2019-02-18, 20:24
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224
2019-02-18, 21:24
(2019-02-17, 11:19)c_c_c_66 Wrote: [ -> ]You're kidding enable_atmos_sound is broken code, atmos profile is enabled by default(2019-02-16, 22:24)grobbie Wrote: [ -> ]Hi,I have no problem with 4K enabled but no Atmos sound (and my home theater is capable of Atmos); could you please post a copy of your edited settings.xml files please?
First of all really love this addon. I just installed version 14 beta 20 on my Shield tv for the atmos support. But for some reason atmos content wil not start. The screen switches to 24hz but then instead of playing the loading icon displays indefinitely. This happens with all atmos content. Non atmos content works correctly.
I set the android settings to surround always as suggested earlier in this thread. Also edited the settings.xml to set the atmos flag to true (is was not present in the settings ui).
Any ideas?
Thanks,
Grobbie
Thnak you!
you only need to set:
Shield setting -> Display & Sound -> Advanced settings -> Surround Sound -> Set to Always
only and after set to kodi options hd audio passtrought to enabled
then reboot kodi
2019-02-18, 21:43
(2019-02-17, 23:53)kowalmisiek Wrote: [ -> ]Hi stefive83(2019-02-17, 22:28)stefive83 Wrote: [ -> ]1. In what KODI motif can you see the HDR flag?(2019-02-15, 20:08)kowalmisiek Wrote: [ -> ]I tested the new version of 20.4K. It works very well.
There are several problems that are known.
1. No HDR flags (HDR icon in the movie list menu)
2. In each film and series there is an icon (Falaga) "Dolby Digital Plus 4.1". The sound is in 5.1 format.
3. In the list of movies, the resolution of the film and the series is displayed incorrectly. (1080p instead of 4K)
It was also a great idea to add a function that is on android tv. When you select a TV series or movie, its trailer appears.
1. HDR media-flag is not supported by the standard kodi theme
2. Please give some examples of films/series showing 4.1 instead of 5.1
and give me the kodi log with enabled debug informations by following these steps:
-install latest release: https://github.com/CastagnaIT/plugin.vid...master.zip
-enable kodi debug informations
-enter in the menu and display the list of movies / TV series that show the problem-exit kodi and put the log file here
3. Give some examples
2. Sorry for the confusion. I just turned on the standard KODI Estuary skin. In this skin the soundtrack is displayed correctly 5.1. I use Eminence skins by Alanon and there is on all video sound 4.1 in the Netflix plugin. Is this the fault of Eminence skin?
3. In every TV series I reviewed, I have a 1080p menu description. And when I turn on a given series, 4k works. Example: Ozark, Stranger Things, Sex Education. Generally, I have not seen anywhere that there was a 4K flag.
https://zapodaj.net/c05bfdbc29446.png.html
Did you check what I wrote? Do you also have the 1080 flag on the TV series I have exchanged?
2019-02-18, 22:30
(2019-02-17, 23:53)kowalmisiek Wrote: [ -> ]1. kodi themes do not currently support the HDR flag(2019-02-17, 22:28)stefive83 Wrote: [ -> ]1. In what KODI motif can you see the HDR flag?(2019-02-15, 20:08)kowalmisiek Wrote: [ -> ]I tested the new version of 20.4K. It works very well.
2. I tried to install it but from errors in the installation, I think that theme has bug. I've tried this https://github.com/jurialmunkey/skin.eminence.2/ and audio flag seem correctly.
3. To me the series you mentioned the flags are correct in 4K,
i don't know what device you're using, but you can try to delete all the content of cache folder:
Kodi\userdata\addon_data\plugin.video.netflix\cache
2019-02-18, 23:55
(2019-01-26, 01:25)neurosis13 Wrote: [ -> ]would it be possible to also export the artwork like clear logo landscape,fanart etc. alongside the movies and tv-shows ?
that would be a nice feature.
Would that be possible?
2019-02-19, 01:02
I was having problems with getting any content to play, so I messed around with the settings and then accidentally reset them to standard, and now the pre-filled ESN is gone! I've got an M8S PRO rk3229, and since it's just a TV box without a sim card I can't find the ESN/IMEI where it's supposed to be in the android settings. What do I do? I've uninstalled the addon and deleted all its data, rebooted kodi, reinstalled the addon, and the field still won't populate automatically. I know for certain it was filled before i reset the settings, but I was stupid and didn't write it down anywhere. Any suggestions?
2019-02-19, 06:27
(2019-02-18, 20:24)ardatanik Wrote: [ -> ]i have problems in android tv
log http://pasted.co/dcc1cc4a
please help
I can log in my account, i can see films,series... but when i click to play, i get cipherKeyId for “Encrypt” error.
https://ibb.co/NSLv2kQ
2019-02-19, 09:17
(2019-02-18, 22:30)stefive83 Wrote: [ -> ](2019-02-17, 23:53)kowalmisiek Wrote: [ -> ]1. kodi themes do not currently support the HDR flag(2019-02-17, 22:28)stefive83 Wrote: [ -> ]1. HDR media-flag is not supported by the standard kodi theme1. In what KODI motif can you see the HDR flag?
I use Nvidia Shield TV
1. By saying the themes you mean that KODI does not support or do you mean that skins do not have HDR display functions?
2. To install Eminence from Alanon you need a repository which is given in the temptation with the skin.
Here's the link https://github.com/marcelveldt/repositor...-1.0.1.zip
3. I will take away everything that is in this path as you write: Kodi\userdata\addon_data\plugin.video.netflix\cache
I am afraid, however, that it will not do anything. I recently reinstalled the entire KODI and the 1080 flags are still there.
2019-02-19, 16:20
(2019-02-19, 06:27)ardatanik Wrote: [ -> ](2019-02-18, 20:24)ardatanik Wrote: [ -> ]i have problems in android tv
please help
Is there anyone can help me?
2019-02-19, 18:06
Does a bug tracker exist for the children account? I have the same issue with 14b20
Also, is there a way to style the addon in such a way it looks a bit more like netflix app itself?
For regular kodi items i like the default look because i know what I have but the regular netflix app allows a for a lot more easy browsing. Or is this something that needs a entire kodi skin?
2019-02-19, 18:15
(2019-02-19, 01:02)cryptid Wrote: [ -> ]I was having problems with getting any content to play, so I messed around with the settings and then accidentally reset them to standard, and now the pre-filled ESN is gone! I've got an M8S PRO rk3229, and since it's just a TV box without a sim card I can't find the ESN/IMEI where it's supposed to be in the android settings. What do I do? I've uninstalled the addon and deleted all its data, rebooted kodi, reinstalled the addon, and the field still won't populate automatically. I know for certain it was filled before i reset the settings, but I was stupid and didn't write it down anywhere. Any suggestions?
Netflix ESN is NOT the same as your phone's ESN/IMEI. ESN that Netflix needs is set by Input-Stream adaptive.., not by Netfix addon.
I think that you need to uninstall your "input-stream adaptive" addon and "inputstream adaptive helper" along with Netflix addon, reboot and first install inputstream adaptive and helper to get propper Netflix ESN again...
2019-02-19, 21:21
I have a Raspberry Pi 3 B+, and Netflix will not work. Worked last week, but not now. Will not play anything. Kan select everything I wont, but fail when Im trying to play
Anyone who can help me?
2019-02-19, 22:51
(2019-02-19, 09:17)kowalmisiek Wrote: [ -> ]1. I mean the various kodi skins, they don't show the HDR flag, but HDR video technology is supported(2019-02-18, 22:30)stefive83 Wrote: [ -> ](2019-02-17, 23:53)kowalmisiek Wrote: [ -> ] 1. In what KODI motif can you see the HDR flag?1. kodi themes do not currently support the HDR flag
2. when I have more time I will try this link
3. this way I can't help you more, follow:
install latest: https://github.com/CastagnaIT/plugin.vid...master.zip
opening ONLY one list of titles with wrong flags (no more than a list of videos otherwise I don't understand the log anymore, in case you make a mistake restart kodi to clean the log),
specifying two or three titles that are displayed.
Copiy here the log file with debug info activated
2019-02-20, 00:47
(2019-02-19, 18:06)daffeh Wrote: [ -> ]Does a bug tracker exist for the children account? I have the same issue with 14b20there are 2 Titan Skin Mods for that.
