2023-09-03 15:18:21.241 T:7505 WARNING <general>: Skin Helper Service --> Exception details: Type: ImportError Value: This platform lacks a functioning sem_open implementation, therefore, the required synchronization primitives needed will not function, see issue 3770. Traceback: Traceback (most recent call last):
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/synchronize.py", line 28, in <module>
from _multiprocessing import SemLock, sem_unlink
ImportError: cannot import name 'sem_unlink' from '_multiprocessing' (unknown location)
During handling of the above exception, another exception occurred:
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/kodi_monitor.py", line 63, in onNotification
self.reset_win_props()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skin.helper.service/resources/lib/kodi_monitor.py", line 129, in reset_win_props
self.metadatautils.process_method_on_list(self.win.clearProperty, self.all_window_props)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.metadatautils/lib/metadatautils.py", line 302, in process_method_on_list
return self._process_method_on_list(*args, **kwargs)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.metadatautils/lib/helpers/utils.py", line 232, in process_method_on_list
pool = ThreadPool()
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/pool.py", line 925, in __init__
Pool.__init__(self, processes, initializer, initargs)
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/pool.py", line 196, in __init__
self._change_notifier = self._ctx.SimpleQueue()
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/context.py", line 113, in SimpleQueue
return SimpleQueue(ctx=self.get_context())
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/queues.py", line 336, in __init__
self._rlock = ctx.Lock()
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/context.py", line 67, in Lock
from .synchronize import Lock
File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/multiprocessing/synchronize.py", line 30, in <module>
raise ImportError("This platform lacks a functioning sem_open" +
ImportError: This platform lacks a functioning sem_open implementation, therefore, the required synchronization primitives needed will not function, see issue 3770.
2023-09-03 15:18:21.241 T:7505 ERROR <general>: Skin Helper Service --> Exception in resources.lib.kodi_monitor ! --> This platform lacks a functioning sem_open implementation, therefore, the required synchronization primitives needed will not function, see issue 3770.
