hello I can not do update to version 1.3.12, in repository i find 1.3.11
help me and excuse for bad english
very beautiful skin compliments
byez from italy
(2016-07-28, 08:22)lucamolfino Wrote: [ -> ]hello I can not do update to version 1.3.12, in repository i find 1.3.11
byez from italy
Do a force refresh on guilouzs repo. It should than automatically download the newest version.
why I cannot see all the default menu items on the homescreen?
(2016-07-28, 05:57)dnlg Wrote: [ -> ]Thanks for the update
But, widgets are showing posters stretched out instead of fanart.
No problem for me (see screenshots)
What widget you use ?
(2016-07-28, 06:52)capnhowyoudo Wrote: [ -> ] (2016-07-25, 12:29)Guilouz Wrote: [ -> ] (2016-07-25, 05:59)capnhowyoudo Wrote: [ -> ]Is there a way to turn off "force refresh" on widgets on the home screen when they are pulling from a third party addon ?
I will see what can I do.
The reason I ask is that when using the a third party addons catagories for a home screen widget it seems to take about 10 secs to load that widget every time you choose a different left pane category. I noticed that the Titan Skin had that option to toggle off the auto refresh for home widgets, is there some where I can look to find that within the XML to narrow down the search so you maybe able to implement such a feature ?
I will take a look at titan skin to see what can I do.
(2016-07-28, 14:54)noah1 Wrote: [ -> ]
Home menu show only items if you have content for each of them.
Envoyé de mon iPhone en utilisant Tapatalk
(2016-07-28, 14:58)Guilouz Wrote: [ -> ] (2016-07-28, 05:57)dnlg Wrote: [ -> ]Thanks for the update
Same here. Using stretched out posters instead of fanart. The widgets affected are "Unwatched TV shows" and "In progress TV shows" maybe others.
(2016-07-28, 15:49)woodside Wrote: [ -> ] (2016-07-28, 14:58)Guilouz Wrote: [ -> ] (2016-07-28, 05:57)dnlg Wrote: [ -> ]Thanks for the update
Tv show widgets use landscape and fanart (if no landscape is available) and thumb for episodes.
Download landsape with artwork downloader and retry
another problem: it is not possible to launch sub menu addons:
16:21:26 T:4596 ERROR: Window Translator: Can't find window videolibrary
16:21:26 T:4596 ERROR: Activate/ReplaceWindow called with invalid destination window: VideoLibrary
(2016-07-28, 16:22)noah1 Wrote: [ -> ]another problem: it is not possible to launch sub menu addons:
You have not latest skin shortcuts addons or addon you use is not updated with latest krypton changes.
(2016-07-28, 16:09)Guilouz Wrote: [ -> ] (2016-07-28, 15:49)woodside Wrote: [ -> ] (2016-07-28, 14:58)Guilouz Wrote: [ -> ]No problem for me (see screenshots)
Downloading 16:9 thumbs did the trick. However, shouldn't it default to use fanart instead of stretched out posters when no 16:9 thumbs are available? Or am I just missing something?
(2016-07-28, 14:59)Guilouz Wrote: [ -> ] (2016-07-28, 06:52)capnhowyoudo Wrote: [ -> ] (2016-07-25, 12:29)Guilouz Wrote: [ -> ]I will see what can I do.
Thanks, i had downloaded the master zip last night and started going through all the xml files but i just was unsure on where to begin looking. lol.
Hi Guilouz,
this time skin autoupdated :-)
I deactivated and reactivated Autoupdate setting for Kodi, Repo and Skin yesterday. perhaps that did the trick.
Thanks for the update.
