2016-11-07, 09:35
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
2016-11-07, 11:14
(2016-11-06, 15:53)anxdpanic Wrote: [ -> ]1080p (HD) was removed from the settings, as it was misleading (it will always result in 720p or less)
In 5.3.0a5, >720p is possible 2 ways;
Use MPEG-DASH
(2016-04-02, 19:47)jdf76 Wrote: [ -> ]
Kodi 17 and inputstream.mpd Add-on are required for 1080p and above to work
inputstream.mpd may be included with your installation of Kodi 17, and some installations will be require it to be enabled and/or installed.
- Ubuntu(other linux distros may be similar): sudo apt-get install kodi-inputstream-mpd
- LibreELEC: "... you'll need to install the inputstream.mpd add-on from the LibreELEC Add-ons repository"
- Windows: Checkbox during installation under "Inputstream Add-ons" (may be disabled by default)
- OSMC: Nightlies have this included (may be disabled by default)
- Android: may be disabled by default
- OSX/macOS: this is disabled by default. Same Setup as the rest.
Where to find inputstream.mpd if installed:
Add-ons - Add-on Browser - My Add-ons - VideoPlayer InputStream
See here for an explanation of how inputstream.mpd handles bandwidth/resolution.
Also worth noting that not all videos will have dash playback at the moment, vevo content for example does not.
Enabling URLResolver (Debrid) support
This option requires an account with a paid service, and is provided optionally for users of these services to take advantage of.
Will enable >720p without mpeg-dash, all configuration other than the enabling of the feature itself is handled by URLResolver
Requirements for this option:
- 'script.module.urlresolver' is installed
- an account with a Debrid service that supports YouTube and has a working resolver available in URLResolver
- URLResolver and resolver(s) properly configured
Currently no other ways for >720p that I am aware of.
Thanks anxdpanic
I didn't see the post where was this issue.
2016-11-07, 14:19
just curious, now that debrid is supported, i wonder which service actually supports >720p?
I tried real-debrid and can only get 720p
2016-11-07, 15:26
My bad. You're right, it works on some videos.
Not on all videos unfortunately, probably the same issue as with inputstream (encrypted signature?)
2016-11-07, 15:30
A word of warning - Real Debrid is banned here due to their piracy associations which violate our forum rules (wiki).
So inclusion of them into the add-on is not desirable please.
2016-11-07, 15:34
(2016-11-07, 15:30)DarrenHill Wrote: [ -> ]A word of warning - Real Debrid is banned here due to their piracy associations which violate our forum rules (wiki).
+a lot
Please remove support for it ASAP
2016-11-07, 15:38
In adding mpd, it was more about providing it so we have an option where possible at this point and trying not to interrupt the user experience. (that would get frustrating fast)
No complete solution yet
* edited for forums rules.
2016-11-07, 20:28
(2016-11-07, 15:34)Martijn Wrote: [ -> ](2016-11-07, 15:30)DarrenHill Wrote: [ -> ]A word of warning - Real Debrid is banned here due to their piracy associations which violate our forum rules (wiki).
+a lot
Done. My apologies.
Jeff
2016-11-08, 04:01
After the update I no longer have thumbnails on my subscriptions. Also tried to roll back to the older version and it no longer has thumbnails as well. I did delete the add on preferences file from /profile/addon_data/plugin.video.youtube
Anyone else have his problem? Too bad. This plug in has been rock solid for months.
2016-11-08, 05:58
(2016-11-08, 04:01)kasmca Wrote: [ -> ]After the update I no longer have thumbnails on my subscriptions. Also tried to roll back to the older version and it no longer has thumbnails as well. I did delete the add on preferences file from /profile/addon_data/plugin.video.youtube
Well this is why we're trying to get the bugs worked out. I did ask you guys to test it and i took it as no news is good news.
I tweaked the API quota settings just a tad bit.
Here is what i'd like you to do .
sign out
go to the settings option.
go to maintenance
select delete settings.xml
Once you hit yes you'll get a "Succeeded message"
After that open it back up and it will act as you are setting it up for the first time.
Select the API option (i'm in estuary but the overall foot print is the same)
If you're using an API key this wont matter to you.
if you're using our pre-set keys choose one of the 5 we have. Leave it at default first and see if that works for you. You will need
to sign in again i'm sorry about that but thats what happenes with API changes.. Fun fun fun.
I *hope* to write a page where you guys can just put in the 2 keys in one webpage.
Let me know how you do.
Jeff
2016-11-08, 06:06
Thanks for the quick reply. That worked!
2016-11-08, 09:15
Got an error when exiting the addon v5.3.1.
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object is not callable
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/default.py", line 7, in <module>
runner.run(__provider__)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/runner.py", line 32, in run
__RUNNER__.run(provider, context)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/impl/xbmc/xbmc_runner.py", line 23, in run
results = provider.navigate(context)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/abstract_provider.py", line 123, in navigate
result = method(context, re_match)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/register_provider_path.py", line 12, in wrapper
return func(*args, **kwargs)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/youtube/provider.py", line 340, in _on_channel
playlists = resource_manager.get_related_playlists(channel_id)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/youtube/helper/resource_manager.py", line 157, in get_related_playlists
result = self._update_channels([channel_id])
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/youtube/helper/resource_manager.py", line 35, in _update_channels
channel_data = function_cache.get_cached_only(self._get_channel_data, unicode(channel_id))
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/utils/function_cache.py", line 66, in get_cached_only
data, cache_id = self._get_cached_data(partial_func)
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/utils/function_cache.py", line 56, in _get_cached_data
return self._get(cache_id), cache_id
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/utils/storage.py", line 191, in _get
result = self._execute(False, query, [item_id])
File "/storage/usbotg/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youtube/resources/lib/kodion/utils/storage.py", line 79, in _execute
return self._cursor.execute(query, values)
File "/home/jenkins/workspace/Android-ARM64-v8a/tools/depends/xbmc-depends/aarch64-linux-android-android-21/lib/python2.7/sqlite3/dbapi2.py", line 69, in convert_timestamp
TypeError: 'NoneType' object is not callable
2016-11-08, 09:29
Do we really need write so many logs like this and no way to turn it off?
23:15:59.534 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'Fy-k3cVe3Wc' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'S9bmc1uKAz4' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '-PABOf09aes' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'pvLoheKYmLI' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'zVJtP2qYMQ0' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'unoJii5PJV4' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 't_bDVLtASVQ' cached
23:15:59.535 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '0Dl6KOc8VMA' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '7STNrFjJhF0' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '44VxElQSa-0' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'JoQ4GidQP-k' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '0z5SsDEWWIU' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'RqLMn9umGD8' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'Sjf_ouod6bM' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '8hCIVB1xDhk' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'TZbxWvc9O6M' cached
23:15:59.536 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'Ty6XAN_kzm4' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'uQ3B0okRgUM' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'd5t-QBmWl3s' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 's6MwGeOm8iI' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'ddN9yZPs2P0' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'VHBNFURDzWA' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '1_Sdkdr_Irk' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'GNR4lArMXRI' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'tLksISrKtO8' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'isbW5RLIeDY' cached
23:15:59.537 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'Z6R0NvVr164' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'Zed17O3vNgI' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'B36kCme89xk' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '2wdefDS1lWs' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'T7HGSvczDA4' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'OklGfyONt9c' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'T6ChQ7hXv7c' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'lBgmZr4vU14' cached
23:15:59.538 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '5uR2BA3MFQE' cached
23:15:59.539 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'cCuR-GUlJzM' cached
23:15:59.539 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '6nMXsxAyDhY' cached
23:15:59.539 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '8KcdZZnBfRA' cached
23:15:59.539 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'SUzsih7QJSY' cached
23:15:59.540 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'SnlL3JiaDTc' cached
23:15:59.540 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'pFA8Xytdlu4' cached
23:15:59.540 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'LhI_8AWX_Mg' cached
23:15:59.541 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'vST61W4bGm8' cached
23:15:59.541 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'hxH6bKNPBIA' cached
23:15:59.541 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'XndcZgxxXPs' cached
23:15:59.541 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'UKQGWrA_UsY' cached
23:15:59.541 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '1VvIiTHw0rU' cached
23:15:59.542 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'lCBQljdIpYE' cached
23:15:59.542 T:367353584016 DEBUG: [plugin.video.youtube] No data for video '8lQtdhtw5eI' cached
23:15:59.542 T:367353584016 DEBUG: [plugin.video.youtube] No data for video 'g6DdX51fnxM' cached
23:16:00.456 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCqFzWxSCi39LnW1JKFR3efg' cached
23:16:00.461 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCk_nBvBjw0DuEtrT8Sxv5vA' cached
23:16:00.461 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCBi2mrWuNuyYy4gbM6fU18Q' cached
23:16:00.461 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCR4wTAyVbbX-IiBiGCgIBTg' cached
23:16:00.461 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC47Xz8LVxEJBX5gmkW9mALQ' cached
23:16:00.461 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCeJLx_Dy_icz3oDHhJeMe9g' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCupvZG-5ko_eiXAupbDfxWw' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCBa659QWEk1AI4Tg--mrJ2A' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCbElcfNJQJHYiNoaV8F7E5g' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCu6mSoMNzHQiBIOCkHUa2Aw' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCgRvm1yLFoaQKhmaTqXk9SA' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCF9imwPMSGz4Vq1NiTWCC7g' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCbPQ73V32axPMIBeqdjZ0WQ' cached
23:16:00.462 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCjD2KyAEm84yVH8cTilID7Q' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCwmZiChSryoWQCZMIQezgTg' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCmWyesNAlftV3kJlFhD6q6w' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC2DYZIou2ZN-stBPv3aks6Q' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCVtL1edhT8qqY-j2JIndMzg' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC1yBKRuGpC1tSM73A0ZjYjQ' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCqC_GY2ZiENFz2pwL0cSfAw' cached
23:16:00.463 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCZyWzFIaigWI3Bsej_19BVw' cached
23:16:00.464 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCZGYJFUizSax-yElQaFDp5Q' cached
23:16:00.464 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC3XTzVzaHQEd30rQbuvCtTQ' cached
23:16:00.464 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCDR8cvjALazMm2j9hOar8_g' cached
23:16:00.464 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCv_s-FKXBwsq1zy4GCR3Ycw' cached
23:16:00.464 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCQ-ttSCwBiGhgM5GLY1hzWA' cached
23:16:00.466 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCy6D16zE_mMEm1HVD20WFxA' cached
23:16:00.466 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC52X5wxOL_s5yw0dQk7NtgA' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC1IodnjXHqTPk5MeNBGC5bA' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC_976xMxPgzIa290Hqtk-9g' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCFP0Q9Bz28zo3jXxzU6JMmA' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCp0hYYBW6IMayGgR-WeoCvQ' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCcp4KFhOic20jLqqqd7qTGg' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCc33VfExTOV1c3Oe0Kau9lw' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCLRYsOHrkk5qcIhtq033bLQ' cached
23:16:00.467 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCnC1qc3bNfNjmzi5wUzGWLA' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCvgfXK4nTYKudb0rFR6noLA' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC4f1JueVgo5t9HSmobCRPug' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCUZzyuAlhHNP3oiuMjn7RfQ' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCoUM-UJ7rirJYP8CQ0EIaHA' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCHqC-yWZ1kri4YzwRSt6RGQ' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC7-E5xhZBZdW-8d7V80mzfg' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCBR8-60-B28hp2BmDPdntcQ' cached
23:16:00.468 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UC0v-tlzsn0QZwJnkiaUSJVQ' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCLXo7UDZvByw2ixzpQCufnA' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCM5UeFpooSJ5g7CGey2DJrQ' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCTcCX_XY4l-W2ba5IxIRhsg' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCETZ7r1_8C1DNFDO-7UXwqw' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCiAz0fn-vfJ145kbing9wNw' cached
23:16:00.469 T:367353584016 DEBUG: [plugin.video.youtube] No data for channel 'UCDr3kQyKDLvB2vlX-nXNY2w' cached
2016-11-08, 10:05
first of all, if you're trying to help us determine an issue a debug log (wiki) is helpful, but don't post it to the forum, because it's too much, post it to pastebin and then give us the link. No you don't need debug mode on all the time.
If you just upgraded over top of what you had, you might try just deleting the cache and settings.xml which is 2 options from the Maintenance menu. Sometimes Upgrades don't go so smooth especially when there is alot of changes. I know personally i just reset my settings and started over. It runs fine for me.
Jeff
Jeff
2016-11-08, 11:14
(2016-11-08, 10:05)jdf76 Wrote: [ -> ]If you just upgraded over top of what you had, you might try just deleting the cache and settings.xml which is 2 options from the Maintenance menu. Sometimes Upgrades don't go so smooth especially when there is alot of changes. I know personally i just reset my settings and started over. It runs fine for me.
Jeff
Thx. Did it for me.
Gesendet von meinem GT-I9300 mit Tapatalk
