Hi latts wondering if you could help me with a sets animation condition.
I have a condition set up on discs sets so they slide out when set case is focused. This works as intended when you scroll from a bluray or dvd to set.
The problem i've having is when you are scrolling from one set to another set next to each other in a list. Then the slide animation doesn't work.
I'm not sure what other condition to include to ensure it works when sets are beside one another.
<animation effect="slide" start="-1527,38" end="0,0" delay="1900" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
<animation effect="rotate" start="0" end="-360" center="auto" time="30000" delay="8000" loop="true" reversible="false" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
<animation effect="slide" start="-1527,38" end="0,0" delay="1900" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left) + ![Container.OnNext | Container.OnPrevious]">Conditional</animation>
<animation effect="rotate" start="0" end="-360" center="auto" time="30000" delay="8000" loop="true" reversible="false"condition="SubString(ListItem.Path,videodb://movies/sets,left) + ![Container.OnNext | Container.OnPrevious]">Conditional</animation>
<control type="group" id="25000">
<animation type="WindowOpen" reversible="false">
<effect type="slide" start="-150,0" end="0,0" time="500" delay="500" tween="cubic" easing="out" />
<effect type="fade" start="0" end="100" time="500" delay="500" />
</animation>
<animation type="Visible" reversible="false">
</animation>
<animation effect="fade" start="100" end="0" time="200">WindowClose</animation>
<animation type="Hidden">
<effect type="slide" start="0,0" end="-150,0" time="300" tween="cubic" easing="out" />
<effect type="fade" start="100" end="0" time="200" />
</animation>
<visible>![IsEmpty(Window(Home).Property(SkinHelper.ListItem.0.Art.DiscArt)) | Skin.HasSetting(noposterlistdiscart)] + Window.IsActive(25) + SubString(ListItem.Path,videodb://movies/sets,left) + Control.IsVisible(9923) + Control.IsVisible(70)</visible>
<control type="image">
<width>240</width>
<height>240</height>
<left>330</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.0.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.0.Art.DiscArt))</visible>
<animation effect="slide" start="-1140,0" end="0,0" delay="1000" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>442</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.1.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.1.Art.DiscArt))</visible>
<animation effect="slide" start="-1252,0" end="0,0" delay="1100" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
<animation effect="rotate" start="0" end="-360" center="auto" time="30000" delay="8000" loop="true" reversible="false" condition="SubString(ListItem.Path,videodb://movies/sets,left) ">Conditional</animation>
</control>
<width>240</width>
<left>555</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.2.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.2.Art.DiscArt))</visible>
<animation effect="slide" start="-1365,0" end="0,0" delay="1200" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>652</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.3.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.3.Art.DiscArt))</visible>
<animation effect="slide" start="-1478,0" end="0,0" delay="1300" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>765</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.4.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.4.Art.DiscArt))</visible>
<animation effect="slide" start="-1590,0" end="0,0" delay="1400" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>878</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.5.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.5.Art.DiscArt))</visible>
<animation effect="slide" start="-1702,0" end="0,0" delay="1500" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>1005</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.6.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.6.Art.DiscArt))</visible>
<animation effect="slide" start="-1188,38" end="0,0" delay="1600" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>1118</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.7.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.7.Art.DiscArt))</visible>
<animation effect="slide" start="-1302,38" end="0,0" delay="1700" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>1230</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.8.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.8.Art.DiscArt))</visible>
<animation effect="slide" start="-1414,38" end="0,0" delay="1800" time="2600" tween="cubic" easing="inout" condition="SubString(ListItem.Path,videodb://movies/sets,left)">Conditional</animation>
</control>
<width>240</width>
<left>1342</left>
<top>540</top>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.ListItem.9.Art.DiscArt)]</texture>
<visible>!IsEmpty(Window(Home).Property(SkinHelper.ListItem.9.Art.DiscArt))</visible>
</control>
</control>
