Using matrix only...no need any addon for it.
(2020-12-08, 19:50)Wanilton Wrote: [ -> ]Using matrix only...no need any addon for it.
Afraid I'm also having problems installing this.
Action:
Clean install of Matrix Beta2.
Downloaded and installed v1.0.0.2 from
https://holybid.com/kodi/repo/matrix/ski...atrix.mod/ as at #1 above
Install hung at "Don't press any key. Wait for the process to finish" - did not get beyond 0%.
Edited guisettings.xml as per #32.
Install still hanging at the "Do not press any key...", 0%.
Don't know what Rar is (#34), and did not install any add-ons (#46).
Subsequently re-tried, installing Cherrypy plus Skin Helper Service as at #1, but SHS failed on a dependency issue.
Grateful for any help as to what I should be doing differently!
Cheers.
(2020-11-22, 18:34)latts9923 Wrote: [ -> ]
latts9923 I'm just testing your MQ8 Mod for Kodi Matrix and everything works so far. Thanks for that. My 1st question: Do I need a special addon for the information in the Movie Set Info? My 2nd question: Does the display of the Oscars in the RightViewList already work? So far none are displayed for me.
latts,
In live TV I always use the guide. Is there anyway to fix live TV so guide comes up by default instead of channels.
ra77
You're welcome! No special Add-on for the Sets Video Info to work. I did have to manually add some artwork that was missing after importing the Movies. The awards and some other info provided by Skin Helper are still not working in Matrix.
rocko
I don't use Live TV, but I'll take a look.
(2020-12-12, 22:41)rocko Wrote: [ -> ]latts,
This is for all AeonMQ skin
Settings - SkinSettings - Main Menu - Custumise Main Menu - Select (from Left List "Live TV") - right arrow "Replace This menu with" - select (from right list "Live TV-Guide", and hit enter)
(2020-12-12, 23:50)Angelinas Wrote: [ -> ] (2020-12-12, 22:41)rocko Wrote: [ -> ]latts,
Thanks for fast reply. That was simple, I never thought it would be that easy.
Thanks again
- I added the Plot info for Sets to display in the Video Info Screen.
- I added the posters and discart of the movies in a Set as well as the focus surround from KodiFlix at the bottom of the Video Info Screen. Selecting the poster will take you to the Video Info screen of the movie.
Hi latts. I wanted to ask you, with which settings it is used and, with which View, to see the information in the Video Info Screen, the multimedia movies Set "Trilogy", if I select the movie set poster from the KodiFlix view and open, only the various films of that trilogy is seen, not the information as per screenshot.
(2020-12-11, 01:34)latts9923 Wrote: [ -> ]@Vitruvius3
If you install my Matrix repo (https://holybid.com/kodi/repo/matrix) and then the Cherrypy script you should be able to install Skin Helper. After that you should be able to install the skin.
Thanks very much for the advice and your work on this skin!
Ran into a succesion of dependency issues on the install, which for info, I eventually fixed by downloading and installing in this order:
script.module.thetvdb v1.0.29
script.module.musicbrainz v0.6.0
script.module.metadatautils v1.0.35 (after updating my copy of its addon.xml file to show the 'required' files as including versions 1.0.29 and 0.6.0 of the above files)
script.module.cherrypy v17.4.2-3
script.skin.helper.service v1.1.31
skin.aeonmq8.matrix.mod v1.0.0.3
I am running Matrix Beta 2 in Windows 10
Thanks again.
gotham_x
That screenshot is the Video Info screen. The context menu does not provide an "INFORMATION" button to access it from a Set, but "I" on the keyboard will open the screen.
Vitruvius3
Thanks for that info. I need to install this from scratch again. I have those Add-ons in my repo, and I need to check if those will install from the repo when they are called for as dependencies.
(2020-12-13, 15:10)latts9923 Wrote: [ -> ]@gotham_x
OK. I was just thinking about a button in the context menu, I didn't get there. However, by pressing I on the keyboard, I have some very very incomplete "INFORMATION", as shown in the screenshot, I have only, Posters and miniature posters of those films that are part of the film set.
https://imgur.com/m68c9GO
gotham_x
I'm pretty sure the plot is pulled from TMDb. You might check
https://www.themoviedb.org and see if the Set has a plot available. I had to manually add the clearlogo, discart, and clearart for the Set.
