2016-04-04, 01:45
I share my custom skin based on Estuary.
Thanks to phil65 and Piers.
KODI 17 Krypton ONLY !
Development is discontinued for this version. Support was given at minus0. I only dedicated myself to Estuary MOD V2 for Kodi 18 : http://forum.kodi.tv/showthread.php?tid=306757
Features :
• Support for 21:9 screens
• Possibility to change skin color
• Movies, TV Shows and Custom Hubs
• Skin Shortcuts addon support
• LibreELEC Configuration / OpenELEC Configuration addons support
• Artwork Downloader addon support
• TV Show Next Aired addon support
• Global Search addon support
• Play Album addon support
• Nextup Service Notification addon support
• RSS Editor addon support
• CU LRC Lyrics addon support
• Library Editor Script addon support
• Clearlogos support
• ClearArts support
• CDArts support
• Extrafanarts support
• Studios icons support
• Record labels icons support
• Weather icons support
• Backup / Restore skin settings
• Possibility to change background opacity
• Kiosk Mode
• More in changelog...
Changes :
See : https://raw.githubusercontent.com/Guilou...ngelog.txt
Music Artworks :
It's easily to configure music artwork with context menu :
If you want to use your own artworks, your artist folder should look like this :
Files naming for 3D / Dolby Atmos / DTS-X / DVD / Blu-Ray flag icons :
Your filenames must contains :
atmos for ATMOS audio flag like : Batman Atmos.mkv / Batman - Atmos.mkv / Batman.Atmos.mkv
dtsx / dts-x for DTS-X audio flag like : Batman DTS-X.mkv / Batman.dts-x.mkv / Batman dtsx.mkv etc...
3d / 3D for 3D flag like : Batman 3D.mkv / Batman - 3D.mkv / Batman.3D.mkv
dvd / DVD for DVD flag like : Batman - DVD.iso / Batman (dvd).iso etc...
bluray / blu-ray / bdrip / BLURAY / BLU-RAY / BDRIP for Blu-Ray flag like : Batman Bluray.iso / Batman - bdrip.iso / Batman (Blu-Ray).iso etc...
Customizing widgets :
For preconfigured widgets, you can change each default widgets but you can't remove one of them.
Preconfigured widgets (video, movies, tv shows, music video, music) : Can be change but not remove.
Custom widgets : Fully customizable. You can add up to 6 widgets.
Required Add-ons :
- Script SkinShortcuts : This addon is needed to personnalize home menu and widgets.
- Marcelveldt's BETA repository : Repo from Marcelveldt to install Skin Helper Service and necessary dependencies.
- script.module.thetvdb : This addon is needed for Skin Helper Service.
- script.module.musicbrainz : This addon is needed for Skin Helper Service.
- Script ExtendedInfo : This addon is needed to show additionnal infos about movies, tv shows and musics.
- Skin Helper Service Skin Backup : This addon is needed to backup/restore skin settings.
- Skin Helper Service Color Picker : This addon is needed to change colors.
- Skin Helper Service Widgets : This addon is needed to use widgets.
- Script PlayAlbum : This addon is needed to play album on album infos screen.
- Script Image Ressource Select : This addon is needed to select weather icons, studio logos, etc...
- AutoCompletion for virtual keyboard : This addon is needed to show autocompletion of keyboard.
Additionnal Add-ons :
- Library Data Provider : This addon is required to add more widgets.
- Next Up Notification : This addon shows a popup next up notification automatically to prompt for playing the next unwatched episode.
- Artwork Downloader : This addon can automaticaly download all available artwork for your movies/tv shows in your library.
- Global Search : This addon lets you search content in your library.
- Youtube : This addon is required to watch trailers.
- cu.lrclyrics : This addon is required to display lyrics from songs.
- Library Editor Script : This addon is required to edit info in your library.
NB : All links are the latest from github.
Installation :
- In Kodi go to "Settings / Add-ons / Install from Zip file".
- Select downloaded ZIP file.
- Once installed, go to "Settings / Add-ons / Install from repository / Guilouz Repository / Look and feel / Skin" and install Estuary MOD (KODI 17).
- Select the skin to "Settings / Appearance / Skin".
Download link Guilouz Repository :
https://github.com/Guilouz/repository.gu...-1.0.3.zip
It's repository, my MOD will be automatically updated by Kodi (auto updates must be enable in Kodi settings).
Donate :
Features :
• ClearArts support
• CDArts support
• Kiosk Mode
Changes :
Music Artworks :
Required Add-ons :
Installation :
Donate :
