2017-11-05, 02:50
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126
2017-11-05, 16:20
(2017-11-04, 12:58)fritsch Wrote: [ -> ]I used the 1.7.2 firmware on my Apollo Lake from ASRock
Link please?
2017-11-05, 16:59
Updated but after 10 minutes still black screen.
Restartet the system, new Version is there, but only Stereo Sound.
Try to go back to 1.66
Can't find any download. Can someone please offer me Version 1.66?
2017-11-05, 17:13
2017-11-05, 21:19
(2017-11-05, 17:13)bobrik73 Wrote: [ -> ](2017-11-05, 16:59)JasonLA Wrote: [ -> ]Update but after 10 minutes stil back screen.
Link
This is just a redirection to the intel download page
2017-11-05, 21:26
Try: https://www.dropbox.com/s/g8fxgnfl2ylnk1...6.zip?dl=0 (Still had it in my dowload dir ... handle with care, no warrantees whatever ...)
2017-11-05, 22:02
(2017-11-05, 21:26)fritsch Wrote: [ -> ]Try: https://www.dropbox.com/s/g8fxgnfl2ylnk1...6.zip?dl=0 (Still had it in my dowload dir ... handle with care, no warrantees whatever ...)
thank you fritsch! Downgrade worked fine. Everything's running normal again
2017-11-06, 00:30
LibreELEC's release notes on version 8.2.0 are telling this:
What issues they are talking about?
Quote:INTEL HBR AUDIOhttps://libreelec.tv/2017/10/libreelec-k...0-release/
Initial patches to resolve the lack of pass-through HBR audio on NUC devices and similar with an internal DP > HDMI convertor were published recently. Testing has shown good results on Linux 4.13+ kernels but issues are seen with older Intel/NUC hardware using the 4.11 kernel used in LibreELEC 8.2. As a result these patches are not suitable for the 8.2.0 release and this minor issue will be resolved with LibreELEC 9.0 in the future.
2017-11-06, 00:51
(2017-11-06, 00:30)Win a 2 Wrote: [ -> ]What issues they are talking about?
Some users reported no audio with 8.2 and the HBR patch.
Reliable but non-HBR audio (you can still use LPCM) for everyone is better than some users being left with no audio at all and thus truly unusable systems.
2017-11-06, 01:50
(2017-11-06, 00:51)Milhouse Wrote: [ -> ](2017-11-06, 00:30)Win a 2 Wrote: [ -> ]What issues they are talking about?
Are customs builds *with* HBR patch available somewhere?
2017-11-06, 02:15
(2017-11-06, 01:50)Win a 2 Wrote: [ -> ](2017-11-06, 00:51)Milhouse Wrote: [ -> ](2017-11-06, 00:30)Win a 2 Wrote: [ -> ]What issues they are talking about?
I use escalades community build with no issues. You can find it in the libreelec forums
2017-11-06, 09:20
(2017-11-04, 16:38)fritsch Wrote: [ -> ](2017-11-04, 16:10)bobrik73 Wrote: [ -> ]My Apollo Lake from ASRock J4205-ITX - AVR Denon X6200
firmware 1.66 : 4K - OK; 3D (Windows 10) - OK; HD Passthrough - OK
firmware 1.72 : 4K - No; 3D (Windows 10) - No; HD Passthrough - No
I tried with Linux :-) all fine. Hehe.
I got the firmware update tool for 1.72 from here
https://downloadcenter.intel.com/downloa...duct=95069
It's a windows tool.
I run linux/single-boot on my J4205 htpc - Fedora 26. - 4.13.10-200.fc26.x86_64. With an AVR X2300W.
Do you need to flash this new firmware using the tool by booting windows from USB (hopefully not!), or does the kernel load the binary as a blob? If the latter which .bin did you use and how did you replace the old one in your system?
2017-11-06, 09:34
(2017-11-06, 09:20)htpcero Wrote: [ -> ]Please don't upgrade to 1.72, as Sound is as good as not working under Windows.(2017-11-04, 16:38)fritsch Wrote: [ -> ](2017-11-04, 16:10)bobrik73 Wrote: [ -> ]My Apollo Lake from ASRock J4205-ITX - AVR Denon X6200
2017-11-06, 09:51
(2017-11-06, 09:34)JasonLA Wrote: [ -> ](2017-11-06, 09:20)htpcero Wrote: [ -> ]Please don't upgrade to 1.72, as Sound is as good as not working under Windows.(2017-11-04, 16:38)fritsch Wrote: [ -> ]I tried with Linux :-) all fine. Hehe.
I don't run windows at all so no worries.
I hope linux users can shed light on how to get either 1.72 or 1.66 firmware installed, without a copy of windows. I was thinking whether this FW comes included in the J4205 BIOS. I notice there is version 1.40 release in late Sep - would that include v1.66? (I'm still running bios v1.20)
Linux has been working very well in this build, but I do notice the odd problem of no audio after resuming, occassionally, (using custom edid and all, restarting X usually fixes the problem without a reboot).
2017-11-06, 10:40
After the latest Windows 10 Fall Creators Update I started to have problems on Windows with automatic display refresh rate adjustment.
The sound was there (passthrough) but the screen was black until I manually switched the hdmi channel back and forth on my TV.
With the 1.72 update on J4205 everything got worse. I have no sound with passthrough and the black screen problem remains after refresh rate adjustment.
So I tried Libreelec 8.2.0 and Ubuntu 17.10 with Xorg (On Wayland kodi only sees the current refresh rate) and I can confirm that both a working great with the 1.72 update.
Passthrough sound is working and refresh rate adjustment too.
Btw. Is the CEC pin correctly connected to the DP aux port on the J4205 so that it could be supported through the kernel ?
