Yea i still have no luck logging in the donor exclusiveq. I would like to just put a few of my live channels from my favorites or super favorites in ptv. I dont know if thats possible or not im pretty new at this so if someone can help me out would really appreciate it thanks.
(2015-02-03, 01:35)Bbold Wrote: [ -> ]Yea i still have no luck logging in the donor exclusiveq. I would like to just put a few of my live channels from my favorites or super favorites in ptv. I dont know if thats possible or not im pretty new at this so if someone can help me out would really appreciate it thanks.
In the first two posts there are examples of how to add Super Favourite channels, including an auto-tune example.
Yea, i tried that maybe I have the format wrong because every time ptv gets to the load superfavorite its freezes but when i take super favor off ptv loads fine.
Super Favorites
\PseudoTV_Live
\Channel_1
tromy I'm wanting to use your skin, I think it looks great, however every time i try to load with your skin it gets stuck here:
Checking to see if there is anything you could recommend
(2015-02-03, 02:56)Bbold Wrote: [ -> ]Yea, i tried that maybe I have the format wrong because every time ptv gets to the load superfavorite its freezes but when i take super favor off ptv loads fine.
Super Favorites
\PseudoTV_Live
\Channel_1
Not everything works with PTVL. If you're not having luck, it may be worth trying a direct plugin type. But if it doesnt work as a Super Fave, it shouldnt work as a direct plugin.
If you want some real help, you have to post a log.
Hi Everyone
I have been using PseudoTV Live for about a month. I have PseudoTV Live running on a Mac with Yosemite and Amazon Fire TV. I am running Kodi 14.1 and have PseudoTV Live 0.57f version. I have USTVnow running exclusively on PseudoTV Live. One of the problems that I am running into is that the channels Fox News, Discovery, National Geographic, Cartoon Network, Comedy Central and Animal Planet do not show any EPG data. Is this still a know issue or do I need to take a look at the settings2.xml? If I need to take a look at it, what is the file location on my Mac? I found this directory path Library/Application Support/XBMC/Userdata/addon_data/script.pseudotv on another forum post but this does not apply to Kodi. Can someone provide with with the navigation path?
Thanks for the help
(2015-02-03, 04:23)peglegtv Wrote: [ -> ]@tromy I'm wanting to use your skin, I think it looks great, however every time i try to load with your skin it gets stuck here:
I'm waiting for Lunatixz stable release in order to update custom skin"Titian" because he said there will be manu changes in PLTV overlay:
but if you or anyone else want to use it with the dev version 0.5.7f I can post a link with a fixed version that works fine on my end.
I just went to the first page to look at the YouTube example for the settings2.xml file, and all the examples are gone. How comes you removed them Luna?
(2015-02-03, 06:53)jackhog Wrote: [ -> ]Hi Everyone
Thanks for the help
Should be the same except with kodi instead of xbmc in the file path. Also script should say live I think as well. I'd take a look at settings2 to make sure that they are set up as livetv chtype and that they direct to the proper xmltv file. Also check the in-app PTVL settings to make sure xmltv is enabled.
(2015-02-03, 13:02)RayW1986 Wrote: [ -> ]I just went to the first page to look at the YouTube example for the settings2.xml file, and all the examples are gone. How comes you removed them Luna?
If I were to guess I would say a) it was a mistake, b) he was annoyed by the amount or people who don't read them and instead ask in the thread how to make such and such channels, or c) the new in-app channel configuration is really close to being released. Hopefully the latter.
I know that Luna's always said that when PTVL is finished he wants it to be so that no-one ever even opens their settings2 file.
(2015-02-03, 15:46)azrael17 Wrote: [ -> ] (2015-02-03, 13:02)RayW1986 Wrote: [ -> ]I just went to the first page to look at the YouTube example for the settings2.xml file, and all the examples are gone. How comes you removed them Luna?
Ah right. I'm so used to using the settings2 file in Notepad++ that I never even bothered with the channel manager, but I guess I'll go download it now. Thanks mate.
(2015-02-03, 15:53)RayW1986 Wrote: [ -> ] (2015-02-03, 15:46)azrael17 Wrote: [ -> ] (2015-02-03, 13:02)RayW1986 Wrote: [ -> ]I just went to the first page to look at the YouTube example for the settings2.xml file, and all the examples are gone. How comes you removed them Luna?
Not the standalone one. Based on Luna's tweets I believe there are changes coming to the channel configuration tool within the PTVL settings. Right now it is used only for local content, but soon it should be able to create all chtypes.
https://www.youtube.com/watch?v=35_C0GiH...eudoTVLive
https://twitter.com/PseudoTV_Live
"Progress on @PseudoTV_Live in-app channel manager is coming along nicely, say goodbye to manually editing settings2.xml!"
(2015-02-03, 15:57)azrael17 Wrote: [ -> ] (2015-02-03, 15:53)RayW1986 Wrote: [ -> ] (2015-02-03, 15:46)azrael17 Wrote: [ -> ]If I were to guess I would say a) it was a mistake, b) he was annoyed by the amount or people who don't read them and instead ask in the thread how to make such and such channels, or c) the new in-app channel configuration is really close to being released. Hopefully the latter.
<blockquote class="twitter-tweet" lang="en"><p>Showing off <a href="https://twitter.com/PseudoTV_Live">@PseudoTV_Live</a> Plugin Channel Configurations:
<a href="https://t.co/4AV8vDkfPG">https://t.co/4AV8vDkfPG</a></p>— Lunatixz (@PseudoTV_Live) <a href="https://twitter.com/PseudoTV_Live/status/558760905769754624">January 23, 2015</a></blockquote>
<script async src="//platform.twitter.com/widgets.js" charset="utf-8"></script>
Yeah I just went to his Twitter, that looks excellent. Has me excited for what's to come.
When its going to be released?
