2021-01-21, 19:30
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170
2021-01-21, 22:47
(2021-01-20, 20:51)RonnieG3 Wrote: [ -> ]Question for those who've switched to Matrix: is the new method of fanart renaming (fanart1, fanart2, etc) in the main folder the only way extrafanart is now supported, or is there a toggle to continue to use extrafanart folder.
If every fanart needs to listed as above in the main video folder, is there an easier way to do it than manual renaming? I have a LARGE Movie and TV Show and Music collection that'll take months convert. Any suggestion or recommendation would be appreciated. I know some add-ons are still waiting for the migration to Py3 - is there a list of commonly used add-ons not yet supported. I didn't know where else to post this, but I am using the Mod on Leia with few issues and I don't have time right now to switch all fanart manually and I'm just hoping for some suggestions.
Thank You
You can use shs, this script is adapt for Matrix and use old way art configuration and naming.
@latts9923
Look what info are missing for TVShow...add them in dialog
2021-01-22, 14:07
@Angelinas
I'll have to add some of that info to Video Info for TV Shows...it is a little lacking. Is all that info provided by SHS?
2021-01-23, 23:45
UPDATE #5 - This will update the skin to v1.0.0.5
Additions
- I added ".hdr10." as an option to use in your video filenames to display the hdr2 icon. Thanks to Tenker for the request!
- I added ".dts." and ".dtshd-ma." as options to use in your video filanemes to display the Digital DTS icon or the DTS HD Master Audio icon as your audio codec. Thanks to Tenker for the request!
- I added "Premiered:" to the Video OSD to display the premiered date when you are watching an episode.
- I added Premiered, Status, Awards, Country, and Writer to Video Info for TV Shows. Thanks to Angelinas for the idea!
Bug fixes
- The title stopped scrolling after about a minute when using Layout 6 in music viz. Thanks to RobinTW for reporting the bug!
- The composition was not displaying in the main menu if you select a Playlist as a Main Menu item. Thanks to gotham_x for reporting the bug!
- The Right List view was not allowing you to navigate if you moved the pointer with a mouse. Thanks to woggs for reporting the bug!
- The modern font was not displaying for the views and Video Info screen when the modern fontset was selected. Thanks to ausvette for reporting the bug!
- Selecting "I" on the keyboard will now toggle on/off the furniture in the music viz screen.
- I fixed a problem with the Smart Shortcuts in the Top Menu. Thanks to fuorigioco1981 for reporting the bug and Angelinas for providing the fix!
Maintenance
- You can now enable/disable the release date/premiere and plot info in the Video OSD with the "MEDIA INFO IN OSD MENU" button in Skin Settings. Thanks to fuorigioco1981 for the request!
2021-01-24, 10:25
thank you for the update!
i have stil problems with skin helper script, also with newest cherypy and skin helper.
is it possible that this is coming from the new emby next gen addon?
found this in emby forum
https://emby.media/community/index.php?/...ent=970914
2021-01-26, 20:16
Hello and thanks a lot for porting aeon mq8 on matrix.
I want to customise the window that temporary appears on live tv on the bottom when we change tv channel.
But I don't find the xml file wich is concerned.
Can you help me ?
Thanks a lot
Can you help me ?
Thanks a lot
2021-01-27, 20:10
Hi latts. Update the skin to v1.0.0.5, the bug reported, the composition was not displayed in the main menu if you select a playlist as the main menu item, it remains so to the previous version. For multiple selected external images, not even activating the selection (Enable global composition) I tried to move the folder containing the images on various paths. Everything remains unchanged with the white stars!
2021-01-30, 22:21
(2021-01-23, 23:45)latts9923 Wrote: [ -> ]Thank you for update #5 ^^UPDATE #5 - This will update the skin to v1.0.0.5
Additions
Bug fixes
Maintenance
2021-02-01, 16:11
1-which prerequisites need to be met in order to display the number of audio channels during playback
2-where to download script.extendedinfo which can be installed in Kodi Matrix RC1 3-where to download script.module.pil which can be installed in Kodi Matrix RC1
2021-02-02, 03:59
2021-02-02, 10:14
It didn't help, but thanks anyway.
2021-02-05, 17:48
UPDATE #6 - This will update the skin to v1.0.0.6
Additions
- I added the Top250 media flag for Movies and TV Shows to the widgets.
- I added a setting to the music viz settings to let you show/hide the furniture when accessing the OSD.
- I added code to use the extrafanart subfolder for a movie first when "EXTRA FANART" is selected. If the folder is missing, it will then use Skin Helper.
- I added code to display animated images for your artists or albums. Thanks to manfeed for the code and the info on how to implement it. (Follow the link to see how to add the settings to advancedsettings.xml. Check page 2 of the thread for links to album images. Place your animated artist or album images in the same folder as your existing artwork for the artist or album. To add your images, go to the info screen for the artist or album, select "GET THUMB", select "animatedthumb", and select your image.)
Bug fixes
- I fixed the Smart Shortcuts so that they display the correct background for the selected item. Thanks to fuorigioco1981 for reporting the bug!
- I removed some info and adjusted the position of the audio and subtitle flags for episodes in Video Info.
Maintenance
- I changed the music viz code to hide the furniture if info or Music OSD is selected. Thanks to RobinTW for the request!
I've added new versions of the Colored Mediaicons, Colored Studio Icons, and White Studio Icons Add-ons to the repo. There were multiple images with invalid characters in the name causing updates to fail when trying to install...that has been fixed with these new versions. Before installing, please uninstall your existing versions and then install the updates via my repo. Any future updates should install just fine after that.
For those that would like to manually download...
Colored Mediaicons update
Colored Studio Icons update
White Studio Icons update
Also, here are some updated colored resolution images...these go in the resources subfolder of the resource.images.resolution.color Add-on.
2021-02-05, 21:54
(2021-02-05, 17:48)latts9923 Wrote: [ -> ]UPDATE #6 - This will update the skin to v1.0.0.6
Additions
Bug fixes
Maintenance
You are admirable!!
my respects
2021-02-06, 14:21
@defleppard
Thanks for the kind words!
2021-02-07, 10:26
thanks for the update
am i the only one who has constant errors with the skin helper addon?
can it be because of the new emby next gen addon?
is anyone else here using the skin with emby server and the emby next gen addon?
