(2014-06-03, 14:50)Lunatixz Wrote: [ -> ] (2014-06-03, 14:43)Dec64 Wrote: [ -> ] (2014-06-03, 14:41)Lunatixz Wrote: [ -> ]Anyone experiencing loading problems with v.0.4.2?
My dev machine loads latest fine, so it was released... But for the life of me I can't get it to load on my HTPC!
Before I rip my htpc apart, Im wondering if this is a global problem....
Updated last night, did a "force channel refresh" on first boot of 0.4.2. It locked up on the 3rd channel. Rebooted this morning and currently doing another channel force refresh. Not locked up this time but i think it's taking longer then usual.
I can't even get it to load on my HTPC, doesn't launch at all!, it's the oddest thing...
took a few attempts - I went in and did a force refresh and reset to defaults. can't get the window patcher to function but everything else looks good.
next step chan logos
It'll refresh for me, but very slow. If I try to cancel, I have to force quit.
Glad its starting for some of you, I'm thinking I have a bad module somewhere... I have to try a clean install.
As for slow refresh, dynamic artwork extends to some plugins and all livetv... so parsing can be longer, but the cache will speed up channel loads next time you run...
Also performance in general will get faster the longer you go without a force channel reset... which clears the cache.
It doesn't load for me either. In fact It doesn't read my XMLTV file anymore. I checked in file manager and the path is still valid and I can see the XMLTV file but for some reason ever since updating to 4.2 it no longer reads it and just hangs at 75%
(2014-06-03, 16:14)ARYEZ Wrote: [ -> ] (2014-06-03, 14:41)Lunatixz Wrote: [ -> ]Anyone experiencing loading problems with v.0.4.2?
if it's getting to the point of reading an xmltv file.. then it's not the same... I said that my problem was it won't load at all! meaning you click icon, nothing happens....
sounds to me like you didn't force channel reset, as required
Only problem I'm having is with the Youtube Playlist Network channels not showing up at all from the community lists.
It happened on the last version (0.4.1d) but I thought it might have been my setup so I did a fresh install (complete XBMC install) with 0.4.2 but the problems still there?
Is anyone else having this or is it my setup? lol
(2014-06-03, 16:38)Lunatixz Wrote: [ -> ] (2014-06-03, 16:14)ARYEZ Wrote: [ -> ] (2014-06-03, 14:41)Lunatixz Wrote: [ -> ]Anyone experiencing loading problems with v.0.4.2?
Haha well I'll force reset again when I get home just to be on the safe buuuut I'm pretty sure I did that already lol.
Btw is there any issue with PTVL reading an XMLTV file off a networked machine on openelec that you've heard of?
after pseudotv scans for my USTVnow channels I get a black screen and it seems as if xbmc has frozen. I am using your USTVnow add-on and have configured it and logged in. The add-on works but doesn't seem to work in pseudotv.
(2014-06-03, 16:57)ARYEZ Wrote: [ -> ] (2014-06-03, 16:38)Lunatixz Wrote: [ -> ] (2014-06-03, 16:14)ARYEZ Wrote: [ -> ]It doesn't load for me either. In fact It doesn't read my XMLTV file anymore. I checked in file manager and the path is still valid and I can see the XMLTV file but for some reason ever since updating to 4.2 it no longer reads it and just hangs at 75%
shouldn't be, I run off smb and it works...
(2014-06-03, 17:03)robbyyyyyy Wrote: [ -> ]after pseudotv scans for my USTVnow channels I get a black screen and it seems as if xbmc has frozen. I am using your USTVnow add-on and have configured it and logged in. The add-on works but doesn't seem to work in pseudotv.
log?
(2014-06-03, 16:57)JohnnyParanoia Wrote: [ -> ]Only problem I'm having is with the Youtube Playlist Network channels not showing up at all from the community lists.
I didn't add playlist network yet.. only channel and user network
Lunatixz Wrote:I didn't add playlist network yet.. only channel and user network
Good to hear, I thought I was screwing it up my end lol
(2014-06-03, 17:41)tromy Wrote: [ -> ]After many attempts PLTV starts to load but freezes(have to focre exit xbmc) when trying to create channels from custom playlists.
Here is the log: https://www.dropbox.com/s/hsd3iuecnrywhr3/xbmc.old.log
fix in next update, thanks for log... sorry about the problem...
at least you can run pseudotv, lol... my htpc refuses to even load it...
btw you should run xbmc with administrator rights and disable aero for better performance....
18:28:34 T:3696 NOTICE: Starting XBMC (13.0 Git:20140504-0d1d803). Platform: x86 Win32 32-bit
18:28:34 T:3696 NOTICE: Using Release XBMC x32 build, compiled May 4 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
18:28:34 T:3696 NOTICE: Running on Windows 7 SP1 64-bit, build 7601
18:28:34 T:3696 NOTICE: Host CPU: Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz, 4 cores available
18:28:34 T:3696 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
18:28:34 T:3696 NOTICE: Running with restricted rights
11:49:44 T:2408 NOTICE: Aero is enabled
I apologize if this is answered elsewhere in this thread; I read as much as I could and searched, but could easily have missed it. I noticed that the EPG works great until I scroll up or down into an area containing YouTube channels--at that point the guide comes to a crawl--10 to 15 seconds to update per up or down click. It's barely useable. If I hit the up and down arrows on the channels themselves without using the guide, it might take a second or two to switch channels, but nothing like with the guide. The computer I'm using isn't stellar, that might be the problem. Is this expected? If not, any ideas on what's wrong? If so, is there a way to just block out the channels guide information? I don't care what's on the channels--I'd like to just be able to flip to them and see whatever happens to be playing like when I hit the up or down arrow without the guide.
have you tried working with NibleTV. They have a few free channels to watch and they also offer a subscription. It would be great to incorporate that into pseudotv live
(2014-06-03, 19:35)komdori Wrote: [ -> ]I apologize if this is answered elsewhere in this thread; I read as much as I could and searched, but could easily have missed it. I noticed that the EPG works great until I scroll up or down into an area containing YouTube channels--at that point the guide comes to a crawl--10 to 15 seconds to update per up or down click. It's barely useable. If I hit the up and down arrows on the channels themselves without using the guide, it might take a second or two to switch channels, but nothing like with the guide. The computer I'm using isn't stellar, that might be the problem. Is this expected? If not, any ideas on what's wrong? If so, is there a way to just block out the channels guide information? I don't care what's on the channels--I'd like to just be able to flip to them and see whatever happens to be playing like when I hit the up or down arrow without the guide.
Try disabling "hide short videos"
let me know if that helps, also try limiting the amount of shows...
I'll add a better limit to youtube autotune channels to avoid problems
