Here's another MOD of the original ConCast Skin I created in my spare time and pretty much started out as a hobby for my own personal skin preference. It's my first attempt at trying to do anything like this, but happy to share here if anybody is interested. UK and US channel icons will also be available to download to donors:-
[/img]
Still have a couple of niggling issues to try and fix.
Full credit goes to Redkiller223 for the original skin concept idea..
nice the more options we have the better. and your logo's are awesome.
(2014-05-02, 00:54)frieten Wrote: [ -> ] (2014-05-02, 00:12)omnicroncs Wrote: [ -> ]Luna, we applaud your patience, please forgive those of us who forget that we are not paying you a salary to develop for us, but are rather leeching hours of pleasure and relaxation from your hard work. We appreciate you and your work.
Except some of us do pay
...some of us do give a little something
(2014-05-02, 21:59)muttley79 Wrote: [ -> ] (2014-05-02, 21:08)scilz Wrote: [ -> ]look at the channel name then name the .png the exact same thing you used to have to put _c after the name but i think luna changed that recently.
Wow thanks! it worked. Is that documented anywhere?
Luna posted it a few pages back
(2014-05-03, 05:41)scilz Wrote: [ -> ]nice the more options we have the better. and your logo's are awesome.
I second that, can't wait to see the finished product.
I found my problem!
it's look like a bug in pseudotv live.
the problem is the language.
if xbmc language is english, everyhing is working, becouse it's searching for the pvr in the path
pvr://channels/tv/All TV channels/...
but if you change xbmc language (for Hebrew in my case) then the path to the pvr is changing as well. in my case it's
pvr://channels/tv/כל ערוצי הטלוויזיה
the pseudotv-live ignore the new path and searching the pvr in the english path (and thats why it's not working)
I need to reformat the tv pc now and return to 14.04.
please fix this bug.
thanks
(2014-05-03, 08:42)SOME1 Wrote: [ -> ]I found my problem!
thanks
I discover one more bug. (I think..)
if the channel name is in Hebrew, the pseudotv-live font (or encoding) doesn't read this correctly (and that's why the xmltv for the epg is not working well and instead the hebrew name I have random letters.
thanks for your help.
edit - here is a screenshot. the channel name is
ערוץ 10
in xbm pvr it is look correct. in pseudotv live it's \u05e2\u05e8\u05d5\u05e5 10
Long time listener, first time caller.
Is there any way to suppress the "YouTube Opening Stream" dialogue? I'm close to getting everything working the way I'd like it to, and I'd love to keep the dialogue popups to a minimum.
Thanks in advance.
(2014-05-02, 10:42)leedemon Wrote: [ -> ]Hi
I updated to the new version but when I use autotune I have black screen. When I press buttons I can hear skins sounds.
I copied log for you
TY
http://pastebin.com/embed_iframe.php?i=DQKDLDMF
I have the same problem and I didn't update I just manually extracted the addon on XBMC Gotham RC1 and executed PseudoTV Live from Programs. Here is my log:
http://pastie.org/9136985
EDIT: Logs points to
Error Contents: global name 'Donor_Downloaded'. Does this mean it will work if I donate?
::Attention::
Users using USTVnow. their rtmp server seems to be down. You will need to change to rstp from within USTVnows plugin settings.
I am expeiencing a wierd behavior, could be a bug or could be that I misconfigured something:
When watching a channel, and then switching to another one, then returning to the original channel - the video on the original channel is restarted, and not keeping its original (or running) position. I would expect the original channel to 'keep running' while i'm on the other channel, and then continue + the time spent on the other channel,
Am I getting it wrong? maybe this is an expected behavior
Any input will help
do you have the channel set to pause in advanced settings?
Most likely not. I haven't touched advanced settings. All of my channels are autotuned from local media.
What should i do?
(2014-05-03, 19:06)Entheogen Wrote: [ -> ] (2014-05-02, 10:42)leedemon Wrote: [ -> ]Hi
TY
I have the same problem and I didn't update I just manually extracted the addon on XBMC Gotham RC1 and executed PseudoTV Live from Programs. Here is my log: http://pastie.org/9136985
EDIT: Logs points to Error Contents: global name 'Donor_Downloaded'. Does this mean it will work if I donate?
Fix included in next update
(2014-05-03, 13:12)deletedpenguin Wrote: [ -> ]Long time listener, first time caller.
Thanks in advance.
The individual plugins generate those boxes, no way around them.
One more languages problem:
Similar to what the user SOME1 already posted, I've tried to run a channel using playlist with all items scrape in Hebrew and Pseudo just ignore that channel. Only after re-scrape all my shows to use English it worked.
TY!
I managed to get it working eventually anyway, I just created some channels manually and they work. It's just the tv shows dont show the the name properly, movies are fine though they show all informations. I get logs next time I have chance.
::Update::
Preview of the new skinnable "Coming Up Next" Overlay
There will be an option in settings to use the "Classic" notification if you prefer it.
Taking suggestions for what information other then title you would like to see displayed.
