(2014-09-07, 02:27)Lunatixz Wrote: [ -> ]@tromy I see you gave me the nfo for the movie, can you give me your exact file name for it as well... thanks
(2014-09-07, 02:22)xavier.ba Wrote: [ -> ]In autotune There should be a option where you can skip updating a certain channel if it takes too long, for example one of the reasons my sistem took so long updating was bad addons , like cnet podcast etc, just froze on them while updating and I had to restart and disable the addon,there are plenty like that
nobody makes you select the auto tuning options... just ignore the ones you know don't work for you.
Any decently powered system should breeze through autotune, just don't go crazy selecting everything if you are running a low power system.
I know!!
Just an idea!!it would make it more user friendly!! 70% of users are newbies
I was wondering how long does it take to get donors feature I'm really anxious to try out I sent pm couple days ago. This addon is wonderful just thought iI'd ask when its avail. Thankyou
Using aftv and a brand new mac, I don't think those are low powered systems, I'm having the same problem in all of them,
(2014-09-07, 03:24)xavier.ba Wrote: [ -> ] (2014-09-07, 02:27)Lunatixz Wrote: [ -> ]@tromy I see you gave me the nfo for the movie, can you give me your exact file name for it as well... thanks
So talk to the dev and or disable the add-ons that are obviously causing problems.
(2014-09-07, 03:57)bry- Wrote: [ -> ] (2014-09-07, 03:24)xavier.ba Wrote: [ -> ] (2014-09-07, 02:27)Lunatixz Wrote: [ -> ]@tromy I see you gave me the nfo for the movie, can you give me your exact file name for it as well... thanks
Yeah , I just disable them, but I'm sure that's the reason so many newbies have so many problems with this addon, I mean it's the best but some if some body contribute to the auto tune with an addon or channel in the community list that does not work it creates problems
Hi does any body no how to parse the youtubeonfire addon useing the new chl type 15
as the method below no longer works with the new update.
<setting id="Channel_47_type" value="15" />
<setting id="Channel_47_1" value="plugin://plugin.video.youtubeonfire/Knowledge/Nature" />
<setting id="Channel_47_2" value="" />
<setting id="Channel_47_3" value="" />
<setting id="Channel_47_4" value="0" />
<setting id="Channel_47_rulecount" value="1" />
<setting id="Channel_47_rule_1_id" value="1" />
<setting id="Channel_47_rule_1_opt_1" value="Nature" />
<setting id="Channel_47_changed" value="False" />
Thank you,
This is the best addon for xbmc, my wife loves that fact that she can now watch all here favourite shows from within one program. bye bye cable..
(2014-09-06, 18:45)Lunatixz Wrote: [ -> ] (2014-09-05, 17:15)Lunatixz Wrote: [ -> ]Donor login giveaway!!
Starting tonight at midnight EST - Ending Monday Morning EST.
Offer exclusive to community list members,
first 5 users to post 10 NEW , WORKING (valid paths, minor syntax mistakes allowed) and UNIQUE Plugin or Playon configurations will receive donor logins.
posts must be made at the community list, never posted before? readme
after posting your 10 configurations please PM here, after I validate the info you will be sent your logins
New community members will be accepted up till contest start, Good Luck!
Format changes to chtypes 15 and new playon 16 can be found here:
http://forum.xbmc.org/showthread.php?tid...pid1785805
Playon will allow Hulu, Amazon, Netflix to integrate easily with PseudoTV Live!
If you are interested in signing up for playon services please use my link below or in post 1,
For a limited time sign up using my link below or in post 1 and receive a free google chromecast with the purchase of playon + playon later lifetime
aftv is low powered... its an arm processor, don't get me wrong it's fast for what it is... but it's no intel core duo... which I think is a reasonable minimum for xbmc and ptvl
(2014-09-07, 04:08)xavier.ba Wrote: [ -> ] (2014-09-07, 03:57)bry- Wrote: [ -> ] (2014-09-07, 03:24)xavier.ba Wrote: [ -> ]Using aftv and a brand new mac, I don't think those are low powered systems, I'm having the same problem in all of them,
How? where is the problem? all it takes is that user to be a part of the community and remove the offending plugin!
BTW just because it parses slow for you doesn't mean its slow for others. I think its best for you to avoid autotune and manually build channels that you know work for you. There is no magic code I could write that will tell PTVL that a certain plugin won't work well for your particular setup...
(2014-09-07, 04:45)pch43 Wrote: [ -> ]Hi does any body no how to parse the youtubeonfire addon useing the new chl type 15
Thank you,
It's not supported, You can ask Kickin to make the changes that are required...
BTW I also want to state that even when I give away something for free, users still won't contribute to the community list... further proof that it's a dead feature... future is looking grim...
(2014-09-07, 04:51)Lunatixz Wrote: [ -> ] (2014-09-06, 18:45)Lunatixz Wrote: [ -> ] (2014-09-05, 17:15)Lunatixz Wrote: [ -> ]Donor login giveaway!!
(2014-09-07, 04:08)xavier.ba Wrote: [ -> ] (2014-09-07, 03:57)bry- Wrote: [ -> ]So talk to the dev and or disable the add-ons that are obviously causing problems.
Thank you,
Then this only is for high powered systems?? Then everybody that has a box should not even try this addon?? Great!! Not for android powered systems or boxes!! Read first
Is anyone experiencing problems switching channels that has an hdstream to a normal channel (not live). for me it keeps freezing.
mrpcpro
(2014-09-07, 05:16)xavier.ba Wrote: [ -> ]Then this only is for high powered systems?? Then everybody that has a box should not even try this addon?? Great!! Not for android powered systems or boxes!! Read first
That's not what I'm saying... I'm saying if you expect all features to run without a hitch... provide some processing power!
I run PTVL on AFTV and rPI without a hitch, then again I reasonably understand what to expect out of PTVL on those low power systems, so I don't go overboard.
I love the way it run on my htpc powered i3 system I wish I could contribute with info
Just learnt about this addon a couple of weeks ago trying to get upto speed with it
Everything I read has been useful. just need a little time to master
And I will help with testing. I see my self stuck to this addon for a long time
I just subscribed to playon. I will stay up all night testing on PseudoTV Live. they are giving away free Chromecast for subscribing
(2014-09-07, 06:52)lozad Wrote: [ -> ]I just subscribed to playon. I will stay up all night testing on PseudoTV Live. they are giving away free Chromecast for subscribing
Hope you used my playon link
Yes sir! and also donated to a good cause
(2014-09-07, 07:16)lozad Wrote: [ -> ]Yes sir! and also donated to a good cause
Thanks I appreciate the support
