First of all: Thanks for the great work you are doing!
I've used 5.3.5 until Thursday (On libreelec 7 on a raspberry pi 3) without serious problems (the known bug of some "no video streams found" messages on some videos the only noticeable).
I decided to upgrade libreelec to 8.0.1 (kodi krypton 17.1).
Since then I've been unable to sign in... It gives me the pop-up with the code for YouTube.com/activate and when I put in the code (and allow the plugin access) it sometimes goes on to the second pop-up with the code for the 2nd login, but at the latest after allowing this access via the Google account it times out (Often it already times out on the first code).
I first tried with the version from the Kodi repo 5.3.12, without private API keys... No go. Then I tried the same version with my own API key, no go. Then I tried with the 5.3.13-alpha (both with our without private API keys), same issue. (After each try I fully removed and reinstalled the plugin including all folders, to be sure to start with a clean install of the plugin)
It almost seems like after the code is entered on YouTube.com/activate and accepting the access, this is not sent back to the plugin, which then waits for the reply until it times out...
I have reinstalled and tried to sign in around 25 times in the last three days, about a quarter of the time it accepts the first authentication and goes on to ask for the second (no difference if I use the community api keys or my own, he asks me to authorize the correct thing, but stalls after I push accept).
What am I doing wrong, or is there an issue at Google or in libreelec that is preventing the proper sign in?
If a log helps,
http://paste.ubuntu.com/24354030 here is one. (What makes me expect an issue on the side of Google is the line " Error Contents: HTTPSConnectionPool(host='www.youtube.com', port=443): Max retries exceeded with url: /o/oauth2/token (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6a9fecf0>: Failed to establish a new connection: [Errno 110] Connection timed out',)) " in the log).
Sorry for the long post, but I'm slowly losing what's left of my sanity ☺. Many thanks in advance for any help!
T
