(2019-06-28, 13:36)badsheep Wrote: [ -> ] (2019-06-28, 08:39)badsheep Wrote: [ -> ] (2019-06-27, 20:33)stefive83 Wrote: [ -> ]I see no errors in netflix addon but several problems with the kodi service
something is not working in your kodi installation or is your skin cause of problems to kodi
Thanks for the help CastagnaIT !
And thanks for your great job !
I'm not sure the problem comes from my install...
Just to test I renamed my Kodi folder, to start from scratch.
Just installed Netflix and Pellucid, nothing else...
And the problem is still here, see the log here.
EDIT. When you look at the log, I agree you can't see nothing...
The bug happens between the lines 318 and 319, during those 15 seconds nothing happens, the wheel keeps turning.
Hello,
I just found a "workaround".
- If I launch the add-on from the "add-on" section > it doesn't work.
- If I create a link in the menu that points to the list of the Netflix users (that's the way I proceed usually) > it doesn't work
- BUT if I create a link in the menu that points inside the list of a chosen Netflix User > IT WORKS !!
It's like it's not possible anymore to display the list of users, but when you're "inside" a user, it works.
Strange, no ?
This behavior is with pellucid, not with estuary.
unfortunately non-standard skins do not always work well and often cause problems
it is not a problem of the addon but of those who develop these skin
if the author of the skin has corrective proposals, it can be discussed
otherwise change skin
(2019-01-26, 01:25)neurosis13 Wrote: [ -> ]would it be possible to also export the artwork like clear logo landscape,fanart etc. alongside the movies and tv-shows ?
that would be a nice feature.
+1
Has that been already integrated?
How does up next integration work? I have never had anything show related to what's next after watching a show and the option to configure up next is not accessible in the settings even though up next integration is enabled.
(2019-06-29, 05:12)stafio Wrote: [ -> ]How does up next integration work? I have never had anything show related to what's next after watching a show and the option to configure up next is not accessible in the settings even though up next integration is enabled.
in order to work you need to install the Up Next addon
Hi! Is there currently a signing in problem with the addon? It keeps telling me to check my credentials, however I know the u/p is correct and Netflix does indeed send me an email saying there had been a sign in. Many thanks!
On Leia 18.1 / Windows 10 / 0.14.0
(2019-07-01, 01:32)Nyctobello Wrote: [ -> ]Hi! Is there currently a signing in problem with the addon? It keeps telling me to check my credentials, however I know the u/p is correct and Netflix does indeed send me an email saying there had been a sign in. Many thanks!
You need newer v0.14.6 (also update your Kodi v18.3)
Updated to 14.6 and still getting the error "Exception: AddonSignals call timed out" randomly.
Running the latest CoreELEC on OdroidC2.
Sorry for not posting the log, but the logfile uploader addon isn't working.
I'm new the forum so please be patient if I do something wrong. I use LibreElec 9.0.1 with the Netflix Add-on. It worked just fine until a few days ago.
When I now start the plugin I can see the different users in my account but If I click on any user a message appears that the plugin stopped working. I attached the
log file.
I already tried a complete reinstallation of the plugin including the deletion of the configuration.
Any ideas how to solve the problem?
a question you know if addon vpnmanager openvpn and nordvpn work with this netflix addon, since netflix detects me that I use proxy and in my pc in web browser works well nordvpn
Those are not things we support here - see our
VPN policy (wiki) for more details.
If you want help with the manager, there's a thread for it on the LE forums where Zomboided can maybe assist you.
2019-06-29 22:55:08.300 T:1080464240 ERROR: GetDirectory - Error getting /usr/lib/kodi/addons/inputstream.adaptive/
2019-06-29 22:55:23.706 T:1146676080 ERROR: [plugin.video.netflix (0)] Traceback (most recent call last):
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/services/msl/http_server.py", line 47, in do_GET
data = self.server.msl_handler.load_manifest(int(params['id'][0]))
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/services/msl/msl_handler.py", line 41, in error_catching_wrapper
return func(*args, **kwargs)
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/common/misc_utils.py", line 238, in timing_wrapper
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/services/msl/msl_handler.py", line 109, in load_manifest
manifest = self._load_manifest(viewable_id, g.get_esn())
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/services/msl/msl_handler.py", line 162, in _load_manifest
'languages' : [g.PERSISTENT_STORAGE['locale_id']],
File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/common/storage.py", line 35, in __getitem__
return self.contents[key]
KeyError: u'locale_id'
2019-06-29 22:55:23.708 T:1080464240 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 400
2019-06-29 22:55:23.708 T:1080464240 ERROR: CCurlFile::Open failed with code 400 for http://localhost:36949/manifest?id=80126025:
2019-06-29 22:55:23.708 T:1080464240 ERROR: AddOnLog: InputStream Adaptive: Cannot download http://localhost:36949/manifest?id=80126025
2019-06-29 22:55:23.708 T:1146676080 ERROR: Traceback (most recent call last):
2019-06-29 22:55:23.708 T:1146676080 ERROR: File "/usr/lib/python2.7/SocketServer.py", line 290, in _handle_request_noblock
2019-06-29 22:55:23.708 T:1080464240 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://localhost:36949/manifest?id=80126025)
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/SocketServer.py", line 318, in process_request
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/SocketServer.py", line 331, in finish_request
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/SocketServer.py", line 654, in __init__
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/SocketServer.py", line 713, in finish
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/socket.py", line 283, in close
2019-06-29 22:55:23.709 T:1146676080 ERROR: File "/usr/lib/python2.7/socket.py", line 307, in flush
2019-06-29 22:55:23.709 T:1146676080 ERROR: error: [Errno 32] Broken pipe
2019-06-29 22:55:23.711 T:1080464240 ERROR: CVideoPlayer::OpenInputStream - error opening [/storage/.kodi/userdata/TV Shows/Netflix/shows/Star Trek Discovery/S01E01.strm]
On Raspi / libreelec / 0.14.6
Getting the error locale_id was not found after a while if I try to start a stream. I can still browse Netflix but can't start a stream. Reboot helps, but then I'd have this error again after a day or so.
