(2014-11-02, 20:08)shambles1980 Wrote: [ -> ]hi you must be doing it wrong..
You should make sure you follow the instructions 100%
You need to install the repo from the zip file.
then leave that section and go to "get addons"
so go back to the main window
then click on system (not one of the options below it
then select get add ons
Then select the infinity repo
then you can get the iplayer.
as for the live streams
the 2.5.9 version we were using still works for live streams "well it works again today" it stoped working yesterday for a while.
You still cannot use it for catch up though, so use the 0.0.3 for the catch ups.
Yes, I did that.
The plugin is loaded.
It apparently partially works. It shows menus that enable me to select a program,
then goes to a menu of different feeds.
When I select one, I get "One or more items failed to play. Check the log for details."
In the log, I see this:
10:14:34 T:2817520704 NOTICE: -->Python Interpreter Initialized<--
10:14:35 T:2817520704 NOTICE: Mode: 5
10:14:35 T:2817520704 NOTICE: URL:
http://www.bbc.co.uk/iplayer/episode/b04...-episode-4
10:14:35 T:2817520704 NOTICE: Name: Autumnwatch, 2014: Episode 4 - [COLOR orange](5 Available)[/COLOR]
10:14:35 T:2817520704 NOTICE: IconImage:
http://ichef.bbci.co.uk/images/ic/832x468/p02948dl.jpg
10:14:37 T:2817520704 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.HTTPError'>
Error Contents: HTTP Error 403: Forbidden
File "/home/pi/.xbmc/addons/plugin.video.bbciplayer/default.py", line 371, in <module>
GetPlayable(name,url,iconimage)
File "/home/pi/.xbmc/addons/plugin.video.bbciplayer/default.py", line 175, in GetPlayable
html = OPEN_URL(NEW_URL,True)
File "/home/pi/.xbmc/addons/plugin.video.bbciplayer/default.py", line 251, in OPEN_URL
response = urllib2.urlopen(req)
File "/usr/lib/python2.7/urllib2.py", line 127, in urlopen
return _opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 407, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 520, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 445, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 379, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 528, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 403: Forbidden
10:14:37 T:3037573920 ERROR: GetDirectory - Error getting plugin://plugin.video.bbciplayer/?IPID=b0079t1p&description=%20It%20is%20Halloween%2c%20so%20this%20edition%20is%20all%20about%20the%20creatures%20of>
10:14:37 T:3037573920 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.bbciplayer/?IPID=b0079t1p&description=%20It%20is%20Halloween%2c%20so%20this%20edition%20is%20all%20about%20the%20creatures%20o>
10:14:37 T:2817520704 NOTICE: Thread BackgroundLoader start, auto delete: false
10:14:46 T:2817520704 NOTICE: Thread LanguageInvoker start, auto delete: false
