(2016-10-18, 19:48)Gracus Wrote: [ -> ] (2016-10-18, 19:36)schumi2004 Wrote: [ -> ]@Guilouz
Would you like to consider adding this Font.xml to your MOD?
I added a extra fontset that is slightly bigger then the default and makes it a bit better to read in certain situations.
https://www.dropbox.com/s/n61fgmavofv0od1/Font.xml?dl=0
Your request was not followed by estuary devs so you try to have it here...
I will just send you to your own solution: http://forum.kodi.tv/showthread.php?tid=...pid2421545
Not my MOD so not my choice but it was just my two cents...
I don't care if Estuary devs wont add it. It's just something i personally use and and others would like to see this as well and since this is a modded version it won't harm asking
Replacing that file after every upgrade isn't that fun and it would be more user friendly (for me atleast) if it was build in and maybe others can profit from it also
If Guilouz decides not to include it's fine by my, it was just a question and i'm forcing nobody.
/edit:
Can't recall i requested this tbh, i just gave my opinion i would like to see this also like all others in that thread but if they don't it's good also.
(2016-10-18, 16:23)Raabi2208 Wrote: [ -> ]Hello Guilouz,
the icons i´ve maded - at that time - are for testing. Because i wanted the menue to look like that: Action Animation Children Adventure ...
So i created a "Indiana Jones - Icon with hat and whip" but these icons are not only white like yours, i dont think they would fit to your standard icons.
Therefore it would be great if i could use a own folder so that i can test similar icons.
Thanks a lot
Not possible to do that. Thumbnails for skin shortcuts must be pointing to a folder :
https://github.com/BigNoid/script.skinsh...mbnails.md
Hey.
I have a small question. So I am using this skin now, but I am not quite sure how I can use the widgets right. I created a Favorite for my Cartoons and TV shows seperately. Then I add a new Custom Home Button for that and want to add a widget that shows the In-Progress TV Shows and another one for the In-Progress Cartoons, same with recently added episodes etc.
If I choose the normal widget I just get ALL files considered as TV-Shows, so in the Cartoon section I can see the TV shows and in the TV show section I can see the cartoons.
Anyone knows how I can configure the widget or create a widget that will only shows the types in special folders?
(2016-10-19, 00:01)Sharillon Wrote: [ -> ]Hey.
You must create 4 smart playlists for each custom home menu and add them as widgets.
Your tv shows and cartoons must not be in same folder.
Recently added for your tv shows folder
Recently added for your cartoon folder
In progress for your tv shows folder
In progress for your cartoon folder
See that :
http://kodi.wiki/view/smart_playlists
Envoyé de mon iPhone en utilisant Tapatalk
I created a smart playlist for each type now, but sadly I dont know how to add them as widgets
(2016-10-19, 00:31)Sharillon Wrote: [ -> ]I created a smart playlist for each type now, but sadly I dont know how to add them as widgets
Just choose a Customizable widget and select your smart playlist.
(2016-10-18, 20:46)Guilouz Wrote: [ -> ] (2016-10-18, 19:36)schumi2004 Wrote: [ -> ]@Guilouz
No problem. I will add it
Thanks Guilouz, your efforts are much appreciated and thanks for considering requests in the most accommodating fashion, you really have made Estuary MOD = Kodi 17.5.
Can you add custom hub? Currently there are only 3 which is not enough.
thenks
forgive me if i'm posting in the wrong place-
i noticed that i am unable to swipe to scroll in the TV widgets on my android phone (i didn't discover this problem until i started using estuary mod). on my pc i am able to use the scroll wheel to cycle through shows in widgets.do any of you nice folks know a workaround for this?? thanks so much.
