(2015-06-04, 00:56)mnjm9b Wrote: [ -> ]aaand it's down again.
Try changing your DNS to 8.8.8.8 or 4.4.4.4 and let me know. Adding this to the faq when I get home.
(2015-06-04, 01:04)bry- Wrote: [ -> ] (2015-06-04, 00:56)mnjm9b Wrote: [ -> ]aaand it's down again.
that is my current DNS
I switched to OpenDNS the first time it stopped working
and now on Google DNS
it's not a problem on my end and nothing I change helps...
This is getting off topic... I posted instructions how to fix the issue, further networking help can be found on the net. Thanks
(2015-06-04, 01:26)Lunatixz Wrote: [ -> ]This is getting off topic... I posted instructions how to fix the issue, further networking help can be found on the net. Thanks
Um.... I don't think you understand....
The problem is not anything I can fix....
it isn't on my end...
I have ran traceroutes from many different locations and MOST timeout when trying to connect to Pseudotvlive.com
also fails to connect (or even ping) the ip address directly bypassing any use of any DNS
so changing DNS has no effect on solving the problem.
I am sure I am not the only one with this issue...
it was random before... but I knew that everytime it fails to activate donor then I could be sure that entering "www.pseudotvlive.com" into my browser would time out.
but Now it is constant...
I tried everything you and bry suggested and even looked into this much further than I care to...
if you choose to believe that this is OFF-Topic then so be it
But this has NOTHING to do with my DNS settings.
(2015-06-04, 01:35)mnjm9b Wrote: [ -> ] (2015-06-04, 01:26)Lunatixz Wrote: [ -> ]This is getting off topic... I posted instructions how to fix the issue, further networking help can be found on the net. Thanks
Sure it does, lol... DNS resolves network addresses.
My server isn't down, and although I haven't found why there is an issue with some ppl, including myself when connecting to the site...
I can assure you that the server is up, and you can certainly fix the issue and get it working on your end.
You can begin by following the instructions posted here :
http://forum.kodi.tv/showthread.php?tid=...pid2018425
If you are running a router or managed switch between your modem... and need further proof it can be fixed on your end... just connect your PC directly to the modem.
www.pseudotvlive.com should load fine...
(2015-06-04, 01:44)Lunatixz Wrote: [ -> ] (2015-06-04, 01:35)mnjm9b Wrote: [ -> ] (2015-06-04, 01:26)Lunatixz Wrote: [ -> ]This is getting off topic... I posted instructions how to fix the issue, further networking help can be found on the net. Thanks
You can begin by following the instructions posted here : http://forum.kodi.tv/showthread.php?tid=...pid2018425
OK....
First of all.... I must admit I know enough about Networking to get me into trouble so you are probably right...LOL
I know a TON about computers but Networking has always been hit or Miss...
I have always been told that if I knew the IP address of the website and entered the numbers instead of the "name.com" then it bypassed the DNS (Domain Name System)
But that could be wrong
Also, I must admit I didn't follow the suggestion to clone the MAC address...
Because that seemed to fix it (for now
although I would love an explanation on why that would matter for only pseudotvlive.com
anyway, you are right this is probably off-topic.
and as always....you are awesome!!!
PS. Next release should be equally as awesome!!!! favorites yeah!!!
(2015-06-04, 02:20)mnjm9b Wrote: [ -> ] (2015-06-04, 01:44)Lunatixz Wrote: [ -> ] (2015-06-04, 01:35)mnjm9b Wrote: [ -> ]Um.... I don't think you understand....
OK....
Because that seemed to fix it (for now?)
No problem... at least you are benefiting from instructions... I had to figure this out on my own (was pulling the hair out of my head)...
Changing the MAC was the last thing I thought of and it worked... My conclusion is that its an issue with the routers iptables. Why? I don't know...
My server guy is looking into it... but we are a minority, most users have no problems connecting...
BTW: Changelog preview, to hold u over til friday's release.
[*] NEW! "Direct Channel Input" setting under "Tweaks". When enabled users are no longer required to hit select after inputting a channel number.
[*] NEW! EPG Menus (EPG/DVR/OnDemand/Apps), Accessed using "Red","Green","Yellow" or "Blue" remote keys. Work In Progress: Only available when PTVL Debugging enabled
[*] NEW! Channel Favourites, Set/Remove Favourites from overlay sidebar, Favourite channel jumping requires mapping "ACTION_SYMBOLS".
[*] In-app channel manager resized and tweaked, LiveTV/InternetTV EPG can't be "paused".
[*] NEW! EPG Context Menu: More Info, Find similar (Coming Soon), Record Show (Coming Soon), Set Reminder (Coming Soon).
[*] NEW! Start Over prompt when a show is 1/2 through show duration.
[*] NEW! EPG RSS Push feed, Displayed once every 15mins on/off during a 60min period. Disabled on startup, it can provide you with instant PTVL Status, Repository activity, twitter posts.
[*] NEW! Direct EPG navigation via channel number. [Experimental]
[*] NEW! "Quickflip"feature under "Tweaks". When enabled, On startup and while flipping thru channels PTVL will ignore .strms & chtype 15 "Plugin" sources in favour of flipping performance.
Channels will be skipped; effectively bypassing channels with long load times. creating a smoother surfing experience. Strms & Plugins can still be loaded via EPG. [Experimental]
[*] Heavy "PTVL" skin tweaking and added enhancements. Goal is to create a very detailed skin base for future skinners to use as a guide.
[*] NEW! "Dynamic" EPG Timebar and past event fading...
[*] NEW! Overlay menu "MoreInfo". Activate from overlay using context button. Click "Back", "Close" or the context button again to exit.
[*] Various tweaks & bug corrections.
[*] Added EPG/Overlay Artwork multi-threading, this should improve performance. Artwork is disable until channel building is finished only when background building is enabled.
Current build no longer needs the "Artwork Spooler" all artwork is queued/downloaded on demand. [Experimental]
[*] Youtube fixed, but not 100% of all features restored... Not working: Search, RawGdata, User Subs&Favs and Last.FM.
[*] Default skin changed to "PTVL" and upgraded to 1080i.
[*] All Skins temporarily removed, include "Custom" Option.
[*] [COLOR=blue][B]^ v.0.6.2 ^[/B][/COLOR]
Hi all,
I'm using channel sharing and I'm having an issue. I have a master and and 3 slaves. With the master I used path substitution to substitute PseudoTV Live folder for a folder on my server. PTVL runs can creates the settings2.xml as it should. I then added a custom playlist through channel manager. Again all works fine on the master. When I set up the slaves everything works except that custom playlist and the recent movies/shows are not in the channel list. Its on the master why isn't it on the slaves?
4 FireTVs
Kodi 14.2
PTVL 0.6.2a
Thanks,
BlueKalel
Lunatixz
I downloaded your repo from Githug. It seems it isn't working with Isenguard. I get "wrong configuration" (or something to that effect) when I try and install the repo so I can't install any addons. Is it just me or if it isn't just me, is there any plan to update it so it works?
(2015-05-29, 05:17)wondercoolguy Wrote: [ -> ]noob question I've searched Changing channel resets.....as many ways as I can so I'm sorry if this has already been answered but I couldn't find it.
Is there a fix for when I'm switch channels the channel I'm switching to media resets. Meaning the guide shows the movie is half way over but when I turn to that channel the movie starts over.... or the tv show starts over.
Any help would be appreciated
I have the same problem :-P
Version 0.6.2a is showing as incompatible or has been marked broken in repository. IS there a different repository I should be looking at?
[Never mind. I now have 0.6.2b - same message though. What dependencies need to be met? I have the ones listed on first page]
For anyone that's not able to access the psuedotvlive website, try resetting your router back to its factory settings. I had the same issue for over a week and I followed all of the steps that Luna listed and still couldn't get it work. Resetting my router (Belkin) was the only thing that worked for me.
ANYWAY, the new update is freaking amazing and I love the guide's new look! Thanks Luna!
(2015-06-06, 05:49)bfarley68 Wrote: [ -> ]Version 0.6.2a is showing as incompatible or has been marked broken in repository. IS there a different repository I should be looking at?
I'm having the same problem. I see the Repository dated 2015-06-02. I download it. I see the PseudoTV Live - Update. I try to install it and I get the dependencies error.
My Pseudotv Live 0.6.2a stays put, but keeps asking me to update to 0.6.2b. Whenever the update seems to happen, it is a flash of pop-ups and messages I have no time to read and then all goes quiet and my 0.6.2a starts up.
I guess I'll have to wait until the post explaining a fix on this happens, just like the 0.6.2a update...
Cerafin
