2018-12-16, 21:00
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224
2018-12-16, 21:40
i am trying to get Netflix running on my Kodi Leia on Windows 10.
But i am not successful as when entering my (correct credentials) the Netflix Addon says they are invalid.
I installed everything mentioned on Page one of this thread - only thing that i found in the addon Dependencies is the "script.module.pycryptodome" that is not available.
Does this have anything to do with the problem?
Anyone running this addon on a windows kodi?
Thx for your help,
chemistry
Thx for your help,
chemistry
2018-12-17, 00:08
(2018-12-16, 21:40)chemistry Wrote: [ -> ]i am trying to get Netflix running on my Kodi Leia on Windows 10.Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.
Thx for your help,
chemistry
https://github.com/asciidisco/plugin.vid....13.21.zip
2018-12-17, 01:53
I'm trying to get some 1080p stream in some show and I'm unable to. Is there something wrong with it ?
2018-12-17, 02:08
(2018-12-17, 00:08)essam315 Wrote: [ -> ]Hello Essam, Do you mind shooting you a PM mate? or if you can start it as I don't have the rights yet to do,(2018-12-16, 21:40)chemistry Wrote: [ -> ]i am trying to get Netflix running on my Kodi Leia on Windows 10.Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.
Thx for your help,
chemistry
Just wanted to ask you about something if possible!
2018-12-17, 05:41
(2018-12-17, 02:08)whocaress Wrote: [ -> ]Sorry, i can not send to you private message, i get this word when i try "whocaress has private messaging disabled. You cannot send private messages to this user", what is the version number of your Netflix plugin, and what is your device, and what is the name of the shows you want to watch in 1080p? Not all the TV shows and movies can be watched in 1080P with Netflix plugin right now.(2018-12-17, 00:08)essam315 Wrote: [ -> ]Hello Essam, Do you mind shooting you a PM mate? or if you can start it as I don't have the rights yet to do,(2018-12-16, 21:40)chemistry Wrote: [ -> ]i am trying to get Netflix running on my Kodi Leia on Windows 10.Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.
Thx for your help,
chemistry
2018-12-17, 08:26
(2018-12-17, 05:41)essam315 Wrote: [ -> ]ah that's weird, its some Arabic tv show, and I’m using the latest version, I still would prefer to PM you about something I have been working on and can’t paste it publically, do you mind passing me your discord or others if you got that? mine is quick#5492(2018-12-17, 02:08)whocaress Wrote: [ -> ]Sorry, i can not send to you private message, i get this word when i try "whocaress has private messaging disabled. You cannot send private messages to this user", what is the version number of your Netflix plugin, and what is your device, and what is the name of the shows you want to watch in 1080p? Not all the TV shows and movies can be watched in 1080P with Netflix plugin right now.(2018-12-17, 00:08)essam315 Wrote: [ -> ]Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.Hello Essam, Do you mind shooting you a PM mate? or if you can start it as I don't have the rights yet to do,
2018-12-17, 08:45
double post...
2018-12-17, 08:46
(2018-12-17, 00:08)essam315 Wrote: [ -> ]That's what i did. I tried the newest nightly build and the RC2 - but same behavior.(2018-12-16, 21:40)chemistry Wrote: [ -> ]i am trying to get Netflix running on my Kodi Leia on Windows 10.Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.
Thx for your help,
chemistry
All with newest AddOn Version.
2018-12-17, 09:01
(2018-12-17, 08:26)whocaress Wrote: [ -> ]What is the name of this Arabic TV show? most of the TV shows are 1080p.(2018-12-17, 05:41)essam315 Wrote: [ -> ]ah that's weird, its some Arabic tv show, and I’m using the latest version, I still would prefer to PM you about something I have been working on and can’t paste it publically, do you mind passing me your discord or others if you got that? mine is quick#5492(2018-12-17, 02:08)whocaress Wrote: [ -> ]Hello Essam, Do you mind shooting you a PM mate? or if you can start it as I don't have the rights yet to do,Sorry, i can not send to you private message, i get this word when i try "whocaress has private messaging disabled. You cannot send private messages to this user", what is the version number of your Netflix plugin, and what is your device, and what is the name of the shows you want to watch in 1080p? Not all the TV shows and movies can be watched in 1080P with Netflix plugin right now.
2018-12-17, 09:05
(2018-12-17, 08:46)chemistry Wrote: [ -> ]Sometimes Netflix changes the password by itself in case of using VPNs many times, open google chrome and try to login with your email and password to be sure that everything is right, and if you are already using google chrome for watching Netflix, logout and login again. And "script.module.pycryptodome" has nothing to do with your problem.(2018-12-17, 00:08)essam315 Wrote: [ -> ]That's what i did. I tried the newest nightly build and the RC2 - but same behavior.(2018-12-16, 21:40)chemistry Wrote: [ -> ]i am trying to get Netflix running on my Kodi Leia on Windows 10.Uninstall Kodi full uninstall, and install this file, from the main page press on "add-ons", then press on "Download", then press on "..", and press on "Install from zip file", you will get a message, press on "Settings" then press on "Unknown sources" and press on "Yes", return to the previous page, then "Install from zip file", and install the Netflix plugin file.
Thx for your help,
chemistry
Go to
C:\Users\Essam\AppData\Roaming
C:\Users\Essam\AppData\Roaming\Kodi
and delete or rename "Kodi" folder, open Kodi and install this version, do not install different versions over each other.
https://mega.nz/#!ptcx1aZR!rVPoAd-WIApD1...GySB2fHof0
2018-12-17, 18:03
Im unable to export tv shows to the main screen..
I just export and nothing happens.. But if I also enable custom export folder.. I cant find my drive with my media on it from the browse function. I see all kinds of folders, but no drives to go to my tv shows folder.
I am using a raspberry pi with just libreelec on it.
Should I wait until it comes out of beta or am I doing somethibg wrong??
2018-12-19, 08:47
(2018-12-17, 18:03)Daikath Wrote: [ -> ]Im unable to export tv shows to the main screen..Exporting netflix shows just places files in a directory.
As i've already told you, that directory needs to be defined as a source, a scraper linked to it and then the sources updated before these netflix exported files appear within Kodi proper.
Finding where this diretory lives is not really an add-on or kodi issue but see my answer here for more details on where the default libreELEC locations are found.
2018-12-19, 17:08
I have netflix working on both my RPi3+ and on my windows laptop but I noticed that the structure of the addon is different on both platforms
Example:
searching on my RPi3+ I get something like
Are there plans to have a similar structure on all platforms? As the current situation is wreaking havoc with my favourites and library which I like to share between platforms.
Example:
While a searching on my windows laptop results in something likepython:plugin://plugin.video.netflix/?action=search_result&term=Ant-man
python:plugin://plugin.video.netflix/directory/search/Ant-man
2018-12-19, 22:47
(2018-12-15, 16:55)essam315 Wrote: [ -> ](2018-12-15, 16:09)Huey Wrote: [ -> ]Unfortunately the caphm version 0.14 beta 18 does not work anymore on the Millhouse alfa builds of LibreElec for raspberry. Returned to the 0.13.21 and that works (after a de-install with all settings removed).Try this fixed 0.14.1 it should work for you (not fixed by me, all credit goes to "jakermx" from GitHub), uninstall everything first (this is not an official release, i just gave the fixed release a new number to differentiate it from 0.14.0 beta 18).
Using the 0.14beta18 pops a dialog saying so much as not ok and look in the log...
Tried to find something in the debug-log but it does not give anything useful? (would post it full but the netflix strings contain alot of privacy sensitive data...)
Think these are relevant bits:
14:44:54.655 T:1524618096 DEBUG: [plugin.video.netflix (0)] Executing POST request to http://www.netflix.com/api/msl/NFCDCH-LX...m/manifest
14:44:55.325 T:1524618096 DEBUG: [plugin.video.netflix (0)] Request took 0.090017s
14:44:55.325 T:1524618096 DEBUG: [plugin.video.netflix (0)] Request returned response with status 200
14:44:55.330 T:1524618096 DEBUG: [plugin.video.netflix (0)] Received encrypted chunked response
14:44:55.351 T:1524618096 ERROR: [plugin.video.netflix (0)] Full MSL error information:
14:44:55.358 T:1524618096 ERROR: [plugin.video.netflix (0)] {"result": {"errorDetails": "No message available", "errorDisplayMessage": "", "data": {"DEFINITION": {"PRESENTATION_TYPES": {"1": "PRIMARY", "0": "COMMENTARY", "2": "ASSISTIVE"}, "OPEN_CONNECT_SIGNALS": {"IS_HTTPS_SUPPORTED": "false"}, "OFFLINE_DOWNLOAD_DESCRIPTOR": {"QUALITY": "DEFAULT"}, "SUPPORTS_PREVIEW_CONTENT": true, "NETWORK_TYPE": "UNKNOWN", "INCOMPATIBLE_MEDIA_INCLUDED": false, "BRANCHED_CONTENT_REQUESTED": false, "trackId": 0, "CUSTOMER_DATA": {"RESTRICTED_BY_TESTER_TYPE": false, "STREAM_QUALITY": "UNSPECIFIED", "EXPERIENCE_TYPE": "regular",
... snip ...
"REQUEST_CONTEXT_CLOCK_TIME": 1544881495, "REQUEST_CONTEXT_DEVICE_TYPE_ID": 781}, "errorExternalCode": 2206, "errorSubCode": 1331}, "success": false}
Anyone else experiencing this and hopefully has a solution?
(The pycrypto lib is supposed to be in the alfa builds and can not be installed with pip for that matter).
Hi, great, I will give this a try. Thx!
