(2014-05-19, 19:59)bigsteel99 Wrote: [ -> ]Hey Luna I double check everything including dependencies, i'm using your version of ustvnow 9.9.9, youtube 4.4.6, only the rss feed and super favorites works in auto tune. I'm using Gotham 13.1 beta 1 and PSTVL 3.9. Log http://xbmclogs.com/show.php?id=203030
Whats the issue? I missed your last question... if it's about ustvnow not working fix coming tonight...
Sorry to post this in 2 different posts but I really need some help... thanks in advance.
Does anyone know why Pseudo TV does not play my MP4 files?... well some of them... I ripped some music files (MP4 high quality)
My files work ok from the "files" section.
but when I add to one channel the mp4 files the channel does not work... (also it doesn't appear on the channel list)
PS my filenames have this character "_" could that be the issue (well I have other channels with "_" and work ok... so these files have another issue... the problem is that I don't get any message on the screen)
I have Frodo
(2014-05-19, 18:37)Lunatixz Wrote: [ -> ] (2014-05-19, 17:12)ianuk2005 Wrote: [ -> ]Never mind I found the options but it seems the main one i'm interested in "STRM Duration tweaks" doesn't work correctly.
All my episodes and movies have a duration of 1 hour in psuedotv live no matter what. I'm using GoMovies and GoTv which don't generate nfo's. I tried using tinyMediaManager to generate nfo's for all the movies in the directory they are in but the problem persists.
I use those plugins without a problem and have correct durations...
My tweak works fine, didn't say it would correct your problem! it helps avoid duration issues.
Perhaps you have hide short videos enabled? and have BCT's enabled?
PseudoTV Live doesn't make up strm durations... it either gets it from the nfo directly or by xbmc library if the media was scraped... if both fail then it creates a show with 3600 second duration.
If you have one of the two above enabled well that's why shows appear longer then they are... Its been mentioned a number of times that hide short videos... hides short videos (ie bcts). The hidden shows duration is filled with the previous show info (making it appear larger the it is).
Thanks for the reply I have both of the options turned off and tried a fresh install of psuedotv live to setup again. I grabbed this from the m3u files in the cache which seems to be showing the movies are set to 3600 duration:
#EXTINF:3600,Toy Story//The adventure takes off!//Woody the cowboy is young Andy’s favorite toy. Yet this changes when Andy get the new super toy Buzz Lightyear for his birthday. Now that Woody is no longer number one he plans his revenge on Buzz. Toy Story is a milestone in film history for being the first feature film to use entirely computer animation.//Movie////imdb_tt0114709|NA|NA|dbid_579,movie|
smb://IAN-SERVER/XBMC/GoMovies/Toy Story (1995)/Toy Story (1995).strm
The Movies/Shows all have the correct run times in the xbmc library and I have added additional nfo;s using tiny media manager to the location of the strms. I'm using frodo 12.3 and mysql if that helps any?
If you can give me any pointers to debugging this and finding out where it's falling over would be greatly appreciated.
(2014-05-19, 21:01)ianuk2005 Wrote: [ -> ] (2014-05-19, 18:37)Lunatixz Wrote: [ -> ] (2014-05-19, 17:12)ianuk2005 Wrote: [ -> ]Never mind I found the options but it seems the main one i'm interested in "STRM Duration tweaks" doesn't work correctly.
I'll make another small adjustment, but not sure why I'm not having this issue... My strms for that plugin have no nfo and are scraped...
Git updated, force channel reset let me know how it works...
::update::
I think something changed in the gotham rc, Need to check it out, I"ll get back to you about your problem...
(2014-05-19, 21:10)Lunatixz Wrote: [ -> ] (2014-05-19, 21:01)ianuk2005 Wrote: [ -> ] (2014-05-19, 18:37)Lunatixz Wrote: [ -> ]I use those plugins without a problem and have correct durations...
::update::
Eureka! That worked:
#EXTINF:4860,Toy Story//The adventure takes off!//Woody the cowboy is young Andy’s favorite toy. Yet this changes when Andy get the new super toy Buzz Lightyear for his birthday. Now that Woody is no longer number one he plans his revenge on Buzz. Toy Story is a milestone in film history for being the first feature film to use entirely computer animation.//Movie////imdb_tt0114709|NA|NA|dbid_579,movie|
Out of interest what did you change?
Lunatixz, was wondering if you had anymore thought into the below. I see the option for hide short videos, but all i get is a bunch of dots in the EPG.
(2014-05-15, 19:33)Lunatixz Wrote: [ -> ] (2014-05-15, 19:18)scooper750 Wrote: [ -> ]Quick questions. What's the difference between using a Youtube channel vs Youtube Playlist.
I've got a few youtube channels, but the EPG is too crammed for the channels.
Is there a way to make it so that the EPG simply says name of the channel instead of trying to fill in the EPG.
The EPG is unreadable for many of my youtube channels
I've debated how to handle short youtube videos, I hate having ... in the epg as wel.
I could add an option to hide all the ... (short videos) with the name of the channel, i'll look into it.
Another quick question, I'm sure it's not possible atm but I have some playlists that have tons of episodes for one show and not as many for other shows. If I have it ordered random and set to only play a show one episode in a row i'd get for example show: ABACADABABDAC
so the epg is populated with a lot from show A and not many from show B,C or D.
If there a way to get it to go like show ABCDABCDABCD
(2014-05-19, 22:17)ianuk2005 Wrote: [ -> ]Another quick question, I'm sure it's not possible atm but I have some playlists that have tons of episodes for one show and not as many for other shows. If I have it ordered random and set to only play a show one episode in a row i'd get for example show: ABACADABABDAC
There is already a rule for this...
(2014-05-19, 20:18)Lunatixz Wrote: [ -> ] (2014-05-19, 19:59)bigsteel99 Wrote: [ -> ]Hey Luna I double check everything including dependencies, i'm using your version of ustvnow 9.9.9, youtube 4.4.6, only the rss feed and super favorites works in auto tune. I'm using Gotham 13.1 beta 1 and PSTVL 3.9. Log http://xbmclogs.com/show.php?id=203030
Ustvnow was one of the problems, the other is the youtube channels are not auto tunning, only rss feeds and super favorites works for me.
I use Amber as my default skin. The problem i'm having is that when I launch PTVL and click Enter to bring up the EPG it comes up without any issues. The problem is that I can't bring up the EPG again. The next time when I try to bring up the EPG. All I get is XBMC's playback controls. This issues is seems to be only with the Amber skin since I decided to load up Confluence and the issue doesn't affect that skin.
http://xbmclogs.com/show.php?id=205574
EPG
No EPG
(2014-05-20, 01:29)gonzo90017 Wrote: [ -> ]I use Amber as my default skin. The problem i'm having is that when I launch PTVL and click Enter to bring up the EPG it comes up without any issues. The problem is that I can't bring up the EPG again. The next time when I try to bring up the EPG. All I get is XBMC's playback controls. This issues is seems to be only with the Amber skin since I decided to load up Confluence and the issue doesn't affect that skin.
EPG
No EPG
You need to bring the issue up with the Amber creator...
Lunatixz
Getting errors on creating channels for certain live tv channels.
03:38:01 T:140257737672448 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: invalid literal for int() with base 10: 'I316.751025.microsoft.com'
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Overlay.py", line 289, in onInit
if self.readConfig() == False:
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Overlay.py", line 407, in readConfig
self.channels = self.channelList.setupList()
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/ChannelList.py", line 158, in setupList
self.setupChannel(i + 1, False, makenewlists, False)
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/ChannelList.py", line 512, in setupChannel
if self.channels[channel - 1].setPlaylist(CHANNELS_LOC + 'channel_' + str(channel) + '.m3u') == True:
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Channel.py", line 48, in setPlaylist
return self.Playlist.load(filename)
File "/home/declan/.xbmc/addons/script.pseudotv.live-master/resources/lib/Playlist.py", line 217, in load
tmpitem.duration = int(line[8:index])
ValueError: invalid literal for int() with base 10: 'I316.751025.microsoft.com'
(2014-05-18, 16:37)Lunatixz Wrote: [ -> ] (2014-05-18, 11:26)abele Wrote: [ -> ]I did a fresh XBMC install on my AppleTV 2 using Frodo as most plugins dont seem to be supporting Gotham yet. I downloaded the master.zip file from the first post and did an install from zip in XBMC. Next, I went to my Add Ons, opened the PseudoTV Live settings, went to Debugging and enabled it for better logging and started the Addon.
At first, things look promising. I see it starts the Auto Tuning process, I see it going through a variety of Youtube channels and then at 55% it crashes
This is my xbmc.log tail:
17:18:07 T:195162112 NOTICE: -->Python Interpreter Initialized<--
17:18:08 T:195162112 NOTICE: script.pseudotv.live PseudoTV Live /var/mobile/Library/Preferences/XBMC/addons/script.pseudotv.live-master 0.3.9
17:18:08 T:195162112 NOTICE: script.pseudotv.live-Globals: System Caching Enabled
17:18:10 T:195162112 NOTICE: script.pseudotv.live-ChannelList: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
17:18:11 T:195162112 NOTICE: Donor Import Failed, Disabling Donor FeaturesNo module named Donor
17:18:12 T:195162112 ERROR: /var/mobile/Library/Preferences/XBMC/addons/script.pseudotv.live-master/resources/lib/Overlay.py:146: DeprecationWarning: object.__init__() takes no parameters
xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs)
17:18:12 T:195162112 ERROR: /var/mobile/Library/Preferences/XBMC/addons/script.pseudotv.live-master/resources/lib/Overlay.py:50: DeprecationWarning: object.__init__() takes no parameters
xbmc.Player.__init__(self, xbmc.PLAYER_CORE_AUTO)
17:18:12 T:195694592 NOTICE: -->Python Interpreter Initialized<--
Absolutely love, love, love the potential of this addon and appreciate all the amazing work you're putting into this!
Appreciate your thoughts on what might be causing this!
Full log would have been nice...
As requested:
http://xbmclogs.com/show.php?id=205671
Please note this is my most recent log. I was able to start up PseudoTV Live once, then it crashed. After that, it just stays on the Addons screen and after a few seconds it will crash. This is a full debug log after the crash happened. Thanks in advance!
Live tv artwork question:
This is an example of a m3u live channel created from PLTV:no artwork
#EXTINF:3600,PERSON OF INTEREST//LiveTV//..plot......//Unknown//2014-05-21 21:00:00//NA|NA|NA|OLD,tvshow|
pvr://channels/tv/All TV channels/3.pvr
I can edit it and add the title of the show:
#EXTINF:3600,PERSON OF INTEREST//LiveTV//..plot.......//Unknown//2014-05-21 21:00:00//NA|PERSON OF INTEREST|NA|OLD,tvshow|
So I have downloaded an image, named it "PERSON OF INTEREST-landscape" and put it in cache/artwork folder.That thing works fine.
Is it possible to auto search in the cache/artwork folder and find the exact name and not do this manually?
(2014-05-19, 23:21)Lunatixz Wrote: [ -> ] (2014-05-19, 22:17)ianuk2005 Wrote: [ -> ]Another quick question, I'm sure it's not possible atm but I have some playlists that have tons of episodes for one show and not as many for other shows. If I have it ordered random and set to only play a show one episode in a row i'd get for example show: ABACADABABDAC
Can you give me some more details on what rule will do that? I have my playlists set to random and the channel rule to only show one episode in a row and it will still go for example show ABACAC and not show ABCABC
