Good day guys,
Must say awesome skin/mod..
I have a question, I don't know if it's possible as maybe I'm overlooking something with custom menus.
Can I add a widget to a menu and make it multiple lines?
So if I only want one widget to a specific menu could I have it scroll down instead of the standard one line scroll sideways?
I'm new to the mod and surely can be overlooking or missing how to do this..
(2016-08-17, 00:17)tfraley Wrote: [ -> ]Good day guys,
You can configure items menu and widgets like you want. If you want just one row for widgets and scroll to have others you need to use horizontal advanced menu.
By default the epg is very small and doesn't show channel logos. Are there any plans to make some of this configurable in the future?
Thank you for the excellent skin.
Sent from my Nexus 6
A while back I wanted to do the same thing as you. One widget, say "Recently Added Movies" that fills the screen with posters and you can scroll down like you would in the poster library view. Defiantly not possible as is unless Guilouz adds that functionality.
(2016-08-17, 14:48)Hardax Wrote: [ -> ] (2016-08-17, 00:17)tfraley Wrote: [ -> ]Good day guys,
Thanks buddy, At least I know that I'm not overlooking something..
Hey guys,
So I have Estuary Mod running on AppleTV as well an iMac and MacBook pro
I have custom menus setup with widgets pointed to addons
Example..
Movies
widget goes to addon - trending moves
A few more widgets
TVShows
widget goes to addon - trending tv shows
A few more widgets
Now the issue is with lag really.
When I go though the menu items (ie movies/tv shows)
I can see the widgets titles change, however, it could take 4-10 seconds before the posers load in the widgets.
At first, I thought maybe it was may AppleTV but I have since installed on my iMac and MacBook with same results
is this normal.. local library posters load instantly but that's expected because posters are downloaded,
I guess I'm looing to see if this is working as expected or if some kinda of bug or error creating longer poster loads.
thanks in advance
(2016-08-17, 21:35)tfraley Wrote: [ -> ]Hey guys,
Example..
Movies
A few more widgets
TVShows
A few more widgets
thanks in advance
Normal, trending movies/tv shows are contents from internet, depends of your internet connection.
(2016-08-17, 21:39)Guilouz Wrote: [ -> ] (2016-08-17, 21:35)tfraley Wrote: [ -> ]Hey guys,
Example..
Movies
A few more widgets
TVShows
A few more widgets
thanks in advance
Gottch thats what I figured.
But the delay dosn't seeem so bad in the addon it self..
But that you for the comfimation.
It's just hindering how I want to set things up
New Update 1.5.3 on repository :
• Add aired time, season and episode number for next aired widget
• Add fallback music disc (Thanks emiralles)
• Add possibility to delete / add more one rule for smartplaylist
• Improve esthetic appearance
• Fix media settings icon
• Krypton : Update DialogGameControllers.xml
• Krypton : Show playspeed on video OSD
Can no longer change TV channels while full screen using the up and down arrows and OK with latest build.
Still works program CH +/-
(2016-08-17, 22:40)elchupete Wrote: [ -> ] (2016-08-17, 18:22)tfraley Wrote: [ -> ]Thanks buddy, At least I know that I'm not overlooking something..
Try using the HUB Widget
Thanks, Just tried it again it doesn't seem to make a difference in load times for me.
(2016-08-17, 23:42)bmonster Wrote: [ -> ]Hi,
Not a skin issue, I did not touch to TV part.
Envoyé de mon iPhone en utilisant Tapatalk
