(2015-01-21, 20:02)bry- Wrote: [ -> ] (2015-01-21, 19:49)FALAFELOLOGIST Wrote: [ -> ]Second Problem: I love that Titanium (I think that's what it's called?) skin that the guy posted a few pages back. LOVE IT. But ever since the update it no longer works. I can only use the PTVL live skin. It just freezes (image below on what it looks like when it freezes) any ideas?
Link: http://i.imgur.com/1sGOcLm.jpg
Greatly appreciate any help!!!
https://twitter.com/PseudoTV_Live/status...2185483264
Ah great! That solves that. I think on page 529 my third question was answered. Now I just need that first problem I have!
(2015-01-21, 19:49)FALAFELOLOGIST Wrote: [ -> ]First problem, these notifications keep popping up. For movies I don't even have! Why does it keep doing this? 75% of my channels are local and I have no streaming movie channels. How can I make these go away forever.
Link: http://i.imgur.com/B0UMMvk.png
That's a message from the Buggalo script. It's letting you know something didn't work right, you can either send the error straight to Luna or ignore it. The movie title is just 'flavour', it doesn't mean that that is what the error landed on. It's just a random movie title.
But it keeps happening all the time! The same 5 movies, I hit ignore, and then thirty minutes later they pop up again. It is very annoying. Will sending the error report make them go away for good?
(2015-01-21, 20:25)FALAFELOLOGIST Wrote: [ -> ]But it keeps happening all the time! The same 5 movies, I hit ignore, and then thirty minutes later they pop up again. It is very annoying. Will sending the error report make them go away for good?
Do you have your channels logos shared over smb?If so,put them in a local folder and see if that fixes it.
....and "that titanium" skin is called "Titian"
Hahaha ooops! And no I do not use any channel logos. Just basic text. No channel bug.
(2015-01-18, 02:51)aptalca Wrote: [ -> ]Hi Lunatix,
A few of us were talking about issues with local artwork not being recognized and also not being retrieved from online sources for movies a few pages back. I am not sure if you saw those.
Here is a log: https://drive.google.com/file/d/0B6Pdr6Z...sp=sharing
My issues are that:
1) Local media and art reside on a samba shared nas, but although tv show artwork is retrieved from there movie artwork is not
2) artwork spooler is taking forever everytime there is background loading (up to 30 min)
3) at the end, the artwork spooler doesn't find any artwork for any of the movies
4) navigating through the epg is painfully slow, it takes a few seconds to move to the next item every time
In the log, you'll see some background loading, a really long spooling session and then me trying to navigate through the epg
I have several Setups My HTPC used to Run great using PTVL because the Media was stored on the same machine. Then went out and got a couple of Android STB's took all my media and moved it to a NAS made by WD cloud and with using smb my HTPC running W7 it scans all the channels in its very slow and when changing channels its very slow and all my Android STB's get only 3 to 8 channels depending what mood PTVL is in. So I would conclude using a Network Drive under SMB PTVL doesn't like it.
Oh and my Ethernet is 1000 speed
(2015-01-21, 22:47)Rickt1962 Wrote: [ -> ] (2015-01-18, 02:51)aptalca Wrote: [ -> ]Hi Lunatix,
My issues are that:
Your conclusion is incorrect, All my media is stored through Samba and works great with PTVL.
I Cannot possibly test every Android & NAS device on the market, but I can assume with the little information you have provide me that:
A) Your HTPC devices are under powered for running PTVL or at least its current configuration.
B) Your NAS isn't up to par to run as a media server.
Having Gigabit hardware and actually running Gigabit are two different things, Either way the issues you're seeing aren't related to PTVL so much as your hardware and network.
(2015-01-21, 20:11)RayW1986 Wrote: [ -> ][quote='FALAFELOLOGIST' pid='1899710' dateline='1421862592']
Click the show error report button. You should get an idea what is causing the error there and perhaps post it if possible.
0.5.7.f
When creating multiple channels that are set to play from a certain directory, the channels load as identical duplicates instead of unique channels.
Exact same episodes play on channels 1 and 2, with exact same start times.
How do I get to the "channel guide?" When I open PseudoTV Live it defaults to the same video. I am running it currently on my stock Nexus 6.The only thing I can do is hit the back button to exit PTVL.
Ehubb read forum rules and stance on piracy add-ons.
(2015-01-21, 19:49)FALAFELOLOGIST Wrote: [ -> ]Third Problem: XBMC isn't very good at picking up documentaries so I just throw them in directories. All previous versions had the directories randomized. Now every time I do a "channel reset" it has all directories start at the same sport every time with identical channel lists. How do I go back to the randomization?
Having exactly the same issue with directory channels, looks like the Advanced Rule to not show the same show more then X times in a row (forgot the actual name off top of head) doesn't apply with the latest 0.5.7f update. It just puts the shows alphabetically in the EPG as it reads it. I rolled back, same settings2.xml and it works again.
(2015-01-22, 21:57)Indy_star Wrote: [ -> ] (2015-01-21, 19:49)FALAFELOLOGIST Wrote: [ -> ]Third Problem: XBMC isn't very good at picking up documentaries so I just throw them in directories. All previous versions had the directories randomized. Now every time I do a "channel reset" it has all directories start at the same sport every time with identical channel lists. How do I go back to the randomization?
Why can't you use the force random rule?
