OK - I was trying to reply to your last reply to me, but this board isn't nested, so it made no sense !
On the "Cancel" issue. I'm using 10.1 on Linux.
If I press "Cancel" whilst the iPlayer app is displaying DialogProgress.xml, the box changes to "iPlayer: Cancelling" and never moves.
The log snippet shows that xbmc is setting the script "Stopping script with id:12", but the script never responds to that request.
The only way to move away from the application is to reboot xbmc.
David
dlake02 Wrote:OK - I was trying to reply to your last reply to me, but this board isn't nested, so it made no sense !
You could try quoting ;-)
A plugin should not be able to freeze xbmc permanently like this, so I would suggest perhaps posting a bug on trac.xbmc.org - I am also unable to reproduce it here.
Hi, I'm having trouble playing live stream, if someone can helps I will really appreciate.
What steps will reproduce the problem?
1.Play any live stream, except the BBC Parliament.
2.
3.
What is the expected output? What do you see instead?
See the live video
Debug log output (
http://pastebin.com/)
http://pastebin.com/0vdhgfU7
What version of the plugin are you using? On what OS?
2.4.8
Please provide any additional information below.
I tried the plugin in two machines with XBMC in different OS Windows and Linux and got the same error.
I can play any non live stream video, but all live streams fails with the debug log attached.
Interesting that the Parliament always works.
I'm using a proxy and I can play the live video on the website and also on the BBC Iplayer desktop.
Any help will be much appreciate.
marcelomanzo Wrote:Hi, I'm having trouble playing live stream, if someone can helps I will really appreciate.
this isn't a debug log btw - you need to enable debugging in xbmc.
also please post full logs - although users often think they know the relevant part, there is often other useful information we need.
you could try switching to akamai stream source, but it looks like the stream source currently used is geolocked. the proxy doesnt proxy rtmp data only the handshake. technically rtmpt (rtmp over http) could support a proxy but librtmp doesnt have any code for this afaik.
Looks like you are right, I tried to connect using the VPN and it works.
Just the proxy it's not enought
Anyone else having issues with this and the nightly build? Fails to load a list of programmes on any channel and when I go back I get a script failed error. Can post a debug log if this is not a known issue (has python version changed on windows nightly build - had script failed error with recentlyadded.py and had to install an additional zip to resolve).
Don't use the nightlies just yet. internal python was removed, along with some changes like getcwd no longer returning the current dir. I have a trac ticket open and am waiting on final guidance regarding the recommended way to do this. as this addon has the same codebase for both xbmc4xbox and xbmc I have to make sure I keep backwards compatibility etc.
http://trac.xbmc.org/ticket/11417
I keep getting an error
'no module named addoncompat'
Running on ubuntu 10.10 with dharma.
Had it running perfectly on my windows build :S
As I said, this is the issue with the nightly builds since removal of internal python and the change of how getcwd words. I would downgrade from the bleeding edge builds or wait until I get a response and adjust the code accordingly (or you can patch it up to get the addon path from the addon if you like).
Hmm, didn't even realize I had a nightly build installed. Installed yesterday through terminal (massive linux noob).
How I can I downgrade easily to a working xbmc?
StealMySoda Wrote:Hmm, didn't even realize I had a nightly build installed. Installed yesterday through terminal (massive linux noob).
what linux distribution / where did you get your xbmc from etc ?
pausing videos; doesn't work. Un pause, vid will play a few secs and xbmc completly freezes. Have to force close with task manager.
02:23:08 T:2616 M:2040455168 INFO: Previous line repeats 1 times.
02:23:08 T:2616 M:2040455168 INFO: HandleInvoke, server invoking <onStatus>
02:23:08 T:2616 M:2040455168 INFO: HandleInvoke, onStatus: NetStream.Pause.Notify
02:23:08 T:2616 M:2040455168 INFO: RTMP_ClientPacket, received: invoke 214 bytes
02:23:08 T:2616 M:2040455168 INFO: (object begin)
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: no-name., STRING: onStatus>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: no-name., NUMBER: 0.00>
02:23:08 T:2616 M:2040455168 INFO: Property: NULL
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: no-name., OBJECT>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: level, STRING: status>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: code, STRING: NetStream.Pause.Notify>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: description, STRING: Pausing secure/1500kbps/MP/b010hwj0_1302960010.mp4.>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: details, STRING: secure/1500kbps/MP/b010hwj0_1302960010.mp4>
02:23:08 T:2616 M:2040455168 INFO: Property: <Name: clientid, STRING: Q2dgMFzu>
02:23:08 T:2616 M:2040455168 INFO: (object end)
02:23:08 T:2300 M:2040492032 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00
02:23:10 T:3812 M:2040528896 DEBUG: Received request to serve 'DeviceDescription.xml'
02:23:15 T:2388 M:2040832000 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
02:23:16 T:2300 M:2040877056 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
02:23:16 T:2300 M:2040877056 INFO: CDVDPlayerVideo - Stillframe detected, switching to forced 25.000000 fps
02:23:16 T:2300 M:2040877056 DEBUG: CPullupCorrection: pattern lost
02:23:18 T:2300 M:2041008128 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00
02:23:19 T:3984 M:2041077760 NOTICE: 'TRAKT: Video found playing'
02:23:19 T:3984 M:2041077760 NOTICE: 'TRAKT: Percentage of progress: 0.0515502428091'
02:23:19 T:3984 M:2041077760 NOTICE: 'TRAKT: continuing to send check'
02:23:20 T:3984 M:2041155584 NOTICE: 'TRAKT: Video is currently paused'
02:23:30 T:4016 M:2041802752 NOTICE: CDVDPlayer::CloseFile()
02:23:30 T:4016 M:2041802752 NOTICE: DVDPlayer: waiting for threads to exit
02:23:31 T:2300 M:2041884672 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
02:23:31 T:2300 M:2041876480 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
02:23:35 T:3984 M:2042093568 WARNING: Previous line repeats 37 times.
02:23:35 T:3984 M:2042093568 NOTICE: 'TRAKT: Resetting last update timestamp'
02:23:35 T:2300 M:2042093568 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
02:23:41 T:4044 M:2042159104 WARNING: Previous line repeats 49 times.
02:23:41 T:4044 M:2042159104 DEBUG: Thread 4044 terminating
02:23:41 T:2300 M:2042155008 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
02:23:50 T:3984 M:2042179584 WARNING: Previous line repeats 84 times.
02:23:50 T:3984 M:2042179584 NOTICE: 'TRAKT: Resetting last update timestamp'
02:23:50 T:2300 M:2042179584 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
02:24:05 T:3984 M:2042130432 WARNING: Previous line repeats 134 times.
02:24:05 T:3984 M:2042130432 NOTICE: 'TRAKT: Resetting last update timestamp'
02:24:06 T:2300 M:2042130432 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
02:24:31 T:1008 M:2042961920 WARNING: Previous line repeats 228 times.
02:24:31 T:1008 M:2042961920 NOTICE: ES: Client from 127.0.0.1 timed out
02:24:31 T:2300 M:2042961920 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
is there a fix for this? plugins shouldn't lock up the whole lot using a basic function.
Death-Axe Wrote:pausing videos; doesn't work. Un pause, vid will play a few secs and xbmc completly freezes. Have to force close with task manager.
This has been reported in this thread many times and the answer is it's an XBMC problem.
StealMySoda Wrote:I keep getting an error
I have the same problem on 2 machines (an Aspire R3700 and a AMD 785/Athlon rig).
iplayer2 plugin was working fine on XBMC Dharma on top of Ubuntu 10.10. Applied some Ubuntu patches over the weekend on the R3700 and iplayer2 plugin stopped working ('no module named addoncompat').
On AMD785/Athlon rig (Dharma + Ubuntu 10.10), I checked and iplayer2 plugin was working OK, but applying same patches made the plug-in break on this machine as well.
Unfortunately, I didn't make a note of what packages were changed, although I do remember 2 packages were deleted. I'm a Linux newbie, so I don't know how to back out the Ubuntu 10.10 changes.
Plugin version: IPlayer-v2.4.8.zip
Other plug-ins on XBMC still work fine.
Anyone have the playback, just stop randomly? It's like it was ages ago where the video would play for a bit then just stop.
Not sure if the BBC site has changed something, as it was working about 2/3 weeks ago.
Revo, windows 7 & XBMC 10.1
