MB1968
Got it! I also removed the extra colon that was displayed for "Version". It will be part of the next update.
@OrbS82User
I am noticing that all of the images you are posting are expiring very, very quickly. Please have the courtesy to go back and clean up your posts to remove the broken images. An example is shown here...
https://forum.kodi.tv/showthread.php?tid...pid2758556
If you intend to have very short life spans for your images, then
do not embed the image in the post. Simply link to it.
Thank you.
browse to your kodi to AAA movies with lots of votes (over 1000 000) and look at these 2 places here in pics marked:
https://ibb.co/cg1KaK
https://ibb.co/cDRkFK
Does the ratings and votes start to dance as soon as there are too many? May the text box is a bit too tight.
(on the pics its fixed)
(2018-09-02, 04:13)latts9923 Wrote: [ -> ]@Jumpy73
You're welcome!
I found the problem with "minutes" being duplicated. It will be part of the next update.
Great
latts9923 in MOVIES-SET view and in Windget views (above main menu item, MOVIES, TV SHOW; MUSIC and so on) extrafanarts are not displayed. Only one image is displayed.
As we can solve the bug?
Tks and good nigh
(2018-09-03, 22:47)Jumpy73 Wrote: [ -> ]@latts9923 in MOVIES-SET view and in Windget views (above main menu item, MOVIES, TV SHOW; MUSIC and so on) extrafanarts are not displayed. Only one image is displayed.
In the Skin.xml's I read code lines for extrafanarts at sets, but extrafanarts at sets have as far as I know never worked. I would also be curious if that works ...
(2018-09-03, 23:24)chrissix Wrote: [ -> ] (2018-09-03, 22:47)Jumpy73 Wrote: [ -> ]@latts9923 in MOVIES-SET view and in Windget views (above main menu item, MOVIES, TV SHOW; MUSIC and so on) extrafanarts are not displayed. Only one image is displayed.
some times ago @
latts9923 addressed this issue in the following way... if I remember right, extrafanart images for cycling is taken not from extrafanart folder into the Set-XXX parent folder, but from the extrafanarts of movies of the set... in any case extrafanart doesn't work in all the above mentioned scenarios
(2018-09-03, 23:37)Jumpy73 Wrote: [ -> ]some times ago @latts9923 addressed this issue in the following way... if I remember right, extrafanart images for cycling is taken not from extrafanart folder into the Set-XXX parent folder, but from the extrafanarts of movies of the set... in any case extrafanart doesn't work in all the above mentioned scenarios
Maybe @
latts9923 can use this as a workaround. It should work only with adding some lines .xml's and the use of AB:
https://rmrector.github.io/script.artwor...onfreefun/
(2018-09-03, 20:50)chrissix Wrote: [ -> ]browse to your kodi to AAA movies with lots of votes (over 1000 000) and look at these 2 places here in pics marked:
Chris, How do i get the rotten tomato and other ratings as shown here in this page?
Also, the Oscar images shown.. that is fantastic, how can i enable that?
Not sure what "start to dance" means, but on my side the ratings and total votes are exactly the same in right list view and info screen for movies with more than 1.000.000 votes (for example: Pulp Fiction, Avatar, Django Unchained).
I'm using the "Light IMDb Ratings Update" addon to frequently update the ratings and votes for movies and tv shows.
https://forum.kodi.tv/showthread.php?tid=316342
(2018-09-04, 14:28)MB1968 Wrote: [ -> ]Not sure what "start to dance" means, but on my side the ratings and total votes are exactly the same in right list view and info screen for movies with more than 1.000.000 votes (for example: Pulp Fiction, Avatar, Django Unchained).
By that I mean that the field starts to scroll when there is not enough place given to the "textbox".
Since it is no problem for you, I have identified the problem now.
It's up to Transifex, if another language is set (german in my case), there is not enough space in some views. Self-fixing or ignoring only solution.
Tte text is scrolling too in my language (Dutch). I assume you changed some code? If so, can you point me into the right direction and provide the code?
Cheers
@"chrissix"
MB1968
I'm sure that label is set to autoscroll. I'll take a look at it.
(2018-09-06, 14:47)latts9923 Wrote: [ -> ]I'm sure that label is set to autoscroll. I'll take a look at it.
It's on both:
The MyVideoNav.xml (DialogVideoInfo on top right)
ViewsRightList (under clearart/clearlogo)
I am missing a clearart here?
I do not see an option above to add one.
I do see the clearart displayed correctly inside the dialogeboxview
