2018-04-14, 21:36)Caped Crusader Wrote: [ -> ] (2018-04-14, 21:07)latts9923 Wrote: [ -> ]@Caped Crusader
@latts I did what you said and that corrected the problem. You're a scholar and a gentleman, a king amongst men. Thank you sir.
hi ! , i've got a question about the updates. the download link in the first page have all the updates or i must download and install the updates one by one ? thank you.
doctor4979
I always update the main download on the first post when I post a new update.
@Latts. I'm currently organising logo's and banners for my music library. Do I need to do extra steps besides copying the logo.png and banner.jpg files to the artist folders? I found out that the filename should be exactly logo.png for the logo. If the filename is different (for example clearlogo.png) the logo won't appear. That'a pity.
I don't know what happened in the word but yesterday I had the time to reopen Kodi and save last modifications in xml files and many features don't work any more now
Movies: discart is no more visible in right list view, no extra fanarts are displayed even if no change has been applied to the option "enable extra fanart" in the top menu, no rating info (tomato, etc...) are displayed in dialog info view
TV Series: extra fanarts are no more displayed even if no change has been applied to the option "enable extra fanart" in the top menu
Music: discart is no more visible for albums in right list view and widget view (I use music smart playlist)
Somebody else had same problems
MB1968
It sounds like you've got it. Yeah, you will have to follow the correct naming convention for your images.
Jumpy73
Did you modify the code in some of your xml files? If so, that could be the cause of the problems you're currently having.
