Hi!
Seems like am having issues since...well could be kodi 14.1 or PSeudoTV 0.5.8b, but it seems to be really killing Kodi. I have random hangs now in kodi, and when i try to start ptv, its REALLY slow and takes like 10 min to even start and it is really really slow background loading the channels now. I have 2 instances running on very identical hardware, just different OS setup (one running kodiuntu is running fine, where the problem one is lubuntu)
The log is freaking huge. Hope it has everything!
http://xbmclogs.com/show.php?id=421418
Cheers!
EDIT: its been running 15 min and still only loaded one channel.
(2015-02-10, 02:37)wyild1 Wrote: [ -> ]Hi!
The log is freaking huge. Hope it has everything! http://xbmclogs.com/show.php?id=421418
Cheers!
You've got some major issues... Most notable is that you are not using channel sharing as it was designed... so don't use nfs shares for your cache folder!
INFO: CNFSFile::Open: Unable to open file : 'Media/htpcsync/PTL/cache/channel_591.m3u' error : 'open call failed with "NFS: Lookup of //htpcsync failed with NFS3ERR_NOENT(-2)"'
(2015-02-10, 02:44)Lunatixz Wrote: [ -> ] (2015-02-10, 02:37)wyild1 Wrote: [ -> ]Hi!
Cheers!
You know what....after i let it run a while it seemed to improve. i quit PTL and started it again and it is performing how it should.
I was looking into the sharing as you mention. I just point each instance to an NFS share like nfs://server/htpcsync. I also mount the share under /Media/htpysync. Should i just point it to the mount point instead?
Thanks for your quick help!
Cheers!
Hey luna, I'm getting dependencies not met is there a new dependency for PTVL, And this happened after closing PTVL to update to 0.5.8c
(2015-02-10, 04:55)Marshall Wrote: [ -> ] (2015-02-10, 04:41)Dec64 Wrote: [ -> ] (2015-02-10, 04:02)bigsteel99 Wrote: [ -> ]Hey luna, I'm getting dependencies not met is there a new dependency for PTVL, And this happened after closing PTVL to update to 0.5.8c
Same here.
Same
Addon script.pseudotv.live requires plugin.program.super.favourites version 3.2.1 which is not available
@PseudoTV_Live updated to version v.0.5.8d
I thought SuperFavs was part of the official repo... dependencies are fixed...
Constructive feedback on the new in-app channel manager would be appreciated.
just looking at the changes.
plugin.video.ustvnow is now required (version 9.9.9)
script.artwork.downloader is now required (version 1.9.4)
plugin.program.super.favourites is now required (version 3.2.1)
script.extendedinfo is now required (version 1.9.4)
script.globalsearch is now required (version 1.9.4)
script.tv.show.next.aired is now required (version 1.9.4)
and maybe
script.module.addon.common (0.9.1)
Seems he changed some from being optional to being specificly required.
(2015-02-10, 05:02)Lunatixz Wrote: [ -> ]@PseudoTV_Live updated to version v.0.5.8d
Works fine now. Checking it out
The new search feature is AWESOME. No idea where you came up with the idea, but now that it's there, it's a can't live without it item.
I really like the entire On Demand idea as well. It adds to that digital sat/cable feel like it should. The search seems quick and pretty robust. I'm using MySQL for my library.
It's a tad bit wonky once you switch to an "On Demand" movie/show etc because your EPG will still show the line item you were on but the description shows the updated details, but all and all you can totally work with it. Now I never need to shut PTVL down.
hi.. for some reason its not creating a channel 4 (live tv from a upnp hdhomerun prime)... here is the logs... any ideas.. i pulled that info right from my xmltv file..
http://pastebin.com/pcLvZLjs
(2015-02-10, 05:30)gman3042 Wrote: [ -> ]hi.. for some reason its not creating a channel 4 (live tv from a upnp hdhomerun prime)... here is the logs... any ideas.. i pulled that info right from my xmltv file..
Try going into the PTVL settings (under the Autotune tab) and make sure you have your Kodi PVR setting option set to xmltv. I'm assuming you had this working at one point.
You should update to the latest version 0.5.8d if you haven't already.
Can someone please in the simplest form explain to me how to add live tv channel in Channel Configuration. Having a hard time with this im new I read a whole lot of information half of which i do not understand. I Provided a log . Jus trying to add 2 or 3 live tv channels thats it. Would appreciate the help thanks
(2015-02-10, 02:37)Lunatixz Wrote: [ -> ] (2015-02-10, 01:48)Marshall Wrote: [ -> ]I have a machine (Windows) that the video window quit working on. The skin file is correct etc. Now that the patching option in the settings is gone I'm wondering if anyone can direct me to what exactly that option used to do so I can dig around and see what's broken. I'm guessing it changed something more than just the skin file.
it should automatically apply itself... anyone else having problems?
Reinstalled Kodi etc problem solved.
