Shield is an awesome device to have. Not just for Kodi, which by the way works best for an android device, but other features as well.
I went to Best Buy last weekend and I did not expect to see it being sold there. I thought it was only being sold online. I had ordered online mine as soon as it got out and it has worked flawlessly for me since then.
I am thinking about buying the Pro version for a different room soon.
Hello all.... Is there any info on using a FTV 2 voice remote on the shield. I think I remember some issue with the voice part not working correct.
I just paired one and everything is working so far
that remark: will be available sometime soon, it's not encouraging at all specially when we know how slow is nvidia as providing upon promises
(2016-01-06, 11:11)abpostelnicu Wrote: [ -> ]that remark: will be available sometime soon, it's not encouraging at all specially when we know how slow is nvidia as providing upon promises
Not really since Nvidia has stated that it will be rolling out this month.
An educated guess though, is that it will start around the same time as the release of Metal Gear which is slated for release on Thurs.
Mine arrived, didn't have time to play with it extensively, but first impressions are good, very quick machine, 1080p 10bit files play smoothly, at first the blacks looked washed out, but changing the HDMI range from Full to Normal correct it, now they look too black, lol, had to change the gamma from 2.4 to 2.2.
(2016-01-06, 16:07)HCarvalho Wrote: [ -> ]1080p 10bit files play smoothly
Before any confusion, h264 10bits is s/w decoded on all androids. Just that the Shield is so powerful you won't notice
these were 10bit 1080p H265 files on Kodi
(2016-01-06, 16:36)HCarvalho Wrote: [ -> ]these were 10bit 1080p H265 files on Kodi
Ah, ok. Those are h/w decoded.
(2016-01-05, 11:20)Bjur Wrote: [ -> ]Thanks for the answer Tinwarble. So when adding a Windows PC I can map for instance keyboard "c" in smart control, assign it to a random button on the remote and assign "c" in keymap.xml to something like download subtile (can't remember my keymap.xml)?
Tinwarble can you help me answer this above?
can I use my wetek core remote with the Nvidia Shield?
nVidia on upcoming updates here; nothing new beyond above link, but interesting read nonetheless.
In the comments section, I'm again pushing them to add 3D MVC support... hope you guys post there as well.
Does kodi support Dolby TrueHD and DTS-MA in NVIDIA Shield ?
Because i try many movies in kodi but it is work as DTS while the other app support Dolby TrueHD and DTS-MA .
