Full Version: TV Guide Fullscreen - possibly the most powerful TV Guide in the world. ;)
(2016-10-30, 13:59)ProjectUltra Wrote: [ -> ]That's great, thank you. I have KODI & your add-ons running on my raspberry pi and i would have WebGrab ++ running on my windows laptop, would your addon still work that way? Also does the file update its self (in terms of upcoming programmes) or would I have to keep downloading the tv guide to get next weeks programme viewing?
Hopefully that makes sense. Your help is much appreciated.
You need to schedule Webgrab++ to run every day or so depending on how many days of programs you like. I just have 2.
If you use LibreELEC on your raspberry pi it has a built-in service for Webgrab++ that runs every six hours.
It will be more configurable in a forthcoming release.
https://forum.libreelec.tv/thread-1102.html
I use a Windows7 computer as my home server which runs Webgrab++ every night using the Task Scheduler.
The action I use for the task is "C:\Program Files\ServerCare\WebGrab+PlusV1.1.1\WebGrab+Plus.exe"
and the argument is the folder with the config files in. For me it is "e:\xmltv"
(2016-10-30, 14:07)primaeval Wrote: [ -> ]
I will be doing more research into this and find the best possible set up. Also can I just download files from http://webgrabplus.com/epg-channels#s12B and then put it on a USB stick, place it in the raspberry pi and then find the file and connect it to you TV Guide Fullscreen addon using the XMLTV file option in your addon settings.
Sorry for all the question. aha
(2016-10-30, 14:12)ProjectUltra Wrote: [ -> ]I will be doing more research into this and find the best possible set up. Also can I just download files from http://webgrabplus.com/epg-channels#s12B and then put it on a USB stick, place it in the raspberry pi and then find the file and connect it to you TV Guide Fullscreen addon using the XMLTV file option in your addon settings.
Those are just the files that configure webgrab to be able to scrape the tv providers.
You need to put them in the folder that webgrab likes or specify a folder on the command line.
You are just going to have to sit down with a cup of coffee and read some of their documentation and try out a few things.
They have a QuickStart guide at:
http://webgrabplus.com/documentation/quick-start
and mine is on the first page of my addon.
@primaeval, thanks again, I am using pt-br language.
Sorry, I forgot to inform you that in movies and TV shows works well, doesn't match for local programs imagens.
Hinkel
(2016-10-30, 18:04)Hinkel Wrote: [ -> ]@primaeval, thanks again, I am using pt-br language.
Hinkel
thetvdb.com does have mainly English shows but English local TV is hit and miss too.
If you find a good searchable source for pt-br images let me know and I'll try to add it in.
Are the new version 0.0.172 name matching Settings helping prevent bad matches?
Hi I found this .....
http://www.webgrabplus.com/sites/default...NY_USA.xml
Is there a way to convert it to xmltv, so it can work as an XMLTV Source in the TV Guide Fullscreen addon?
(2016-10-30, 18:39)ProjectUltra Wrote: [ -> ]Hi I found this .....
That is the channel config file for yo.tv. You need to select which channels you want and add them to the WebGrab++.config.xml file. Then put the associated .ini file in the same directory and run webgrab. My addon automates those steps for you. All you need to do is install webgrab and its update.
Try following my QuickStart and tell me where you get stuck. Go slow and read everything twice.
I will test the latest version. As mentioned earlier the skin.helper service works well for me. thanks again.
I downloaded WebGrabber+ on my windows laptop and followed all the installation instruction provided on their website as well as some youtube videos. How do I add my own channels and create a guide? Do i just use notepad to edit the guide.xml file?
Thank you for your help in advance.
Tutorial for Windows Install of Webgrab++
1. Main program installation
Download main webgrab program from
http://webgrabplus.com/download
currently
http://webgrabplus.com/sites/default/fil...1.1MSI.rar
unrar it
install with WebGrab+PlusV1.1.1MSI\Install.bat
the exe ends up in
the data ends up in
C:\ProgramData\ServerCare\WebGrab
Download the Upgrade from the same place
currently
http://webgrabplus.com/sites/default/fil...exe_57.zip
unzip it
Right Click on patchexe.bat and Run As Administrator
2. Webgrab+Plus Configurator installation
Download my repo from
https://github.com/primaeval/repository....-0.0.1.zip
install it in Kodi via System \ Addons \ Install from zip
Go into System \ Addons \ Install from Repository \ primaeval.. \ Programs \ Webgrab+Plus Configurator
and
Install
3. Webgrab+Plus Configurator settings
Kodi \ Programs \ Webgrab+Plus \ Settings
Paths
Webgrab+Plus Program:
Config Output Folder:
wherever you like (locally)
Config
xmltv Output Folder:
whereever you like
xmltv file name:
xmltv.xml (is easiest)
OK
4. Webgrab+Plus Configurator operation
Download Site Pack
ends up in:
userdata\addon_data\script.webgrab\webgrab\siteini.pack
Lab \ tv.com
enter your zip code
10001
enter your time zome (you might have to experiment)
UTC or US/Mountain or UTC-05:00
Choose Provider
Add to Channels (just choose a couple at first to test)
The selected channels will be in Selected Channels and in Countries \ USA \ tv.com
Output Config Files
This will output the main WebGrab++.config.xml, and tv.com ini and cookie file into the Folder you selected in "Config Output Folder".
Have a look in there to see what it has made.
Run Webgrab
If all goes well you should have an xmltv.tv in the folder you selected in "xmltv Output Folder".
5. Webgrab++ Scheduler
Windows \ Program Search \ Task Scheduler
Menu \ Action \ Create Task
Triggers: new, 3:00AM daily
Action: new,
Program: C:\Program Files\ServerCare\WebGrab+PlusV1.1.1\WebGrab+Plus.exe
Add Arguments: wherever "Config Output Folder" is
OK
6. Webgrab+Plus Configurator advanced
Selected Channels \ Right Click \ Sort Channels | Move | Rename etc
then
Output Config Files
More info in the main thread here:
http://forum.kodi.tv/showthread.php?tid=...id=2389809
(2016-10-31, 13:27)primaeval Wrote: [ -> ]Tutorial for Windows Install of Webgrab++
currently
unrar it
the exe ends up in
the data ends up in
currently
unzip it
and
Install
Paths
Config
whereever you like
xmltv file name:
OK
Download Site Pack
ends up in:
Lab \ tv.com
enter your zip code
10001
Choose Provider
Output Config Files
Run Webgrab
Action: new,
OK
then
Output Config Files
Thank you very much! I will follow the instructions later and tell you if I'm successful or not.
Much appreciated. Blush
Everything went very smoothly up to this point.... (Marked "<<<<<<<<<<<<")
Download Site Pack
ends up in:
Lab \ tv.com
enter your zip code
10001
Choose Provider
Output Config Files
Run Webgrab <<<<<<<<<<<<<<<<<<
My set up is running Kodi on the raspberry pi (and your Web grab+Plus Configuration add-on) and my windows laptop running WebGrabber+ as well as holding the files from WebGrabber++ . I'm using a SMB file sharing connection so Kodi can access files on my computer. When I run web grabber is says "Starting" them "add-on error".
Any ideas on what the problem could be?
Edit #1: To add what should the Config Output folder be? Should it be on my laptop or Raspberry Pi Kodi?
Edit #2: I've noticed that the xmltv.xml file isn't being created. Is there a reason why?!?
(2016-10-31, 17:02)ProjectUltra Wrote: [ -> ]...
Start on Windows so you know exactly what is happening to what files when and where.
Look inside them with a decent text editor. I use Notepad++ these days.
Then go on to LibreELEC on the raspberry pi and use these settings in
/storage/.kodi/userdata/addon_data/script.webgrab/settings.xml
Make sure you have installed the LibreELEC webgrab service from their repo.
<settings>
<setting id="config_output_folder" value="/storage/.kodi/userdata/addon_data/service.webgrabplus/" />
<setting id="exe" value="/storage/.kodi/addons/service.webgrabplus/bin/webgrabplus.start" />
<setting id="mdb" value="false" />
<setting id="mdb_grab" value="false" />
<setting id="mdb_run" value="false" />
<setting id="proxy" value="" />
<setting id="proxy_password" value="" />
<setting id="proxy_user" value="" />
<setting id="rex" value="false" />
<setting id="rex_grab" value="false" />
<setting id="rex_run" value="false" />
<setting id="timespan" value="2" />
<setting id="update" value="0" />
<setting id="user_agent" value="" />
<setting id="xmltv_name" value="guide_wgp.xml" />
<setting id="xmltv_output_folder" value="/storage/.kodi/userdata/addon_data/service.webgrabplus/" />
</settings>
The output xmltv file should end up here
/storage/.kodi/userdata/addon_data/service.webgrabplus/guide.xml
which you can add to TV Guide Fullscreen
if you turn on
Kodi \ System \ Appearance \ File Lists \ Show Hidden Files and Directories.
(2016-10-31, 18:21)primaeval Wrote: [ -> ]
<settings>
</settings>
if you turn on
Okay thanks! Will follow those instructions. I'm using OSMC to run kodi should I download LibreELEC instead?
(2016-10-31, 18:24)ProjectUltra Wrote: [ -> ]Okay thanks! Will follow those instructions. I'm using OSMC to run kodi should I download LibreELEC instead?
Yes. Their webgrab service is an exclusive right now.
