I replaced my htpc (with Pulse-Eight USB-CEC device, love that thing!) with an Nvidia Shield TV last week, but my tv (LG 47LX9500) doesn't seem to recognize the Shield as a CEC device. The Shield does turn on my tv when waking from sleep mode though, but I can't use my tv remote to control the Shield (or Kodi).
Is this normal, or should my tv recognize the Shield and should I be able to control Kodi? Of course I'll move this to Nvidia's forums if this should work, but I thought I'd try here first
No problem with my sony TV 9005B 4K with shield and kodi
(2015-11-04, 13:48)rb338 Wrote: [ -> ]I replaced my htpc (with Pulse-Eight USB-CEC device, love that thing!) with an Nvidia Shield TV last week, but my tv (LG 47LX9500) doesn't seem to recognize the Shield as a CEC device. The Shield does turn on my tv when waking from sleep mode though, but I can't use my tv remote to control the Shield (or Kodi).
Don't know about the Pulse-Eight device, but there are two issues:
- if CEC doesn't work (anymore) and all the settings in TV are right, you have to unplug all your devices including the TV from ~230V net for a few minutes. Try switch the TV on to unload capacitors. After that mostly CEC works (again)
- i have two HDMi cable, one made for 4k and Ethernet, and both cable doesn't work with CEC. I don't know why, but if i replace these cables with others it works.
(2015-11-04, 01:28)veegee21 Wrote: [ -> ]Thanks for the reply. So its an Nvidia issue not a Kodi issue then I take it?
I have no way to verify that. I don't have any other programs that will play VC-1 off my server. Plex is still in la-la land with wanting to transcode everything.
(2015-11-04, 16:04)querty1000 Wrote: [ -> ] (2015-11-04, 10:24)Martijn Wrote: [ -> ]nothing changed
What about this:
https://github.com/xbmc/xbmc/commit/6920...c18c0d22c7
Well, I actually thought that might cause CEC problem, but it does not on the SATV.
I'll anyway push a "preemptive" fix for less well-behaving devices later.
(2015-11-03, 17:35)hdmkv Wrote: [ -> ]Shield TV for $150 shipped... request a promo code here.
Just a correction to the above, the Shield does
NOT ship for $150 via Amazon.
That coupon code was made available to subscribers of the Nvidia newsletter for use in the Nvidia store, the price direct from them nets it down to the same $199 as found at Amazon.
Nope, it's $149.99 shipped for the 16GB model.
(2015-11-04, 17:24)hdmkv Wrote: [ -> ]Nope, it's $149.99 shipped for the 16GB model.
Is this available in the UK or just for the US?.
(2015-11-04, 18:26)hdmkv Wrote: [ -> ]Just U.S. I believe.
Cheers, Pity, the cheapest in the UK is £149
I also receive the code but from Amazon France so it has to be global...
I'm afraid you're mistaken. The discount code applies to the Nvidia store, which lists an MSRP of $50 more than the Amazon regular price. I got in touch with the moderator at the Nvidia forum, and this was his response:
Quote:Please note this code is only good for the SHIELD Android TV purchased through the NVIDIA Store. It does not apply to SHIELD Android TV accessories or other items sold through NVIDIA Store.
If you have other information, then please substantiate it, because so far your understanding seems faulty.
(2015-11-04, 19:53)Cincinnatus Wrote: [ -> ]I'm afraid you're mistaken. The discount code applies to the Nvidia store, which lists an MSRP of $50 more than the Amazon regular price. I got in touch with the moderator at the Nvidia forum, and this was his response:
I'm not sure of what you're trying to say. The SATV is listed for $199 on both the
Nvidia Store and
Amazon, so I don't know were you're getting that it's listed as $50 more.
With the coupon code that makes it $149 from the Nvidia Store.
Simple math......$199 - $50 = $149
