(2015-02-28, 10:56)Lunatixz Wrote: [ -> ] (2015-02-28, 10:50)hasamba Wrote: [ -> ] (2015-02-27, 19:36)tromy Wrote: [ -> ]I use one plugin called "Hellenic TV" by Lambda.
The plugin contains folders,most of them with greek names and some with english names.
configuration with english names,works fine
<setting id="Channel_3_type" value="15" />
<setting id="Channel_3_rulecount" value="1" />
<setting id="Channel_3_rule_1_id" value="1" />
<setting id="Channel_3_rule_1_opt_1" value="Hellenic.Tv 1821..." />
<setting id="Channel_3_1" value="plugin://plugin.video.hellenic.tv/Documentaries/1821..." />
<setting id="Channel_3_2" value="" />
<setting id="Channel_3_3" value="25" />
<setting id="Channel_3_4" value="Default" />
<setting id="Channel_3_changed" value="False" />
<setting id="Channel_3_time" value="256" />
configuration with a greek name at the end can't be parsed
<setting id="Channel_1_type" value="15" />
<setting id="Channel_1_rulecount" value="1" />
<setting id="Channel_1_rule_1_id" value="1" />
<setting id="Channel_1_rule_1_opt_1" value="Hellenic.Tv Κάτω Παρτάλι" />
<setting id="Channel_1_1" value="plugin://plugin.video.hellenic.tv/Networks/Mega/Κάτω Παρτάλι" />
<setting id="Channel_1_2" value="" />
<setting id="Channel_1_3" value="25" />
<setting id="Channel_1_4" value="Default" />
<setting id="Channel_1_changed" value="True" />
I have the same problem with hebrew, but it never worked before.
I have a script that deletes the hebrew translation from a certain plugin folder whenever it updates,
My problem earlier was that i didnt changed the path after switching from xbmc to kodi.
plugin and configuration?
about the chtype 15, the plugin is banned from this thread, but i think that any plugin that have translation will not work...
about chtype 17, here is config for example that doesnt work:
<setting id="Channel_522_type" value="17" />
<setting id="Channel_522_time" value="344329" />
<setting id="Channel_522_1" value="Channel" />
<setting id="Channel_522_2" value="20" />
<setting id="Channel_522_3" value="TV" />
<setting id="Channel_522_4" value="0" />
<setting id="Channel_522_rulecount" value="1" />
<setting id="Channel_522_rule_1_id" value="1" />
<setting id="Channel_522_rule_1_opt_1" value="Knowledge Channel" />
<setting id="Channel_522_changed" value="False" />
<setting id="Channel_523_type" value="17" />
<setting id="Channel_523_time" value="344329" />
<setting id="Channel_523_1" value="Playlist" />
<setting id="Channel_523_2" value="6" />
<setting id="Channel_523_3" value="TV" />
<setting id="Channel_523_4" value="0" />
<setting id="Channel_523_rulecount" value="1" />
<setting id="Channel_523_rule_1_id" value="1" />
<setting id="Channel_523_rule_1_opt_1" value="Nature" />
<setting id="Channel_523_changed" value="False" />
all came from autotune ofcourse
