cult
What about nesting your channels that you want as bumpers? I've not tried it but interleaving a channel that is interleaved. So bumper channel 100 is channel 2,4,5. Then channel 100 is interleaved as bumper.
(2014-08-17, 03:12)Jadiusatreu Wrote: [ -> ]@cult
Thats actually a great idea - I'm not sure why I didn't think of that earlier... Thanks!
(2014-08-17, 03:33)cult Wrote: [ -> ] (2014-08-17, 03:12)Jadiusatreu Wrote: [ -> ]@cult
cult
That's exactly what I do. I have a channel that's made up of about 15 different interleaved channels from various sources. I then interleave that one bumper channel into all my regular channels and have it set to play three videos between each show. It's really a great way to get your bumpers fine-tuned exactly the way you want.
Still having issue with artwork showing in EPG. Anybody have an idea where I should start? Also, it is required that I changed the advancedsettings.xml? Am I correct that it will use 3x more RAM? I actually have never looked for it, or created it.
(2014-08-17, 18:23)Jadiusatreu Wrote: [ -> ]Still having issue with artwork showing in EPG. Anybody have an idea where I should start? Also, it is required that I changed the advancedsettings.xml? Am I correct that it will use 3x more RAM? I actually have never looked for it, or created it.
Changing advancedsettings.xml isn't required but it definitely helps.
As far as your artwork problem goes the simplest answer is usually a fresh install of the master branch of PTVL, but also I have found that trying different skins can sometimes at least expose the nature of the problem. For instance my skin (Aurora) is based off of landscape art, whereas some of the other skins are based off of fanart. So if you were using Aurora and didn't have landscapes for your media (some people don't) then you would not see the artwork on the EPG.
Might be worth a try.
I have been using confluence, and everything else default. I've not had an issue before. What's weird is after the fresh install I can go watch Game of Thrones and when I open the EPG it shows the image for a second and then it goes blank. I've tried as you suggested, reinstall Pseudotv live, changed skin to Aeon Nox, still the same issue. (My logs on a previous post
https://docs.google.com/document/d/1tNJO...sp=sharing)
On a different note, I assume I need to create advancedsettings.xml, where does that need to be placed?
EDIT: Tried a different skin Classic PTV will show some art for the episode if I simply change the channel, but will still not show if I have the EPG pulled up. Anybody?
EDIT 2: Logs from today
http://xbmclogs.com/show.php?id=271190
Any help please.
I've been at this for awhile. Still no artwork showing in EPG. Been trying to read logs, I have no idea what I'm looking at but it appears it's looking for a file fanart.jpg and then it can't find it? I have all the dependencies and have let them run. Still no worky.
If anybody can check my logs (posted above) I would really appreciate the solid. Thanks in advance.
(2014-08-21, 02:11)Jadiusatreu Wrote: [ -> ]Any help please.
Do you have in every (movie, tv show) folder artwork?You must have landscape.jpg,poster.jpg,logo.png
Default skin uses poster,landscape and logo
PLTV skin uses landscape
Select skin,enable dynamic artwork(inc.service) and you must be fine
tromy, is mymusictv working for you with latest development branch? Can you force channel reset and let me know if you experience Unicode issues? Thanks
Can someone pm me a link to there epg7.db that sole uses OTA/ATSC guide data, no xmltv data sources.
(2014-08-21, 19:25)Lunatixz Wrote: [ -> ]@tromy, is mymusictv working for you with latest development branch? Can you force channel reset and let me know if you experience Unicode issues? Thanks
Tested with autotune and it works great
Nice work Lunatixz!
The only "issue" is that my music tv channels don't use the new " you tube alpha" plugin,like the other "you tube" channels do.
Also great work with the you tube artwork!
(2014-08-21, 22:00)tromy Wrote: [ -> ] (2014-08-21, 19:25)Lunatixz Wrote: [ -> ]@tromy, is mymusictv working for you with latest development branch? Can you force channel reset and let me know if you experience Unicode issues? Thanks
Tested with autotune and it works great Nice work Lunatixz!
Yeah, mymusic handles playback so it would need to change it's code to allow for the new youtube plugin.
Let me know if you have unicode errors or missing data... glad you like the youtube artwork.
