Hi latts.
I'm testing Kodiflix , I found a bug , if it activates SHOWART in the selection (DE)ACTIVATE VIEWS , SHOWART is overlapped a Kodiflix.
it took me a while to understand , I deactivated SHOWART and in Kodiflix there is no more overlap SHOWART.
all the rest in (DE)ACTIVATE VIEWS is activated , except SHOWART that is disabled
(2017-12-18, 18:07)lathie Wrote: [ -> ]@latts9923 Its in all views now that i look is there a file i can be missing somewhere
I would copy all the files in 1080i from the main Multi-Mod download and see if that fixes it.
(2017-12-18, 21:24)movie78 Wrote: [ -> ] Great Job!
Now the 4k UHD Disc has the proper case and info...
PS: Movieset option is displaying movie in the set, any help.
Thanks movie78!
I'm going to try the Movieset Artwork Automater Addon.
Hey Latts,
I was using the shelf view before i switched to the KodiFlix view, In the shelf view, upper left hand corner you would see the name of the movie, the year it was made, how long the movie and a one sentence description of the movie plot.
For example, the movie Leon the professional - If you want a job done well, hire a professional.
Could these one sentence plot description be use in the KodiFlix view under the plot: outline, since nothing happens when you switch to this option?
gotham_x
Thanks for the bug find...it's now fixed. It will be part of the next update.
bobbie digital
That's the tagline you're seeing on the Shelf View. The tagline displays on KodiFlix right before the plot. But you can certainly put that in the plot outline field and only display the tagline when you switch to Plot: Outline.
(2017-12-18, 07:04)lathie Wrote: [ -> ]https://forum.kodi.tv/showthread.php?tid...6&page=260 The last few pages tells how to fix that
I tried it and now the rating info scraping works like a charm...
... If I can, I'd suggest to use Universal Movie Scraper (UMS) in addition to the above mentioned solution.
The first one solves the problem with rating info, while UMS solves the problem with Critics Consensus e Awards info. In this way all info included into the dialog info view (Detail Info) will be retrieved and displayed
Hope this help!
Does the Universal Movie Scraper have to be setup a certin way in settings
I've started porting MQ7 to Leia. In doing so I just noticed a few bugs with the List3D View. When you pause a movie and return to the View, the currently playing movie info is missing. I have a fix for Leia. I'll fix it on the Multi-Mod as well and include it in the next update.
We can still stay on 17.x right
(2017-12-20, 00:55)latts9923 Wrote: [ -> ]@gotham_x
Hi Latts,
where I come from it is said that luck rewards the audacious, so I will try to propose again 3 points I noticed time ago and which hadn't had a fix yet and new 2 points.
I hope they will be included into the next update too
1) Text and images in the media flags bar don't appear properly (language flags for audio tracks and subtitles seem to be displayed properly, only audio channels number icons are wrong positioned)... please see the following screenshot
https://www.dropbox.com/s/mme1ufbaxw7gtj...0.png?dl=0
2)
When I select a music album at the right side, the relative list of tracks appears at the left side. If the list started higher or the list had 1 entry less, the overlapping between the last track title and the transparent central ring of discart could be evoided... please see the following screenshot
https://www.dropbox.com/s/pkmfssbzc3humv...7.png?dl=0
3)
No discart for music album widgets based on smart-playlist. All stuff works for default music album widgets (ie ALBUMS - Random, ALBUMS - Recommended, etc...)
4)
The rating info for music contents is represented by a number between 1 and 5 (not like movies where rating info is represented by a number between 1 and 10). Is it possible to display the rating info for music contents in the right values scale?... please see how now appears the info in the following screenshots
https://www.dropbox.com/s/uwncqyz5vb26am...7.jpg?dl=0
https://www.dropbox.com/s/p5idy1e0m0do76...2.jpg?dl=0
5) in this last new release I noticed many new images that I can't see currently used in kodi (it surely is a my lack
). For example how can I substitute the current radio buttons with the new ones included into your new media/setting folder?
Is there something to enable here and there in the kodi settings area?... please see the following screenshot
https://www.dropbox.com/s/b1zx1cai02nbuw...s.jpg?dl=0
I hope these points could be useful to other guys needs too
Thanks for working hard and for sharing the results of it... really stunning for me!
Marry Christmas
(2017-12-20, 04:41)lathie Wrote: [ -> ]Does the Universal Movie Scraper have to be setup a certin way in settings
I suppose a key point is to insert your OMDB API KEY in the RATING section. If you continue having problems and if you considered it useful, I could send you a PM with my settings.xml file
(2017-12-20, 07:03)lathie Wrote: [ -> ]We can still stay on 17.x right
Yes...I'm just getting a Leia version of MQ7 ready for anyone who might want to use it. I'll be staying with Krypton for now.
