(2015-06-06, 07:38)cecastil Wrote: [ -> ] (2015-06-06, 05:49)bfarley68 Wrote: [ -> ]Version 0.6.2a is showing as incompatible or has been marked broken in repository. IS there a different repository I should be looking at?
[Never mind. I now have 0.6.2b - same message though. What dependencies need to be met? I have the ones listed on first page]
I'm having the same problem. I see the Repository dated 2015-06-02. I download it. I see the PseudoTV Live - Update. I try to install it and I get the dependencies error.
My Pseudotv Live 0.6.2a stays put, but keeps asking me to update to 0.6.2b. Whenever the update seems to happen, it is a flash of pop-ups and messages I have no time to read and then all goes quiet and my 0.6.2a starts up.
I guess I'll have to wait until the post explaining a fix on this happens, just like the 0.6.2a update...
Cerafin
Maybe the download is failing for some reason? The new version is 34mb so it'll take a bit longer than usual for PLTV to update/install. You could try downloading the zip file from:
https://github.com/Lunatixz/XBMC_Addons/...udotv.live
The dependency might be Youtube-dl as that's what gets installed with 0.6.2b
(2015-06-05, 07:06)wondercoolguy Wrote: [ -> ] (2015-05-29, 05:17)wondercoolguy Wrote: [ -> ]noob question I've searched Changing channel resets.....as many ways as I can so I'm sorry if this has already been answered but I couldn't find it.
Is there a fix for when I'm switch channels the channel I'm switching to media resets. Meaning the guide shows the movie is half way over but when I turn to that channel the movie starts over.... or the tv show starts over.
Any help would be appreciated
I have the same problem :-P
It sounds like your shows have improper runtimes, either hard coded or via kodi library.
Try enabling "Find missing data" and force channel reset.
I had the same issue. I finally found the issue was a bunch of .avi file that PseudoTV would incorreclty parse as being insanely long (like 100s of hours). Of course, when you changed to that channel, it would fail to seek the right time and have to start from the beginning of the next show.
You can check every .m3u file in the /userdata/addon_data/script.pseudotv.live/chache/ folder. You'lll see one .m3u file for each of your channels. If you open the .m3u files in a text editor, you'll see a bunch of lines that start like this:
#EXTINF:2750,Star Trek: The Next Generation//
That 2750 number is length of the show. If it's stupid big (like over 100,000), then that's the file that's your problem.
If you're using linux this command will find them all:
grep -e 'INF:[0-9]\{6,\}' *.m3u
The file I was having problems with were .avi's that were, well, let's just say I got them from some pretty shady places on the internet so I'm guessing the encoding was off. ffmpeg would calculate the length correctly, but PseudoTV didn't. I ended up just re-encoding them and then they worked fine and my channels all behave properly now.
Oh for...
I've got to ask, even if the answer makes me feel like a class 'A' exhibit for moron:
Has the option to hide videos smaller than xyz time always been measured in seconds? If so did the bit of text in that section recently change to explain this?
I've always read it as being in minutes, so clearly was setting it to the lowest setting of fifteen (minutes or so I thought)....
(2015-06-06, 16:37)snesmaster40 Wrote: [ -> ] (2015-06-06, 07:38)cecastil Wrote: [ -> ] (2015-06-06, 05:49)bfarley68 Wrote: [ -> ]Version 0.6.2a is showing as incompatible or has been marked broken in repository. IS there a different repository I should be looking at?
Cerafin
I ave the same problem on my Windows machine, but not my Openelec machines. I did try downloading the the 0.6.2b zip and it won't install because it says dependencies not met but 0.6.2a is running fine on it. . I have all the dependencies listed in the first post of the main thread for PTVL and I also have an addon called youtube-dl COntrol 15.318.0. I assume that's the same thing as you are talking about?
Hello everyone. I'm new to Kodi and attempted to install pesudoTV. I keep getting playback errors when trying to watch channels from the US. How can I fix this?
(2015-06-04, 02:25)Lunatixz Wrote: [ -> ]Code:
[*] NEW! Start Over prompt when a show is 1/2 through show duration.
This is a great idea! When I tired it, it just made the video skip back whatever time the skip back is set to. It didn't go back to the beginning.
Also, I would suggest at least an option to enable this for any video that is not at the beginning and not just ones 50% or further in.
(2015-06-06, 20:15)RockDawg Wrote: [ -> ] (2015-06-04, 02:25)Lunatixz Wrote: [ -> ]Code:
The video does skip back to the beginning... At least it should... and I'm happy with it a 50%, since this is just a reminder.
You can technically start over any show by simply clicking the skip back playlist button (if you have it mapped to a remote).
(2015-06-06, 20:06)RockDawg Wrote: [ -> ] (2015-06-06, 16:37)snesmaster40 Wrote: [ -> ] (2015-06-06, 07:38)cecastil Wrote: [ -> ]I'm having the same problem. I see the Repository dated 2015-06-02. I download it. I see the PseudoTV Live - Update. I try to install it and I get the dependencies error.
Cerafin
I placed youtube-dl as an optional dependency... should fix install issue
Seeing a lot of post concerning YouTube, but not seeing any logs. Note that only channels and playlists currently work. I also fixed limits, locally I can parse over 200. Their maybe regional issues... YouTube is far from 100% after Google's api change.
(2015-06-06, 20:35)Lunatixz Wrote: [ -> ]Seeing a lot of post concerning YouTube, but not seeing any logs. Note that only channels and playlists currently work. I also fixed limits, locally I can parse over 200. Their maybe regional issues... YouTube is far from 100% after Google's api change.
What about Multi Channels and Multi Playlists?
(2015-06-06, 21:05)sickboyy Wrote: [ -> ] (2015-06-06, 20:35)Lunatixz Wrote: [ -> ]Seeing a lot of post concerning YouTube, but not seeing any logs. Note that only channels and playlists currently work. I also fixed limits, locally I can parse over 200. Their maybe regional issues... YouTube is far from 100% after Google's api change.
Yeah those work, because they use channels and playlists.
(2015-06-06, 21:06)Lunatixz Wrote: [ -> ] (2015-06-06, 21:05)sickboyy Wrote: [ -> ] (2015-06-06, 20:35)Lunatixz Wrote: [ -> ]Seeing a lot of post concerning YouTube, but not seeing any logs. Note that only channels and playlists currently work. I also fixed limits, locally I can parse over 200. Their maybe regional issues... YouTube is far from 100% after Google's api change.
Hmm I must be doing something wrong. I have a few YouTube channels and only one of them is working.
http://pastebin.com/GX0DSkVT (settings2.xml -- the YouTube playlists are at the bottom).
The 'Challenge' channel works fine but the others won't show up. I'm guessing it's because I'm grabbing usernames explicitly with the Challenge channel, whereas with the others I'm getting them from different places.
For playlists I'm grabbing the &list= part of
a playlist and for channels I'm grabbing the ID which follows /channel/ on
these pages.
I'm guessing that's wrong..?
(2015-06-06, 21:15)sickboyy Wrote: [ -> ] (2015-06-06, 21:06)Lunatixz Wrote: [ -> ] (2015-06-06, 21:05)sickboyy Wrote: [ -> ]What about Multi Channels and Multi Playlists?
For playlists I'm grabbing the &list= part of a playlist and for channels I'm grabbing the ID which follows /channel/ on these pages.
YouTube channels work with channel Id ie uc..... Or by channel name, ie. vevouk
Playlists require playlist id ie Pl.....
(2015-06-06, 21:21)Lunatixz Wrote: [ -> ] (2015-06-06, 21:15)sickboyy Wrote: [ -> ] (2015-06-06, 21:06)Lunatixz Wrote: [ -> ]Yeah those work, because they use channels and playlists.
Thanks for the help. The 'Discovery' channel (where the script is getting stuck) has a Multi Playlist with this value:
PLqt1BbpFEnLLoHMQTh7jBOvjmZE2soaj5|PLOIgvHgqep3Auswl_QFQvchQZAUmwqLDE
They're both prefixed with PL, so why would they not be accepted?
