Now i found where the line is. It is in the IncludeVariables.xml in the value_multilabel.
Ive added a "$INFO[Container.NumItems]" and now i have what i want.
But when i am in the main movies container in kodi the count of "$INFO[Window(0).Property(Movies.Count)" and "$INFO[Container.NumItems]" is the same. (sure it is)
One option is to replace MoviesCount with NumItems, but i decedid to add it with a reason, but now i want to reach:
If MoviesCount is the same like NumItems, then hide NumItems,
cause if i am in main movie label, no NumItems is necessary to show cause then its the same like Movies count.
But this are "value conditions". Don't know if its possible to set an "IfThenElse" "visible" contition in the value_multilabel in IncludeVariables.xml. No success until now.
To see how many items are in the actual container i am is very important feature i missed, for. e.g. in BlackGlassNova Skin it was implementet.
Its very useful when use Tags, or big Collections, or (Imdb250) Smart Playlists.
_____
Jay19802005
Under "theme" option, do you understand the TvTunes Addon toggle on/off button in the TopMenu?
If yes, this button is broken since i know AeonMq, not only the Mod, also in the non modded original AeonMq Skins.
We are not allowed to discuss this addon (I have to mention this addon is not explicit on the blacklist, only the repo where it is containing is on the blacklist)
But in this case it is about a broken Skin feature wich skin is not on blacklist an i'm sure we can discuss ist.
There are two possible options to solve this broken toggle on/off button in the topmenu of AeonMQ7
1. We have to modify the addon -> We have no chance
2. There are only code lines for this addon in the IncludesTopMenu.xml of AeonMQ7 skin -> Maybe we can find out what is broken in the code line
I have to admit it would be very practically if it would work again,
although it is one of the nicest features i know in kodi,
sometimes it get on nerves the always playing auto theme, but always i have go to the addon settings also sucks.
____
Edit:
I'm using v100.5.8
Now also tried v100.1.1, this version Wanilton (MQ7 Author) have use in his his actual AeonMQ7 repo (updated 18.6.2018)
And also tried newest version v100.6.1, the most actual (updated 6.6.2018) (Edit: This version is broken for Multi-Mod in DialogueVideoInfo [python error: runscript for a non-script...])
Makes no difference, am sure it's a skin depended problem.
____
Edit:
latts9923
I now just saw you published a youtube video on 16.01.2017 for AeonMQ7 Spin Jarvis (19.08.2016)
and at this date the toggle on/off button was working.
Not using an TvTunes version later that that date so what do you think changes in Kodi or Kodi Skin that causes the button now dead?
