(2019-12-26, 06:54)sualfred Wrote: [ -> ]It's an issue with the installed numpy package on your Linux image. https://github.com/sualfred/script.embua.../issues/28
There's nothing I can do and has to be fixed by the ones wo introduced the issue.
Thanks sualfred.. I appreciate you taking the time to look at it.
I'll play with the package versions see if I can get one that will work.
the numpy python is problem... i had seen it both opensuse and ubuntu. i forgot what i did to solved in opensuse, but in ubuntu problem solved by remove inkscape :p
(2019-12-26, 13:55)freebs Wrote: [ -> ] (2019-12-26, 06:54)sualfred Wrote: [ -> ]It's an issue with the installed numpy package on your Linux image. https://github.com/sualfred/script.embua.../issues/28
So I checked version on my Pi3 compared to my Pi4.. and they are the same... PIP version 18.1 for python 2.7 with numpy versions being 1.16.2.
I downgraded the Pi4 of numpy to 1.14.5 (python -m pip install numpy==1.14.5 ) and was then able to see the normal widgets placed there upon install. Still had an error pop up though. Weird.
I'll continue to play with this..
(2019-12-26, 14:49)freebs Wrote: [ -> ] (2019-12-26, 13:55)freebs Wrote: [ -> ] (2019-12-26, 06:54)sualfred Wrote: [ -> ]It's an issue with the installed numpy package on your Linux image. https://github.com/sualfred/script.embua.../issues/28
Ok solved the issue..
I had to install matching versions with sudo apt install python-backports.functools-lru-cache (which is version 1.5-3)
and pip install backports.functools_lru_cache==1.5
also did
python -m pip install numpy==1.15.4
No more log errors and all widgets on main screen work
Thanks for the heads up on the python !
Scrub this. Did a fresh install.
I seem to have a problem with my "next up widgets". I have set up user widgets that should show me the next epiosdes of my shows based on tags.
<setting id="UserWidget3_path" type="string">plugin://script.embuary.helper/?info=getnextup&tag=TV-Show - Kino</setting>.
This worked perfectly for the last year.
Unfortunately in some cases now it does not work anymore.
If I have also a season 0 (specials) for a show, this widget will not show me the correct next episode but one episode of the last season of the respective show.
For example, the last epsiode of GoT I watched was S02E06. I would expect the widget to show me S02E07. Instead it shows me S08E01 for some reason. And as I said, it seems to only happen with shows where I have specials...
Please reproduce the error and upload me your MyVideos116.db to check it on my end. So I can see it with the same play and watched states.
Edit:
Tested it with Black Mirror (the only one which I have specials for), marked everything unwatched, marked season 1 as watched, marked 1 episode of season 2 as watched -> next up shows me "s02e02" as next.
Specials are ignored for this widget, but I have to check it with your db. Maybe there is a corner case.
Hey there sualfred. I just downloaded the Embuary skin and it's great. I do however have a question about the widgets.
Can I get the next up or continue watching for my gdrive add-on?
Only native library can be supported. I don't know anything about the gdrive addon but if the content is scanned to the Kodi DB like any ofther content it is working.
I tried it with the local library as well. The "next up" and "continue watching" don't seem to be working. They don't show up. (Actually what happens is when I exit out of the player window, I'll the see the next up widget buffering for a moment and then it disappears)
(2020-01-14, 15:52)treatyoself Wrote: [ -> ]I tried it with the local library as well. The "next up" and "continue watching" don't seem to be working. They don't show up. (Actually what happens is when I exit out of the player window, I'll the see the next up widget buffering for a moment and then it disappears)
Update: the continue watching is now working. Still don't see next up.
It's a really nice looking skin. But I rarely keep anything on my laptop for the widgets to work. Would be really nice if you could have those widgets working for add-ons as well. Great work nonetheless.
Can you tell me how to enable my track pad for this skin?
As I said, it works flawlessly with the native DB. I have no clue about what the gdrive addon is doing.
The skin has no mouse/trackpad, touch support.
Hi ,
First, let me thank you for this wonderful skin.
I have two questions :
1. After clicking a movie file, the file is playing directly. I need to check the information, I can do it by accessing the context menu or pause the playback and pressing the "i" button. Is there some way I get the info with the first click and select to play the movie next. (like netflx).
2. Is there some way to display the imdb rating + the file size of the movie. (I am using plex share to see my contents).
