latts9923
At this time, in add-ons skin settings, i miss:
- Rom collection browser (i don't use games but i think some users do)
- Skin Helper Service Widget (i try to install directly from here but nothing happened)
- Netflix (i don't know wich module is and it can't install directly from here)
In my series list (i use Multiplex) there is an alternate background at the bottom, it appeared randomly and it can't be removed, do you know how to do it?
I attch you what i've found in my log (warning and error):
2021-03-04 12:33:13.151 T:25667 ERROR <general>: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/
2021-03-04 12:33:20.209 T:25647 WARNING <general>: script.tv.show.next.aired --> Exception in resources.lib.main_module ! --> 'airtime'
2021-03-04 12:38:01.844 T:25775 ERROR <general>: DoWork - Direct texture file loading failed for resource://resource.images.recordlabels.white/
2021-03-04 12:38:04.115 T:25773 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-03-04 12:38:05.673 T:25767 ERROR <general>: DoWork - Direct texture file loading failed for resource://resource.images.skinthemes.aeonmq/darkness/weather.jpg
2021-03-04 12:38:07.347 T:25765 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_addon.jpg
2021-03-04 12:38:07.909 T:25775 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_games.jpg
2021-03-04 12:38:08.574 T:25767 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_addon.jpg
2021-03-04 12:38:08.795 T:25767 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_system.jpg
2021-03-04 12:38:09.044 T:25765 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_profiles.jpg
2021-03-04 12:38:09.696 T:25765 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_skin.jpg
2021-03-04 12:38:10.832 T:16982 WARNING <general>: Label Formatting: $VAR[addon1102.label] is not defined
2021-03-04 12:38:10.833 T:16982 WARNING <general>: Label Formatting: $VAR[addon1103.label] is not defined
2021-03-04 12:38:16.053 T:25767 ERROR <general>: Read - Error( -4, read call failed with "Command was cancelled" )
2021-03-04 12:38:16.054 T:25767 ERROR <general>: ExtractThumb - Error creating demuxer
2021-03-04 12:40:35.720 T:25764 ERROR <general>: DoWork - Direct texture file loading failed for special://skin/backgrounds/extras/settings_skin.jpg
2021-03-04 12:40:37.162 T:25764 ERROR <general>: DoWork - Direct texture file loading failed for resource://resource.images.recordlabels.white/
2021-03-04 12:41:04.035 T:25764 ERROR <general>: Skipped 1 duplicate messages..
2021-03-04 12:41:04.035 T:25764 ERROR <general>: DoWork - Direct texture file loading failed for resource://resource.images.recordlabels.white/
Have a nice day!
