(2020-02-26, 19:47)sualfred Wrote: [ -> ]no, it will get overwritten on a skin update.
https://github.com/sualfred/skin.embuary...s.xml#L525
add a new param with "limit" if you still want that risk.
Ok. I will not touch the xml - will rather figure out the way to reset the watch position for the movies. Thanks.
Hi sualfred, amazing work on this skin. Like others have said, it's rare I find a skin that I'm immediately in love with and becomes my go to.
I have two questions and REALLY apologize if either has been asked already. I searched and read through almost 100 pages before asking.
- Is there a way to remove the watched symbol/graphic from all movies and tvshows? Not the content but the indicator itself.
- When changing the aspect ratio using keymaps and a single button toggle, I don't see the current mode shown on the screen. Is there a way to add this? I'm primarily concerned with "normal" and "16:9 Stretch" for anamorphic support. It's somewhat hard to know the mode you are in without going into the video options. I'd really like to limit it to just those two options but that doesn't seem possible from what others have told me.
Thanks again and keep up the great work!
Thanks a lot for all your work man!
I have an issue with my kodi.
The "cinema intro" section is completely disabled.
Please see the image. Am I missing something?
https://extraimage.net/image/y5ob
Works only with local items.
The solution for me was very simple and already present in custom widgets. I disabled the "continue watching" widget of the skin, created a custom widget for "In Progress movies" and renamed to "Continue watching" - Now I have the "continue watching" widget where I can limit the item numbers (I've set it up to 25). As such, the original continue watching widget was listing all movies as I hardly leave any tv episode not completely watched. Thanks again for the wonderful skin.
I also had request/suggestion to make. I don't remember which skin was it, but I saw a skin where there were 2 widgets possible for "suggestions based on recent movie" - sort of recommending 2 different set of movies based on 2 different movies in recent watch history. Is that something that can be implemented with your skin?
(2020-03-04, 21:51)sualfred Wrote: [ -> ]https://github.com/sualfred/script.embua...hed-movies
plugin://script.embuary.helper/?info=getsimilar&type=movie&pos=0
plugin://script.embuary.helper/?info=getsimilar&type=movie&pos=1
plugin://script.embuary.helper/?info=getsimilar&type=movie&pos=2
So, this is already included in the skin(?) I will try to enable these widgets when I go home this evening.
Yeah, Movies -> Recommendations.
If you want it as widget on the home screen you have to manually add it with these paths.
Hey Sualfred, did you have any suggestions for my question a few posts back about the watched indicator and aspect ratio?
No to a watched indicator toggle.
The AR one is controlled by Kodi, not by a skin. Hands bound.
(2020-03-05, 09:08)sualfred Wrote: [ -> ]No to a watched indicator toggle.
Do you know if there is a way for me to delete the watched indicator graphic? I looked through the assets but couldn't find anything.
For the AR, yeah I get that I can't reduce the number of modes but would there be a way you can display what AR is currently active when switching? Every other skin has this shown and yours is the first where nothing is on the screen.
I have a small issue.
For some reason, after clicking on a folder with TV shows, the first level is not showing the thumbnail on the left side of the screen. (See pic)
When selecting the desired season, that level works correctly, and thumbnail shows. (see pic2)
For testing purposes, I tried another skin, and it does work right.
Any idea what may be wrong?
Thanks in advance
Sorry, I forgot to add some things, and don't seem to be able to edit the post.
I am running The Mezzmo plugin and those pics were from within the plugin.
Kodi Ver: 18.6
Latest version of your Skin.
