Guilouz ,hi!
im using your skin and it is fantastic.
but i have an issue,when i watch tv with iptv simple
i get a message on the lower right side in a box that says "to be continue" and the only way to make it disapear i have to change the channel.
and then go back to the original channel.
i searched in skin settings how to disable that message but i didnt find how..
can you pleassssse help to get rid that message?
thank you for help
(2017-01-24, 03:22)jeks Wrote: [ -> ] (2017-01-23, 05:01)jeks Wrote: [ -> ]Seems to have a problem with Tv Tunes addon... When I enter TV SHOW section it starts to play theme immediatly and doesn't display any fanart on the background (probably because it's like playing a song...). Tv Tunes is configured to only play then WHEN I enter in a specific tv show, not directly on the first menu where I can select a show.
Original Estuary skin doesn't have this issue and it displays Fanarts correctly even if theme is playing.
Thank You
Nobody use Tv Tunes except me?
I don't use it but I will try to see.
(2017-01-24, 05:00)Blurayx Wrote: [ -> ]Hi Guilouz,
When I enable extrafanarts, Fanarts for TV shows, Episodes Airing Today disappears when I Quit/restart kodi
Before Quitting kodi
After restarting kodi
I noticed this a few versions back on my iMac & Shield TV.
Also a few threads back I mentioned all the TV Shows are displaying the same dates. is it a skin or skin helper issue
Yes I have same issue, extrafanarts seem to not work with widgets from Skin Helper Service.
My code is correct, example for airing tv shows :
<value condition="Skin.HasSetting(SkinHelper.EnableExtraFanart) + !String.IsEmpty(Window(home).Property(SkinHelper.ListItem.Art.ExtraFanArt)) + Control.HasFocus(6500)">$INFO[Window(home).Property(SkinHelper.ListItem.Art.ExtraFanArt)]</value>
<value condition="Skin.HasSetting(SkinHelper.EnableExtraFanart) + String.IsEmpty(Window(home).Property(SkinHelper.ListItem.Art.ExtraFanArt)) + Control.HasFocus(6500)">$INFO[Container(6500).ListItem.Art(fanart)]</value>
<value condition="!Skin.HasSetting(SkinHelper.EnableExtraFanart) + !String.IsEmpty(Container(6500).ListItem.Art(fanart)) + Control.HasFocus(6500)">$INFO[Container(6500).ListItem.Art(fanart)]</value>
When extrafanarts are enable and available -> Show extrafanarts
When extrafanarts are enable and not available -> Show fanart
When extrafanarts are disable -> Show fanart
(2017-01-24, 09:12)ilancoll Wrote: [ -> ]RTL view please
I do not plain to do this.
(2017-01-24, 12:14)totlip Wrote: [ -> ]Guilouz ,hi!
thank you for help
Anyone have this issue ?
You can disable it in skin settings / Video OSD / and disable 'Enable Next Up popup for Live TV'
Salut Guilouz!
First at all, congratulations for your job and I love so much this level of customization offered by your skin.
I use this skin, overall, to customize my main menu and then I can create custom items for my son.
I managed to make items for his movies, his TV Shows and his Music using smartlists.
However, I want to do the same with TV Live section and I have a problems ...
I did a group channel called "KidsChannelsTV" and I can change the channel group in the TVChannels widget with any problem but .... now I don't know how I can setup a shortcut to this channel group.
If I create a menu item which point to a channel tv and in the setup screen of the menu item it appears a "pvr-channel://99". And now I want to do the same with a channel group of pvr channels.
I hope do you understand exactly my question.
Á bien tôt !!
Numerikus
Extended info script gives me error on the latest 18 nightlies!
(2017-01-24, 03:22)jeks Wrote: [ -> ] (2017-01-23, 05:01)jeks Wrote: [ -> ]Seems to have a problem with xxx addon... When I enter TV SHOW section it starts to play theme immediatly and doesn't display any fanart on the background (probably because it's like playing a song...). xxx is configured to only play then WHEN I enter in a specific tv show, not directly on the first menu where I can select a show.
Thank You
Nobody use xxx except me?
Please be aware, the the named add on is banned.... So please do not refer to it to avoid banning of this thread.
@Guilouz: The issue might be related to the changes I pushed a while back when banned add-on did not supported Kodi 17
Hi Guilouz,
I reported Episodes Airing Today widgets displaying a day ahead to marcelveldt.
can you please test if you're having the same issue.
This skin isn't compatible with the latest nightly and gets disabled :/
Is this something I can install without a computer? I usually do all of my updates/installs from the firetv box itself. Thanks!
