ok, changed scrapper and rescrapped all, now it seems to be fine...
how good that there is trakt.tv^^
Only issue now: On some movies the codec infos aren´t shown^^...
And thanks!
(2016-12-30, 16:21)junias Wrote: [ -> ]ok, changed scrapper and rescrapped all, now it seems to be fine...
And thanks!
Glad it works for you now!
Where do you have issue with codec infos? Home widgets? Library?
If it's in home widgets, it also happen to me from time to time after a fresh install
Best way I have found:
-go in library and put your mouse on the issued movie
-wait a few seconds to have the codec infos loaded
-go back to home
-click on the power button and select "reload skin"
Installed the Global Search addon for, well, searching stuff.
I did an initial search, got 0 results, and then was stuck on an empty results screen.
None of the normals keys worked, such as ESC and BackSpace. I finally had to do ALT-F4 to really escape.
Is the whole Search box thing still a "work-in-progress" ?
(Ubuntu 14.04.5 / Kodi 17 RC / EstuaryMOD 1.7.3)
Hi Guilouz,
Just saw a little thing and do not know if it is an issue or an expected behaviour
For Star Wars movie set, I change the poster of the last movie (want it to be the same as the others) and the ordering (from year to name) to have them in the good order (1 first and 7 last):
But at the movie set level, the mini poster on the bottom right still show the old poster and the original ordering (by year):
(2016-12-30, 18:30)Klojum Wrote: [ -> ]Installed the Global Search addon for, well, searching stuff.
Just try global search with local library, addons and themovieDB and all works good
(Windows 10 / Kodi 18 Alpha 1 / latest EstuaryMOD from git / all updated addons)
Hi there,
problem with codec infos is gone...
Now i have a little problem with ratings for some movies (i think JUST for harry potter movies...^^)
don´t really care...^^
Another thing, which you maybe could edit in your skin:
In the episode view (list), the rating for the selected episode is missing (screenshot).
Here´s a screenshot so you can see that there is a rating for this episode:
Maybe you could add it there just as in the movie-list-view?
Ps.: Ups, its another episode, but the selected episode above has really a rating
The rating isn´t shown at all episodes in this view
I have exactly the same problem (see
http://forum.kodi.tv/showthread.php?tid=...pid2486157)
Running Kodi 18, on Ubuntu 16.04, Estuary Mod 1.7.3
The imdb rating is not showing up for me. Also running time shows up blank if it's over 9 minutes.
Running Kodi 17 RC, latest version of estuary mod.
I have two questions more:
- What about coloured epg (coloured by epg genre)?
- What about a timeshift indicator for live-tv? -->
http://forum.kodi.tv/showthread.php?tid=226287 (for timeshifting in live-tv)...
After two days of usage i have to say it´s a really good skin, coming from aeon nox 5 silvo
I prefer the new look, but in some things there has to be some finishing
But: Really really good! Thank you so much!
Just find a new issue with skin on kodi 18 latest nightly
I try to access the casting tab:
But if I put my mouse on the tab, then the tab become empty:
And if I put the mouse lower on the tab, it close itself:
Works perfectly if using keyboard instead of mouse
Why no graphics in Weather Underground, while in Estuary there is graphics...
Estuary Skin
Estuary Mod 18 Skin
Sent from my iPhone
(2016-12-31, 19:17)iMak Wrote: [ -> ]Why no graphics in Weather Underground, while in Estuary there is graphics...
Estuary Skin
Estuary Mod 18 Skin
Sent from my iPhone (typie typie)
Confirming the issue:
And the "refresh" button does not seem to work
Kodi 18 latest nightly and latest estuaryMOD from git
Seems like movie set clearlogo is "dead" again:
Rework after restarting kodi!
Do not know what happened...
(2016-12-31, 19:46)Gracus Wrote: [ -> ]Seems like movie set clearlogo is "dead" again:
Found what's wrong!
If you open the extended info window:
Then movie set clearlogo will not be displayed anymore until you restart kodi:
Opening extended info window for one movie trigger the issue for all movie sets
