I have no experience with Mezzmo but it seems that it doesn't set the artwork correctly for seasons.
OK, Thanks for taking a look.
I asked them a few days ago, and they couldn't find anything on their end.
But it's all good. This skin works best for me.
Thanks for the reply and the skin.
Before someone asks:
Die "cinema" widgets are currently "broken". I have to update the skin. Will do it asap.
Hi, I recently discovered this skin to use on my Vero 4k+ device. As a long-time user of Emby on Windows 7, this is a great skin for Kodi. One feature request if I may:
1 have a 1.78 ratio projection screen, and when I view a 2.35 video I like to use screen masking (CIH) to mask of the top and bottom black bars, this gives me the perception of improved contrast.
The problem is that by masking to 2.35 the OSD of the skin gets chopped off. Is there any way you could add an option to keep the OSD within the 2.35 ratio space?
Here is an example of a skin that provides this function :
https://discourse.osmc.tv/t/screen-displ...atio/84613
This skin has only 16:9 support, like most of all custom skins.
(2020-03-08, 20:25)sualfred Wrote: [ -> ]This skin has only 16:9 support, like most of all custom skins.
OK, maybe something for a future feature?
Hi, for some reason, I'm only able to view/access Unwatched items... despite having the latest version and resetting my menu multiple times.
(2020-03-08, 22:30)Simsimma Wrote: [ -> ]Hi, for some reason, I'm only able to view/access Unwatched items... despite having the latest version and resetting my menu multiple times.
Ok, now I feel stupid; I just sorted it.
I wanted to watch a previously watched movie, so I switched to another skin, and saw that the "Unwatched" option was toggled on; I switched it to "All."
Then I put Embruary back again and it all works as it should.
It seems to be due to the fact that Embruary does not offer the option of selecting these options within the skin itself. You must use the menu.
Something worth addressing in a future update/version?
Header bar -> Filter icon
(2020-03-08, 23:08)sualfred Wrote: [ -> ]Header bar -> Filter icon
There was no such icon for me.
(2020-03-05, 16:44)sualfred Wrote: [ -> ]It's not a graphic.
Is there any way you could make the watched indicator a configurable option? With your own library, haven't you watched 95% of your library? Don't you want to see the beautiful posters without that graphic all over the place?
Is this something other people want?
Doesn't change the fact that I love your skin!
Hi sualfred,
I really like Embuary skin.
Request. Is it possible to have a theme with round edges also rather than sharp edges on posters/ wall papers etc? I think round edges will make the look more modern.
So I'm using Embuary Skin on my Shield TV pro 2019, but I find it to be fairly slow, is there any way to make it snappier?
Is there still support for Embuary skin?
Cheers
As far as I'm aware Embruary is a one-man project, who judging by his avatar has a young family.
I'd say his priorities are elsewhere for now, wouldn't you agree?
