junkiepilot Wrote:Any fix to get this working with a nightly windows build? I get failed to fetch URL errors on windows, works on atv2 nightly build though...
exobuzz Wrote:debug log please. did you check on the bugtracker first also ?
Here you go...I'm running the latest windows nightly on windows 7.
17:29:32 T:304 NOTICE: -->Python Interpreter Initialized<--
17:29:33 T:304 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
17:29:33 T:304 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
from sets import Set
17:29:33 T:304 NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.13
17:29:33 T:304 NOTICE: .
17:29:33 T:304 NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\xbmc\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
17:29:33 T:304 NOTICE: iplayer2.py: INFO (None, None, None, None, None, None, None, None, None, None)
17:29:36 T:2500 NOTICE: -->Python Interpreter Initialized<--
17:29:37 T:2500 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
17:29:37 T:2500 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
17:29:37 T:2500 NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.13
17:29:37 T:2500 NOTICE: .
17:29:37 T:2500 NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\xbmc\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
17:29:37 T:2500 NOTICE: iplayer2.py: INFO (None, None, None, 'tv', None, None, None, None, None, None)
17:29:39 T:3908 ERROR: XFILE::CFile:
elete - Error deleting file C:\Users\xbmc\AppData\Roaming\XBMC\userdata\Thumbnails\1\19fa4fc9.png
elete - Error deleting file special://masterprofile/Thumbnails/1/19fa4fc9.png
17:29:42 T:2156 NOTICE: -->Python Interpreter Initialized<--
17:29:42 T:2156 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py:8: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
17:29:42 T:2156 ERROR: C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer_search.py:5: DeprecationWarning: the sets module is deprecated
17:29:42 T:2156 NOTICE: iplayer2.py: INFO IPlayer: version: 2.4.13
17:29:42 T:2156 NOTICE: .
17:29:42 T:2156 NOTICE: iplayer2.py: INFO IPlayer: Subtitles dir: C:\Users\xbmc\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.iplayer\Subtitles
17:29:42 T:2156 NOTICE: iplayer2.py: INFO (<iplayer2.feed object at 0x094BD910>, 'list', None, None, None, None, None, None, None, None)
17:29:42 T:2156 NOTICE: iplayer2.py: INFO Read RSS:
http://feeds.bbc.co.uk/iplayer/bbc_one/list
17:29:42 T:2156 NOTICE: iplayer2.py: INFO Feed URL not in cache, requesting...
17:29:42 T:2156 NOTICE: Traceback (most recent call last):
17:29:42 T:2156 NOTICE: File "C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\iplayer2.py", line 161, in httpget
17:29:42 T:2156 NOTICE: resp, data = http.request(url, 'GET')
17:29:42 T:2156 NOTICE: File "C:\Users\xbmc\AppData\Roaming\XBMC\addons\plugin.video.iplayer\lib\httplib2\__init__.py", line 1092, in request
17:29:42 T:2156 NOTICE: info = email.Message.Message()
17:29:42 T:2156 NOTICE: File "C:\Program Files\XBMC\system\python\Lib\email\__init__.py", line 79, in __getattr__
17:29:42 T:2156 NOTICE: __import__(self.__name__)
17:29:42 T:2156 NOTICE: ImportError: No module named message
17:29:44 T:2156 NOTICE: iplayer2.py: ERROR Network Error. Failed to fetch URL
