2021-03-04, 04:14
I didn’t mind Embuary not being available on Matrix as long as it was an option to stay on Leia. NVIDIA Shield forced-updated Kodi to Matrix today. Looking forward to a Matrix-ready version in a repo. Thanks for the cool skin!
(2021-02-24, 09:30)sualfred Wrote: [ -> ]Tempory fix to get this skin running in Matrix is to manually edit the addon.xml and bump the xbmc gui version to 5.15.0. There were no important changes which could affect this skin. Will take care of it as soon as I find time.
(2021-04-03, 00:53)jgr1045 Wrote: [ -> ]I had the similar issue. I installed Kodi 18.9 first. Then I installed Embuary perfectly. Finally, I updated Kodi to 19.0. The screen showed that the addons were transferring the addons to new environment. After that, I use this method to modify the xml file then zip it again for reinstalling the skin. But it looks missing some dependencies or the the dependencies are not supported for Kodi 19.0. So I failed to update it. My device is n nVidia Shelid TV 2017.(2021-02-24, 09:30)sualfred Wrote: [ -> ]Tempory fix to get this skin running in Matrix is to manually edit the addon.xml and bump the xbmc gui version to 5.15.0. There were no important changes which could affect this skin. Will take care of it as soon as I find time.
First of all, thank you so much for this skin, it's the best!
I extracted the files and edited the addon.xml to 5.15.0 and re-zipped it.
When i try to install it, I get and error message saying it failed because of invalid structure.
Any chance you can tell me what i'm doing wrong?
Thank you!
(2021-06-30, 16:30)satelly Wrote: [ -> ]Thank you for this excellent skin. I have been exploring this having previously used Aeon Silvo Nox and Arctic Zephyr. The 1 main issue I seem to be stuck on is I can't change the view.
For example, when I go into the movie section, all the movies are in list mode
https://imgur.com/grkffLD
How to I get these other poster or fanart views
https://imgur.com/B1hYoMV
https://imgur.com/AHEHTpD
EDIT: apologies when I try to use img coding, it doesn't work
(2021-06-30, 17:41)Doctor Eggs Wrote: [ -> ](2021-06-30, 16:30)satelly Wrote: [ -> ]Thank you for this excellent skin. I have been exploring this having previously used Aeon Silvo Nox and Arctic Zephyr. The 1 main issue I seem to be stuck on is I can't change the view.
Go to the top of the screen where it has Home | All Movies | Recommended | etc. and then go all the way to the right where there is a search icon, a sort icon and the third should allow you to change the view.
(2021-07-27, 05:42)plsharevme Wrote: [ -> ]hello, before that i use this skin with emby, the setting all go very well.Are you using the Jellyfin addon or the Jellycon addon? There is a distinct difference between both, just the same as Emby vs Embycon. Jellyfin translates your media files from the filesystem directly to KODI DB as if you scanned sources, when you click on default Kodi menu items its pointing to the KODI DB and plays back. Jellycon is a streaming addon that doesn't synchronise your content from Jellyfin to KODI so you have to change the default menu items to point to Video Addons > Jellycon > Jellyfin Libraries > Movies etc
recently i change to jellyfin with jelly for kodi addons, when setup custom widget, i add video library - movies which i already sync to kodi. but when i click the movie it no show me the information page, it just show me plot , play , close.
i have setting kodi media when click play to when click show information.
i install embuary use kodi repo.
any setup i miss?
thanks
(2021-07-27, 07:55)Kokonutcreme Wrote: [ -> ](2021-07-27, 05:42)plsharevme Wrote: [ -> ]hello, before that i use this skin with emby, the setting all go very well.Are you using the Jellyfin addon or the Jellycon addon? There is a distinct difference between both, just the same as Emby vs Embycon. Jellyfin translates your media files from the filesystem directly to KODI DB as if you scanned sources, when you click on default Kodi menu items its pointing to the KODI DB and plays back. Jellycon is a streaming addon that doesn't synchronise your content from Jellyfin to KODI so you have to change the default menu items to point to Video Addons > Jellycon > Jellyfin Libraries > Movies etc
any setup i miss?
thanks
I use Jellyfin and not Jellycon, which means after KODI launches, it will perform a server sync and I use the default menu items, create custom menu items, playlists, widgets etc accessing content directly from KODI DB and not via Video Addons.
