(2021-02-26, 20:46)znmex3r Wrote: [ -> ] (2021-02-24, 09:30)sualfred Wrote: [ -> ]Tempory fix to get this skin running in Matrix is to manually edit the addon.xml and bump the xbmc gui version to 5.15.0. There were no important changes which could affect this skin. Will take care of it as soon as I find time.
Hi Sualfred, I don't see reference to the xbmc gui version in the addon.xml. Do you mean change this line: <import addon="xbmc.addon" version="12.0.0"/> to version 15.5.0? I guess this is a stupid question. Sorry and thanks, znmex3r
No, that's not correct. Here is the entire addon.xml (emphasis mine):
<?xml version="1.0" encoding="UTF-8"?>
<addon id="skin.embuary-leia" version="18.8.9" name="Embuary (Leia)" provider-name="sualfred">
<requires>
<import addon="xbmc.gui" version="5.15.0"/>
<import addon="script.embuary.helper" version="1.3.6"/>
<import addon="script.embuary.info" version="1.2.4"/>
<import addon="resource.uisounds.embuary" version="0.0.4"/>
<import addon="plugin.program.autocompletion" version="1.0.1"/>
<import addon="script.skinshortcuts" version="1.0.17"/>
</requires>
<extension point="xbmc.gui.skin" debugging="false">
<res width="1920" height="1080" aspect="16:9" default="true" folder="xml" />
</extension>
<extension point="xbmc.addon.metadata">
<summary lang="en_GB">Embuary skin by Sualfred</summary>
<summary lang="de_DE">Embuary Skin von Sualfred</summary>
<description lang="en_GB">Embuary is based on the web UI of Emby and has been developed for Emby-For-Kodi and EmbyCon users, but will also work for any other common Kodi setup.</description>
<description lang="de_DE">Embuary ist dem Web UI von Emby nachempfunden und für Emby-For-Kodi und EmbyCon Nutzer entwickelt worden, aber funktioniert auch für alle gängigen Kodi Setups.</description>
<disclaimer lang="en_GB">No mouse support. With the installation of the skin you agree that you don't use it in combination with blacklisted and illegal Kodi add-ons. I'm not associated with any available build and I won't give any support to blacklisted, banned or illegal third party addons.</disclaimer>
<disclaimer lang="de_DE">Keine Maus Unterstützung. Mit der Installation des Skins erklärst du dich damit einverstanden keine verbotenen und illegalen Addons von Kodi damit zu benutzen. Ich stehe in keinerlei Verbindung zu verfübaren Builds und gebe keinen Support für diese oder andere illegalen Drittanbieter-Addons.</disclaimer>
<platform>all</platform>
<license>CC-BY-NC-ND-4.0</license>
<forum>https://emby.media/community/index.php?/topic/49724-beta-embuary-the-emby-kodi-skin/</forum>
<source>https://github.com/sualfred/skin.embuary</source>
<assets>
<icon>resources/icon.png</icon>
<fanart>resources/fanart.jpg</fanart>
<screenshot>resources/screenshot-01.jpg</screenshot>
<screenshot>resources/screenshot-02.jpg</screenshot>
<screenshot>resources/screenshot-03.jpg</screenshot>
<screenshot>resources/screenshot-04.jpg</screenshot>
<screenshot>resources/screenshot-05.jpg</screenshot>
<screenshot>resources/screenshot-06.jpg</screenshot>
<screenshot>resources/screenshot-07.jpg</screenshot>
<screenshot>resources/screenshot-08.jpg</screenshot>
<screenshot>resources/screenshot-09.jpg</screenshot>
<screenshot>resources/screenshot-10.jpg</screenshot>
</assets>
</extension>
</addon>
I don't think you are looking at the right addon.xml file.
