(2016-07-14, 19:13)BobCratchett Wrote: [ -> ]@Raabi2208 - Make certain you're running the git version of Skin Shortcuts (version 1.0.10) and if you still have the problem with video shortcuts not working when clicking on them (or, if that isn't your problem, whatever problem you have along with a description of the problem itself) then post a link to a full debug log (wiki) with the scripts own debug logging option enabled in addition to Kodi's (System/Settings > System > Add-ons > Manage Dependencies > Skin Shortcuts > Configure > Enable debug logging - and make sure to click 'OK' to save the setting) showing you editing the menu and the menu being rebuilt.
Hello BobCratchett,
thank you for your information with the path System/Settings > System > Add-ons > Manage Dependencies > Skin Shortcuts
I ve updatet serveral times the skin shortcuts but i dont get version 1.0.10
On the "Manage Dependencies there is the entry BigNoid,marcelveldt - 1.0.8 so I think i dont have the aktual Shortcuts addon.
Why isnt the shortcut updated when I click on it?
I dont know where to find but i will try to find the version 1.0.10
(2016-07-14, 20:27)Raabi2208 Wrote: [ -> ] (2016-07-14, 19:13)BobCratchett Wrote: [ -> ]@Raabi2208 - Make certain you're running the git version of Skin Shortcuts (version 1.0.10) and if you still have the problem with video shortcuts not working when clicking on them (or, if that isn't your problem, whatever problem you have along with a description of the problem itself) then post a link to a full debug log (wiki) with the scripts own debug logging option enabled in addition to Kodi's (System/Settings > System > Add-ons > Manage Dependencies > Skin Shortcuts > Configure > Enable debug logging - and make sure to click 'OK' to save the setting) showing you editing the menu and the menu being rebuilt.
Hello BobCratchett,
On first page... It's not a repo version, that's why update on Kodi not working.
(2016-07-14, 20:35)Guilouz Wrote: [ -> ] (2016-07-14, 20:27)Raabi2208 Wrote: [ -> ] (2016-07-14, 19:13)BobCratchett Wrote: [ -> ]@Raabi2208 - Make certain you're running the git version of Skin Shortcuts (version 1.0.10) and if you still have the problem with video shortcuts not working when clicking on them (or, if that isn't your problem, whatever problem you have along with a description of the problem itself) then post a link to a full debug log (wiki) with the scripts own debug logging option enabled in addition to Kodi's (System/Settings > System > Add-ons > Manage Dependencies > Skin Shortcuts > Configure > Enable debug logging - and make sure to click 'OK' to save the setting) showing you editing the menu and the menu being rebuilt.
Hello BobCratchett,
...... AAAAAND IT WORKS!!!! FU**** GREAT ...... :-)
Thank you BobCratchett your a Wizard
Sometimes a little bit more Information and its not so hard to fix any problems.
If i would have known where to find the Version 1.0.10 and If i would have known where
to see what Version of the Skin Shortcuts ive installed on my Pi3 and I wouldt have to ask so much.
For the Future - to all - Please give a little more detail for noobs like me because i dont know
every single step where to do this or that. Sometimes im only one click away but dont know where to search for.
Thanks a lot all!
Great Forum!
(2016-07-14, 20:52)Raabi2208 Wrote: [ -> ] (2016-07-14, 20:35)Guilouz Wrote: [ -> ] (2016-07-14, 20:27)Raabi2208 Wrote: [ -> ]Hello BobCratchett,
Thanks a lot all!
Great Forum!
I have already say many times you need latest addons on first page.
How can I set the default view? (some skins respond to right click and set as default)
Tnx!
Guilouz
I created a PR to add CinemaVision button to DialogInfo window. I hope you would like to consider adding it
During some tests I also noticed something strange. (version 1.3.5)
When in main menu and highlighting Unwatched or Random movies from widget and selecting Info it gives a completely different view as when you entered library and pressed Info there.
(2016-07-14, 23:54)MewCore Wrote: [ -> ]How can I set the default view? (some skins respond to right click and set as default)
Tnx!
You can change view with media menu when you press left on keyboard.
(2016-07-15, 00:27)Guilouz Wrote: [ -> ] (2016-07-14, 23:54)MewCore Wrote: [ -> ]How can I set the default view? (some skins respond to right click and set as default)
Tnx!
I understand that, but how to set a
default view? IE: I would like InfoWall show up in all categories and genres for movies. So far I need to set it manually for everything because lists is the default.
(2016-07-15, 00:48)MewCore Wrote: [ -> ] (2016-07-15, 00:27)Guilouz Wrote: [ -> ] (2016-07-14, 23:54)MewCore Wrote: [ -> ]How can I set the default view? (some skins respond to right click and set as default)
Tnx!
I understand that, but how to set a default view? IE: I would like InfoWall show up in all categories and genres for movies. So far I need to set it manually for everything because lists is the default.
You must set view for each window. Once done, no need to do later. Kodi save it.
Guilouz,
My apologies for the PR, didn't noticed the button before.
I'm also shocked to see what happened in your country!
My thoughts and prayers go out to all those affected by the tragedy in Nice!
(2016-07-14, 02:53)woodside Wrote: [ -> ] (2016-07-13, 14:36)woodside Wrote: [ -> ]"Could not connect to repository" when trying to install your mod.
Friendly bump.
Is there a problem with the repo your mod is located at? Been trying to connect for 3 or 4 days now in order to install your Estuary mod but have been unable to. Thanks
(2016-07-15, 15:02)woodside Wrote: [ -> ] (2016-07-14, 02:53)woodside Wrote: [ -> ] (2016-07-13, 14:36)woodside Wrote: [ -> ]"Could not connect to repository" when trying to install your mod.
Friendly bump.
No problem with it. I have updated my other system with repo with no problem.
Do you have 1.0.1 version of repo ?
(2016-07-15, 15:04)Guilouz Wrote: [ -> ] (2016-07-15, 15:02)woodside Wrote: [ -> ] (2016-07-14, 02:53)woodside Wrote: [ -> ]Friendly bump.
Yes... 1.0.1 d/l from first page is what I have. I try to choose "install from repository" then choose your repository but as soon as I do I get a message "could not connect to repository". No problem installing anything from any other repository.
