I switched it off now and going to sleep, I will check the installed version and will report back.
Hello
since there have been some releases already and this issue prevails I thought I would share it here.
On the home widget I have 2 duplicate ratings on the top of the screen. See the screenshots. It is random and as you can see on one widget it is duplicated and on another the same movie is not.
I only use the IMDb rating (hide rotten tomatoes option is turned on). In the 3rd screenshot you can see the movie's ratings just to be sure.
Can I assist in fixing this issue?
(2017-01-18, 22:50)Guilouz Wrote: [ -> ] (2017-01-18, 15:51)berkhornet Wrote: [ -> ]Great Skin Thanks . I noticed that when selecting "Settings" from the "Power Menu" nothing happens. The other options from the Power Menu work ok. Using Windows 10. Thanks.
Screenshot please ? Because there is no settings shortcut in power menu by default.
I added the Settings option via Skin Settings / Customize Power Menu
(2017-01-19, 09:28)jakubklos Wrote: [ -> ]Hello
Do you use Personnalizable Widgets ?
In third screenshot I don't see issue...
(2017-01-19, 13:06)Guilouz Wrote: [ -> ] (2017-01-19, 09:28)jakubklos Wrote: [ -> ]Hello
Yes, the 3rd picture has no problems. I only sent it to show what the IMDB and TMDB ratings are (in case they would have the same value and that could be the reason for duplicates - that is not the issue though)
Yes, I only use personalizable widgets because I have playlists for everything (Kids movies, Family movies, Other etc.). I didn't find any other way for the built-in widgets to show what I need (they show it all mixed from the big Movies source)
(2017-01-19, 13:06)Guilouz Wrote: [ -> ] (2017-01-19, 12:01)berkhornet Wrote: [ -> ] (2017-01-18, 22:50)Guilouz Wrote: [ -> ]Screenshot please ? Because there is no settings shortcut in power menu by default.
Please post debug log.
I try the same thing on kodi 18 and here is the error:
DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
16:12:30.350 T:8084 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
16:12:32.923 T:8084 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
16:12:32.923 T:8084 DEBUG: Activating window ID: 10004
16:12:32.923 T:8084 INFO: Activate of window '10004' refused because there are active modal dialogs
16:12:34.937 T:8084 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
16:12:34.937 T:8084 DEBUG: Activating window ID: 10004
16:12:34.937 T:8084 INFO: Activate of window '10004' refused because there are active modal dialogs
16:12:37.228 T:8084 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
16:12:37.228 T:8084 DEBUG: Activating window ID: 10004
16:12:37.228 T:8084 INFO: Activate of window '10004' refused because there are active modal dialogs
16:12:38.922 T:8084 DEBUG: CInputManager::ProcessMouse: trying mouse action leftclick
16:12:38.922 T:8084 DEBUG: Activating window ID: 10004
16:12:38.922 T:8084 INFO: Activate of window '10004' refused because there are active modal dialogs
16:12:39.061 T:8084 DEBUG: CInputManager::ProcessMouse: trying mouse action doubleclick
16:12:39.303 T:8084 DEBUG: ------ Window Deinit (DialogButtonMenu.xml) ------
Here is the full log:
http://pastebin.com/JbGTZv5g
(there is also an error earlier about "NEWADDON Unknown Video Info Key "progress"" that seems to come from skinhelper)
Hi, I am on latest nightly and when I activate the skin, while there is a notification that the menu is being built on the screen, the main menu on the left of the screen is empty.No movies,no TV, nothing... Any help? Thanks
Sent from my SM-N910C
Hi, I am running on OpenElec and Kodi Jarvis, and I have added your repo, but for some reason the folder Skin under Look and Feel remains empty ?
What am I doing wrong exactly, because I would like to have your Estuary skin
(2017-01-19, 20:09)iceman3000 Wrote: [ -> ]Hi, I am running on OpenElec and Kodi Jarvis, and I have added your repo, but for some reason the folder Skin under Look and Feel remains empty ?
You should have read the OP: kodi 17 krypton and kodi 18 leia only
The skin does not work on kodi 16 jarvis
(2017-01-19, 20:15)Gracus Wrote: [ -> ] (2017-01-19, 20:09)iceman3000 Wrote: [ -> ]Hi, I am running on OpenElec and Kodi Jarvis, and I have added your repo, but for some reason the folder Skin under Look and Feel remains empty ?
ok,thx I did not read that as good as I thought I did, thx for the info
(2017-01-18, 02:48)Guilouz Wrote: [ -> ] (2017-01-17, 22:59)awesomebuilder Wrote: [ -> ]Beautiful Skin! Thanks for sharing!!
Two question.
Im looking to delete background on the main menu screen.
How do I change font on this menu? Which line in font.xml file?
It's font14 in Font.xml but if you change it some fonts in other parts in skin will be change too. Or you can change it directly in Includes_Home.xml, home menu have ID 9000
Thaaaanks sir!
but how do I delete that background on main menu to make it fully transparent please
(2017-01-19, 18:26)kenmex Wrote: [ -> ]Hi, I am on latest nightly and when I activate the skin, while there is a notification that the menu is being built on the screen, the main menu on the left of the screen is empty.No movies,no TV, nothing... Any help? Thanks
Sent from my SM-N910C (typie typie)
Kodi 18 ?
Make sure to use SkinShortcut for Kodi 18 from first page
(2017-01-19, 21:13)elchupete Wrote: [ -> ] (2017-01-19, 18:26)kenmex Wrote: [ -> ]Hi, I am on latest nightly and when I activate the skin, while there is a notification that the menu is being built on the screen, the main menu on the left of the screen is empty.No movies,no TV, nothing... Any help? Thanks
Kodi 18 ?
Yes Kodi 18. Thanks for the help, I will try that.
