(2017-01-02, 15:32)latts9923 Wrote: [ -> ]I might look at that sometime. I'm working on additional Holidays for the Holiday Mod right now.
Thanks for the reply bro, I look forward to you hopefully working on it.
(2017-01-05, 11:10)bolter Wrote: [ -> ]currently I get 6 tiled images when kodi goes to music screensaver. how can I get it back to slideshow of 1 at a time
watch gallery
I haven't messed much with the music side of this. I'll take a look later today when I get home.
bolter, only need configure, in fullscreen press M, find "setting" button, have options for change background images, please don´t cross post with
same question. @
latts9923, he´s fixed trouble, don´t need check.
(2017-01-05, 14:44)Wanilton Wrote: [ -> ]@bolter, only need configure, in fullscreen press M, find "setting" button, have options for change background images, please don´t cross post with same question. @latts9923, he´s fixed trouble, don´t need check.
Good deal...thanks Wanilton!
hi to all,
is someone working in the integration of the shelf3D view for the moment ?
i missed a lot that view in the Spin mod.
thank for the answers.
(2017-01-05, 15:16)toutoune290 Wrote: [ -> ]hi to all,
I'm looking at it right now...going to take some time to get it fixed I think.
Hey latts - don't know if I should post here or in emirales MOD thread, but if I arrow up to the Collection/Change View Menu, I lost the selection for Show/Hide Watched. Not sure if there is an option somewhere to make it visible or if a household member did something while trying to navigate... I'm at a loss. If I switch to Estuary,I can toggle, but it's lost in the MOD. All are affected (Movies, TV Shows, Concerts). Any suggestions? I already tried reinstalling your mod with no luck.
(2017-01-07, 05:08)RonnieG3 Wrote: [ -> ]Hey latts - don't know if I should post here or in emirales MOD thread, but if I arrow up to the Collection/Change View Menu, I lost the selection for Show/Hide Watched. Not sure if there is an option somewhere to make it visible or if a household member did something while trying to navigate... I'm at a loss. If I switch to Estuary,I can toggle, but it's lost in the MOD. All are affected (Movies, TV Shows, Concerts). Any suggestions? I already tried reinstalling your mod with no luck.
Hmm...I will have to install a fresh Krypton mod and see if that's available in the menu.
I had to tweak the file IncludesTopMenu.xml and now the Hide Watched button displays correctly. The fix is available below. Just replace your existing file with this one. Or, if you've altered this file with additional mods, copy and paste the code between the <!-- Media Info Mod --> markers.
Hide Watched Fix
I have updated the original download with this fix as well.
Thanks for letting me know RonnieG3!
I finally got the two views from the Spin Mod (Shelf3D and List3D) working! I'll put together a fix for this as soon as I can.
One bug I noticed is the progress bar when video is paused is empty.
(2017-01-08, 20:40)Ruk12345 Wrote: [ -> ]One bug I noticed is the progress bar when video is paused is empty.
I'm not seeing that problem on my end. Check your file DialogSeekBar.xml. I uploaded a fix for this on post
#24.
First off thanks for the Mod, I have a bit of a weird problem and I apologize if this has been asked/answered before.
Using widgets on the home screen movies/tv etc work great, I have a problem opening most programs or video add-ons from the widgets. A good example of this is using ADD-ONS - VIDEO with iPlayer or BOB if I click the on the widget nothing happens apart from the click sound yet if I use the ADD-ONS - AUDIO both the add-ons open to their respective add-ons, iPlayer to the radio section and BOB to it's menu.
With the ADD-ON - PROGRAMS widget most programs don't open although there are a couple such as Backup that do. I have re-installed Kodi and the skin a couple of times and always come across the same problem.
This is with Kodi 17 RC2 on windows 10
Part of the debug log with it working in ADD-ONS - AUDIO is:
20:38:52.780 T:916 DEBUG: Thread JobWorker start, auto delete: true
20:38:52.781 T:3008 DEBUG: Thread LanguageInvoker start, auto delete: false
20:38:52.782 T:3008 INFO: initializing python engine.
20:38:52.782 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): start processing
20:38:53.254 T:8672 DEBUG: ------ Window Init (DialogBusy.xml) ------
20:38:53.456 T:3008 DEBUG: -->Python Interpreter Initialized<--
20:38:53.456 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): the source file to load is "C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py"
20:38:53.457 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): setting the Python path to C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww;C:\Users\herei\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files\Kodi\system\python\DLLs;C:\Program Files\Kodi\system\python\Lib;C:\Program Files\Kodi\python27.zip;C:\Program Files\Kodi\system\python\lib\plat-win;C:\Program Files\Kodi\system\python\lib\lib-tk;C:\Program Files\Kodi;C:\Program Files\Kodi\system\python;C:\Program Files\Kodi\system\python\lib\site-packages
20:38:53.457 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): entering source directory C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww
20:38:53.474 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): instantiating addon using automatically obtained id of "plugin.video.iplayerwww" dependent on version 2.19.0 of the xbmc.python api
20:38:56.793 T:3008 INFO: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): script successfully run
20:38:56.819 T:6240 DEBUG: Thread BackgroundLoader start, auto delete: false
20:38:56.855 T:6240 DEBUG: Saving fileitems [plugin://plugin.video.iplayerwww/?content_type=audio]
20:38:56.857 T:6240 DEBUG: Thread BackgroundLoader 6240 terminating
20:38:56.858 T:8672 DEBUG: RetrieveMusicInfo() took 40 msec
and part of the debug log where it fails with ADD-ONS - VIDEO is:
0:41:50.508 T:8672 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
20:41:50.634 T:8672 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
20:41:51.665 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:51.665 T:8672 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
20:41:51.669 T:8672 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
20:41:51.798 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:52.264 T:8672 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
20:41:52.264 T:8672 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
20:41:52.379 T:8672 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
20:41:53.329 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:53.330 T:8672 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
20:41:53.428 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:54.328 T:8672 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
20:41:54.406 T:8672 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
20:41:54.407 T:8672 ERROR: Window Translator: Can't find window video
20:41:54.407 T:8672 ERROR: Activate/ReplaceWindow called with invalid destination window: video
20:41:54.407 T:8672 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
20:41:59.935 T:8672 DEBUG: CWinEventsWin32::WndProcWindow is active
Any help would be greatly appreciated, I have probably missed something but I do not have a clue what. Thanks in advance......
