2020-11-13, 21:04
Aeon MQ 8 Matrix Mod v1.0.3.5 for Kodi v19 "Matrix"
Installation Guide
Optional Add-ons (Some available to install from my repo)
Skin download (For those who would like to manually download the skin)
Automated Skin Settings
Updates
11/22/20 - Skin update v1.0.0.1. Read here for more info.
12/05/20 - Skin update v1.0.0.2. Read here for more info.
12/12/20 - Skin update v1.0.0.3. Read here for more info.
12/30/20 - Skin update v1.0.0.4. Read here for more info.
01/23/21 - Skin update v1.0.0.5. Read here for more info.
02/05/21 - Skin update v1.0.0.6. Read here for more info.
02/13/21 - Skin update v1.0.0.7. Read here for more info.
02/21/21 - Skin update v1.0.0.8. Read here for more info.
03/21/21 - Skin update v1.0.0.9. Read here for more info.
04/10/21 - Skin update v1.0.1.0. Read here for more info.
04/30/21 - Skin update v1.0.1.1. Read here for more info.
05/23/21 - Skin update v1.0.1.2. Read here for more info.
07/02/21 - Skin update v1.0.1.3. Read here for more info.
09/06/21 - Skin update v1.0.1.4. Read here for more info.
11/23/21 - Skin update v1.0.1.5. Read here for more info.
12/21/21 - Skin update v1.0.1.6. Read here for more info.
01/14/22 - Skin update v1.0.1.7. Read here for more info.
01/22/22 - Skin update v1.0.1.8. Read here for more info.
02/10/22 - Skin update v1.0.1.9. Read here for more info.
02/25/22 - Skin update v1.0.2.0. Read here for more info.
02/26/22 - Skin update v1.0.2.1. Read here for more info.
03/19/22 - Skin update v1.0.2.2. Read here for more info.
04/02/22 - Skin update v1.0.2.3. Read here for more info.
06/11/22 - Skin update v1.0.2.4. Read here for more info.
08/28/22 - Skin update v1.0.2.5. Read here for more info.
09/03/22 - Skin update v1.0.2.6. Read here for more info.
09/18/22 - Skin update v1.0.2.7. Read here for more info.
10/08/22 - Skin update v1.0.2.8. Read here for more info.
10/30/22 - Skin update v1.0.2.9. Read here for more info.
11/12/22 - Skin update v1.0.3.0. Read here for more info.
11/25/22 - Skin update v1.0.3.1. Read here for more info.
12/10/22 - Skin update v1.0.3.2. Read here for more info.
12/19/22 - Skin update v1.0.3.3. Read here for more info.
01/02/23 - Skin update v1.0.3.4. Read here for more info.
01/21/23 - Skin update v1.0.3.5. Read here for more info.
Installation Guide
- Install my repo (https://holybid.com/kodi/lattsrepo/maste....lattsrepo)
- Install the Marcelveldt repo (https://github.com/kodi-community-addons...-1.0.3.zip)
- Install Skin Helper Service from the Marcelveldt repo (located in Context Menus)
- Install ExtendedInfo Script from my repo (located in Program add-ons)
- Install Aeon MQ 8 for Matrix from my repo (located in Look and Feel > Skin)
- When you access Skin Settings, Kodi will prompt you to install the Skin Helper Service Colorpicker add-on.
- While you are in Skin Settings, scroll down to Add-ons. This will show the installation status of additional add-ons that MQ 8 uses. Select "Install All Add-ons Now (Selective Mode)" and you can choose one at a time which add-ons you would like to install.
- Install the optional Add-ons below...
- Aeon MQ Skinthemes
- Additional Aeon MQ themes (You can copy these themes from this file into the Aeon MQ Skinthemes Add-on after it is installed)
- Artwork Helper v0.9.2
- Colored Flag Add-ons
- Colored Media Icons v0.3.0
- Library Editor v3.0.0
- Skin Info Service v1.1.2
- TV Show - Next Aired v8.0.1
- TVTunes v2.0.4 (There is still a problem with the video themes not stopping once they begin to play and you select another Movie.)
Updates
