(2017-07-03, 02:51)Jay19802005 Wrote: [ -> ]When playing music I can't get my lyrics to appeasr like that I just get regular lyrics
When playing a song, right click or bring up the context menu and select Activate Manfeed Lyrics.
(2017-07-03, 10:11)Jay19802005 Wrote: [ -> ]I'm also having a problem getting disc Art on widgets in movie menu section
Hmm...which widget are you using?
(2017-07-03, 21:48)oboytrakzz Wrote: [ -> ]I don’t do music.... Problems with music. What do you mean by scraped for discussion art...
You need to run Artwork Downloader on your Movies to get extra content like disc art, clearart, logo, etc.
Ruk12345
I was able to add the option to turn off the media case for the List3D View. It will be part of the next update.
latts9923
Yes sir. I've run. Artwork Downloader. Are there any toggle or anything I need to do in settings?
Same issue for list 3d movie view no animated artwork. I even re seclected the animated art via context menu with no luck.
Disc art looks great on list 3d movie view tho
(2017-07-03, 23:37)oboytrakzz Wrote: [ -> ]@latts9923
No sir, no toggles to control the disc animation...it's built into Shelf3D. Does your disc art work on other views?
(2017-07-03, 23:38)Ruk12345 Wrote: [ -> ]AWESOME BRO, thanks!
You betcha!
(2017-07-04, 00:35)Ruk12345 Wrote: [ -> ]Same issue for list 3d movie view no animated artwork. I even re seclected the animated art via context menu with no luck.
I never noticed that...fixed for all three new 3D Views. Thanks for reporting it. It will be included in the next update.
latts9923
Yes I get artwork animation on Right List View only.... updated Android Sheild and Windows 10. No artwork animation on 3D Shelfview on both devices
oboytrakzz
OK...is it the animated movie poster you're having trouble with? If so, I just found the problem with that and fixed it.
latts9923
On 3D views. The case moves, but the spinning disc doesn't show up at all
OK...just wanted to double check. If you see the disc spinning on Right List View, you should see the disc animation on the 3D Views. If not, try copying the updated files again...that's all I can think of.
latts9923
OK! I'll try that..... Thank You!!!
